Theres NO coolant in my bike, what should i do ?
Runner07
PostPosted: 17:09 - 25 Nov 2008    Post subject: Theres NO coolant in my bike, what should i do ? Reply with quote
Hi all,
I'm a little worried. I checked my coolant level today after around a year and noticed its bone dry!
Ive been to a few petrol stations just now and they had no distilled water... The bike shop is closed until next week due to referbishment also..
Is there anything i can top it up with just for now?
Any replys will be appreciated..
Keir
PostPosted: 17:11 - 25 Nov 2008    Post subject: Reply with quote
water for now, this should allow you to go further afield to get some coolant. the damage may already be done though.
Current : '08 Yamaha FZ1s
Barry_M2
PostPosted: 17:18 - 25 Nov 2008    Post subject: Re: Theres NO coolant in my bike, what should i do ? Reply with quote
Runner07 wrote:
Hi all,
Are you checking the expansion bottle or radiator?
If it was bone dry, your bike would overheat in about 3 minutes flat, and seize!
You'll probably find that its just 'very' low!
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
Runner07
PostPosted: 17:25 - 25 Nov 2008    Post subject: Re: Theres NO coolant in my bike, what should i do ? Reply with quote
Barry_MC21 wrote:
Runner07 wrote:
Hi all,
Hi, im just checking the container...
Does anyone know anywhere (petral stations etc) which sell any motorcycle coolant OR distilled water?
Mr Hammers
PostPosted: 17:40 - 25 Nov 2008    Post subject: Reply with quote
I imagine any DIY place or hardware shop would do distilled water, and forgive my ignorance, but what exactly is 'motorcycle coolant'?
A Guide To Powerbands
PostPosted: 17:47 - 25 Nov 2008    Post subject: Reply with quote
If it's completely dry then don't fill it with just water, cos over night the water will freeze and expand which won't do your cooling system much good!
Pretty much all petrol stations sell coolant, go buy some. Doesn't matter if it's motorcycle coolant or car coolant, they'll all have anti freeze in them and will be about the same anyway.
PostPosted: 17:48 - 25 Nov 2008    Post subject: Re: Theres NO coolant in my bike, what should i do ? Reply with quote
Same places that sell motorcycle petrol.
Runner07
PostPosted: 18:36 - 25 Nov 2008    Post subject: Reply with quote
Ok, so i either get normal coolant or distilled water..
If i get car antifreeze will i need to mix that with distilled water then ?
Coolant is alreadymixed right?
PostPosted: 18:45 - 25 Nov 2008    Post subject: Reply with quote
On the side of the bottle it'll have instruction which will tell you what ratio to mix it with water.
Coolant will contain anti freeze, what you buy won't be mixed with distilled water.
Just go to a petrol station and buy some coolant. Brick Wall Brick Wall
Runner07
PostPosted: 18:47 - 25 Nov 2008    Post subject: Reply with quote
Ok!
Will any coolant do, even if it says its for a car?
Because evrytime ive gone into a petrol station they only sell antifreeze for cars
PostPosted: 18:52 - 25 Nov 2008    Post subject: Reply with quote
Coolant is coolant, makes no difference if the bottle says it's for cars or bikes.
Runner07
PostPosted: 19:52 - 25 Nov 2008    Post subject: Reply with quote
Ok thanks.
I just bought a bottle of coolant. Is this okay to use?
https://img380.imageshack.us/img380/7923/image001vy1.jpg
Robby
Dirty Old Man
PostPosted: 19:59 - 25 Nov 2008    Post subject: Reply with quote
For the 5th time, yes, coolant is coolant.
I personally don't worry about distilled water. Coolant contains stuff to inhibit corrosion, so using tap water isn't a problem. Particularly if you change your coolant as often as you're meant to.
If your system is just very low, I would top up with coolant out of that bottle. If it is empty, you'll need a 50/50 mix of coolant and water.
However, if it was empty your engine would have seized, so just top it up with the bottle.
