| Thom |
 Thom World Chat Champion
 Posted: 18:54 - 24 Nov 2008 Post subject: Bleeding Brakes, Guide me :) |
Ok i tried to bleed my front discs on the GPX not long ago and although i used oldish brake fluid (half used botttle which had its foil seal broken for about 3months) the brake just feels really spongey and so im not sure what i should do.
It is simply just bleeding it needs as the master cylinder is mint and ive rebuilt both calipers now but how can i bleed the brakes up front, considering ive only ever successfully back bled a single disc bike.
Can anyone guide me, step by step, as to how to bleed twin discs?
cheers#  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
| Ste |
 Ste Not Work Safe
 Posted: 18:57 - 24 Nov 2008 Post subject: |
| BCF Workshop Guides & Handy Links (which is right at the top of this forum) wrote: | |
| Thom |
 Posted: 19:58 - 24 Nov 2008 Post subject: |
I forgot about that!
Cheers man! ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
| SoND |
 SoND World Chat Champion
| Thom |
 Posted: 20:31 - 24 Nov 2008 Post subject: |
Maybe i should furthur explain my confusion.
I have two front brake discs+calipers, however the hoses join half way up at a 'thing' and then its a single hose to the caliper. i cannot understand how on earth i can bleed this system.
And ive read the guides with little success  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
| SoND |
 Posted: 20:39 - 24 Nov 2008 Post subject: |
A 'thing'? Any pictures of said 'thing'?
Are you getting any pressure in the system at all? ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| Thom |
| Thom |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 21:47 - 24 Nov 2008 Post subject: |
Take cap off your fluid res, top up fluid.
Attach hose to bleed nipple on caliper, and put the end of the hose in a jar to catch the fluid.
With a 10mm spanner, undo nipple 1/4 turn, pull lever in and tighten nipple, release lever.
Keep doing that, remembering to check and top up your fluid level in the reservior.
Once you done that 4 or 5 times, close the nipple, pump the lever til hard and hold it on, then undo the nipple and tighten. If there is still air in it, repeat until its all gone.
 ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| Thom |
| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 17:24 - 25 Nov 2008 Post subject: |
If you need two hands to pull it all the way back i'd guess that is good enough, as you'll never be in a situation where you'll need to do that - at least i hope not!
It sounds like the lines are expanding, or it could be that you've used old fluid - apparently brake fluid is prone to soaking up moisture in the air left to its own devices..some people even cap the bottle in between topping up when bleeding. ____________________ A Guide To Powerbands |
| Thom |
| Mr Hammers |
 Posted: 17:44 - 25 Nov 2008 Post subject: |
So long as it stops as it should, and is impossible to pull the lever back to the bar with one hand, i can't see you''ll have a problem getting it through, tbh. ____________________ A Guide To Powerbands |
The last post was made 17 years, 311 days ago. Instead of replying here, would creating a new thread be more useful? |
