wont start cold kawasaki zxr400 :(
pixel
PostPosted: 20:57 - 23 Nov 2008    Post subject: wont start cold kawasaki zxr400 :( Reply with quote
I didn't have any problems with my zxr up until now (almost a week now) Sad - it will not start on cold ... starter motor will turn, but theres no ignition. Though it will start after 6-7 attempts, which is not normal, i presume.
After running it for a while (hot) it starts as a charm.
Battery has been replaced 2 weeks ago.
Guys will appreciate any help ,
thanks,
geordiecbrblo...
PostPosted: 21:22 - 23 Nov 2008    Post subject: Reply with quote
Is the choke lever / cable working ok?
When were the spark plugs last changed?
pixel
PostPosted: 21:27 - 23 Nov 2008    Post subject: Reply with quote
is the choke lever / cable working ok?
Choke lever is fine - spark plugs were changed long time age - i was thinking about the spark plugs but why it starts normally on hot ?
geordiecbrblo...
PostPosted: 22:47 - 23 Nov 2008    Post subject: Reply with quote
I'd suggest changing the plugs then Wink
A new plug with correctly adjusted gap will produce a nice fat healthy spark, worn out ones produce a weaker spark... it might make all the difference on a cold start Thumbs Up
pixel
PostPosted: 23:56 - 23 Nov 2008    Post subject: Reply with quote
thanks for your reply geordiecbrbloke - i guess the time has come to change the plugs.
geordiecbrblo...
PostPosted: 00:09 - 24 Nov 2008    Post subject: Reply with quote
You're welcome, let us know how you get on Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 05:25 - 24 Nov 2008    Post subject: Reply with quote
Same problem/fix as this thread:
https://www.bikechatforums.com/viewtopic.php?t=161408
Ariel Badger
PostPosted: 08:56 - 24 Nov 2008    Post subject: Reply with quote
ZRX61 wrote:
Will all due respect.....That is bolloxs Mr. Green
ZRX61
Victor Meldrew
PostPosted: 16:03 - 24 Nov 2008    Post subject: Reply with quote
1930 Ariel wrote:
Kawasaki's are well known for coldbloodedness on nippy mornings & the fix for the past 30 years has been putting a pilot jet in that actually works instead of the microscopic one they fit for emission tests in some markets. Wink
pixel
PostPosted: 16:40 - 24 Nov 2008    Post subject: Reply with quote
The problem is that last winter it didn’t show any symptoms alike - yes there was slight barking here and there but choke solved most of that.
So I guess spark plugs are my best bet for the problem in question.
Thanks for your reply guys,
Any more suggestions before I order a new set ? Smile
Ariel Badger
PostPosted: 19:46 - 24 Nov 2008    Post subject: Reply with quote
I agree but much of the other thread was advocating a bigger main jet. That was the bollox I refered to.
The last post was made 17 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 68.48 Kb