Runner07
PostPosted: 20:07 - 25 Nov 2008    Post subject: Reply with quote
Thanks for your help! Yes i cant even see a messurment when i check the container. so i'd presume its basically empty.
Ok, im going to mix it with 50% water then.
thanks
Robby
Dirty Old Man
PostPosted: 20:13 - 25 Nov 2008    Post subject: Reply with quote
Well pour some into the container and see, or drain the whole system down and start from scratch - this is what I would do.
The reason I would put neat coolant in is that if you haven't evenr checked it for a year, there is a chance that the coolant is getting old. When coolant gets old it gets less effective as anti freeze - its freezing point rises. Adding more neat coolant will lower the freezing point, however if you run the whole thing on neat coolant it will be too thick.
So, simple steps because you're probably young. Pour in some coolant until it shows at the bottom of the resevoir, then fill from there with 50/50 mix. Should give you a suitably strong mix without being neat.
That's the expansion bottle you're checking. If you undo the cap on top of the radiator is there anything in there? If there's not, try taking one of the hoses off the bottom of the radiator and see if anything comes out?
It's not going to be completely empty. How long since you last checked the coolant? As I'd be wondering where it's all gone. Confused
Baxendale
PostPosted: 20:21 - 25 Nov 2008    Post subject: Reply with quote
I've had tap water in mine since august, still no problems Very Happy Tap water is fine, but I'm gonna be dropping some coolant in mine for the winter.
Robby
Dirty Old Man
PostPosted: 21:20 - 25 Nov 2008    Post subject: Reply with quote
You run tap water with coolant, not just straight tap water. Shouldn't be running straight water of any kind, you'll only corrode your engine innards.
PostPosted: 22:02 - 25 Nov 2008    Post subject: Reply with quote
Plus there was a frost at the weekend, down to -5 or6 where I was.
If you have water in your engine without anti-freeze it will freeze and if you are lucky, only burst the radiator. Can burst the engine block.
I wouldn't be using tap water if you are in an area with hard water. Look inside your kettle. If the inside is all covered in yak, don't put your tap water in your bike. If the inside is clean, tap water should be ok.
Finglonga
PostPosted: 23:35 - 25 Nov 2008    Post subject: Reply with quote
Coolant is already pre mixed otherwise it should be called anti-freeze.
As S/W says tap water is fine as long as its soft if your mixing with anti-freeze as it will contain corrosion inhibiter's.
Andy Sez....
F.Y.Y.F.F.
Dalemac
PostPosted: 01:18 - 26 Nov 2008    Post subject: Reply with quote
dont forget be careful with coolant - its very toxic and will easily blind you if you manage to get any in your mouth. it can also smell sweet to little kids/ animals so keep it well away from them at all times.
PLus, dont forget to recycle any old coolant if you have any left.
YBR125 -> GPZ500S -> SL1000
PostPosted: 01:49 - 26 Nov 2008    Post subject: Reply with quote
In fairness, you'd have to drink a fair bit to cause a problem and it causes liver failure not blindness. It tastes sweet, not just smells sweet. As such, yes, keep it away from pets and children.
I usually wash old stuff down the drain with a bucket of water or two to dilute it beyond the point it could be harmfull.
Dalemac
PostPosted: 02:22 - 26 Nov 2008    Post subject: Reply with quote
oh ight, interesting to know. just remember a few stories where evil wives have poinsoned their husbands with coolant and went blind.
Finglonga
PostPosted: 12:44 - 26 Nov 2008    Post subject: Reply with quote
How would the wife go blind after poisoning her husband?https://img.photobucket.com/albums/v112/finglonga/Ne%20nau/ne_nau.gif
Andy Sez....
F.Y.Y.F.F.
veeeffarr
PostPosted: 12:48 - 26 Nov 2008    Post subject: Reply with quote
Don't you have to find coolant compatible with aluminium engines or am I talking bollocks? I imagine quite a few cars have alu engines now so might be a relic of the past...
The last post was made 17 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 130.11 Kb
