urgent help please. cbr 125
The Artist
PostPosted: 19:08 - 25 Nov 2008    Post subject: urgent help please. cbr 125 Reply with quote
cbr 125. 04 or 05.
Rear wheel. "grinding noise"
I take it home, have a look at it, seems bent or something. Take rear wheel off.
I pull the sprocket off with half of the cush drive stuff and all these bearings fall out, bits of broken and sheared metal. Some spacer type things and a rubber seal.
I would like to know if anyone has some sort of exploded diagram of this.
Anyone had this happen before?
It is not the wheel bearing, 99% sure its not anyway.
Can anyone explain what these parts are called techincally. I don't want to be asking for "cush drive bearing thingys"
Thanks
Keir
PostPosted: 20:45 - 25 Nov 2008    Post subject: Reply with quote
sprocket carrier bearings?
rear wheel bearings?
Current : '08 Yamaha FZ1s
geordiecbrblo...
PostPosted: 21:27 - 25 Nov 2008    Post subject: Reply with quote
^ what he said seems the most likely if it all fell out with the cush drive...
yen_powell
PostPosted: 21:36 - 25 Nov 2008    Post subject: Reply with quote
There are usually three wheel bearings, two in the hub and the third in the sprocket carrier. The one in the sprocket carrier probably has a sleeve that slides into the inside of the bearing.
The two bearings in the wheel will have a tube between them. There will be a seal on the outside two bearings that you can still see when the wheel is fitted to the bike.
XT1200Z and a DR350 in bits
geordiecbrblo...
PostPosted: 21:43 - 25 Nov 2008    Post subject: Re: urgent help please. cbr 125 Reply with quote
It is called the sprocket carrier bearing and will be a sealed bearing similar to this:
https://images.wemoto.com/bearings/ddubearing.jpg
The Artist
PostPosted: 22:17 - 25 Nov 2008    Post subject: Reply with quote
Ok thanks guys.
Yes the wheel bearings are fine. It is the sprocket carrier bearing.
It doesn't look like a bearing at the moment because it has broken and fallen apart.
The chain was loose prior to this incident aswell. I have found bits of it e.g. the balls and the centre piece with a groove round the middle for the balls to sit in.
Anyone know where I can buy one of these? Online preferably.
The owner has said she needs it on the road asap so im thinking if I can't get a bearing quick enough, buy an entire wheel and fix the broken one in the meantime.
Thanks for your help.
Keir
PostPosted: 22:25 - 25 Nov 2008    Post subject: Reply with quote
www.wemoto.com - around £4.50 + delivery
yen_powell
PostPosted: 00:02 - 26 Nov 2008    Post subject: Reply with quote
allymoss wrote:
Ok thanks guys.
Find the bit of bearing casing that has a 4 figure number stamped into it and you can get a bearing in any bike shop or bearing factor (yellow pages for one of those) with that. Ask for double shielded type.
The Artist
PostPosted: 00:09 - 26 Nov 2008    Post subject: Reply with quote
thanks so much for the help guys.
Just ordered from wemoto. Totally forgot how awesome they are.
Also ordered a clutch lever holder thing that she broke when she fell off.
Thanks very much
Karma
The last post was made 17 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 61.2 Kb
