Bearing movement with the sprocket carrier
geordiecbrblo...
PostPosted: 14:38 - 22 Nov 2008    Post subject: Bearing movement with the sprocket carrier Reply with quote
Hi workshop,
I got an advisory on my MOT for the sprocket carrier bearing, so while it is thick with snow outside, I decided to have a look!
The actual bearing is fine, but can move slightly within the hub - what can I do? A drop of Loctite and press the bearing in or is that a bodge? New sprocket carrier?
Thanks,
Paul
yandy_yay
PostPosted: 18:15 - 22 Nov 2008    Post subject: Reply with quote
could you take the carrier to a local machine shop and get the recess for the bearing machined up bya few mm and fit a bearing with a bigger outside size but same internal diameter ?
Andy
p.s. I would say that the loctite is a bodge and would likely not hold for long.
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
geordiecbrblo...
PostPosted: 20:49 - 22 Nov 2008    Post subject: Reply with quote
Andy
Cheers Andy, all things considered I've decided to buy a decent used one - there seems to be quite a few on ebay, hopefully not as worn as my current one!
All the best,
Paul
MaybeGuy
PostPosted: 00:47 - 23 Nov 2008    Post subject: Reply with quote
its an advisory.
ignore it.
yandy_yay
PostPosted: 07:48 - 23 Nov 2008    Post subject: Reply with quote
if there is movement it would be unwise to simply ingnore it, it will wear more rapidly than it should and will soon reach a point where the sprocket can twists sideways under load and possible cause the chain to depart company with the spocket, something that no one wishes especially at speed.
Andy
Gazdaman
I did a trackday!!!
PostPosted: 11:12 - 23 Nov 2008    Post subject: Reply with quote
Get it sorted. I suggest you just fit a new bearing. The one in there is probably knackered or the wrong size.
The sprocket carrier bearing went on my GS. It did all sorts of damage, and left me stranded 40 miles away. I was lucky it didn't break the chain. But it did very nearly junk the swing arm as the wheel could twist and the bolts holding the sprocket onto the carrier hit the swing arm whilst spinning at 50mph etc.
My fix was to buy a new sprocket carrier. It was £20 inc postage and had a brand new bearing fitted.
Depends on the bike though.
Gaz
The last post was made 17 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 48.91 Kb
