replacing steering lock
Jai466
PostPosted: 20:45 - 24 Nov 2008    Post subject: replacing steering lock Reply with quote
My CBR125 streering lock is broken, wen some idots nicked my bike, would anybody know how it would be replaced?
Thanks
Chriss
PostPosted: 20:51 - 24 Nov 2008    Post subject: Reply with quote
Normally it's a part of the lock set that locks into the head stock, so where you stick your key in will need replacing, or your frame.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Jai466
PostPosted: 20:52 - 24 Nov 2008    Post subject: Reply with quote
Thanks Chris,
would that be the ignition barrel?
alun111
PostPosted: 21:19 - 24 Nov 2008    Post subject: Reply with quote
That would be the ignition barrel.
How do you lock your steering? Through the ignition or is a seperate key used to lock the steering on the bottom yoke?
Jai466
PostPosted: 21:29 - 24 Nov 2008    Post subject: Reply with quote
I lock it via the ignition barrel... but its broke now Evil or Very Mad
alun111
PostPosted: 21:39 - 24 Nov 2008    Post subject: Reply with quote
as chriss said then... it'll be the ignition barrel or the frame. You'll need to take the ignition out to inspect the hardened pin that gets projected into the frame when the key is turned to lock the steering. Hopefully it'll just have a bent/snapped pin, then it's a new ignition. If not the hole in the frame may be dissfigured.
Chriss
PostPosted: 15:45 - 25 Nov 2008    Post subject: Reply with quote
If you're lucky, and you have all the silly pieces of plastic that come with the lock, you may be able to get an identical replacement barrel which uses the same key.
Fadel
PostPosted: 16:02 - 25 Nov 2008    Post subject: Reply with quote
When my RS got stolen, they obviously broke steering lock, it literally just pushed the frame "smooth" to get it out so when I got it back, to have a working steering lock I would of had to replace the frame.
The last post was made 17 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.32 Sec - Server Load: 2.62 - MySQL Queries: 13 - Page Size: 55.08 Kb
