Electricians - Wiring in flourescent lights in garage?
Barry_M2
PostPosted: 10:40 - 26 Nov 2008    Post subject: Electricians - Wiring in flourescent lights in garage? Reply with quote
Question for you electrical type people out there....
I've got x4 36w flourescent lights I'm going to put up in my garage, but as I have 4, I'm unsure how to wire them up!? Series, parallel, some other way?? Confused
Anyone knock up a quick diagram for me!?
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
PostPosted: 10:46 - 26 Nov 2008    Post subject: Re: Electricians - Wiring in flourescent lights in garage? Reply with quote
Parallel; will be the same for 98% of things like that outside a science class.
I never got around to wiring it in, but I got a IR switch that either can be set to off / IR / on. Ended up getting a switch on a multisocket by the door, so never got around to wiring it in.
What I'd really like to do is to have some kind of time delay (unfortunately my garage really isn't /that/ big to justify it Sad ) for multiple lights, ideally with an industrial 'clunk' sound as they come on; so each ones comes on in sequence as they would in a warehouse in an appropriate film Smile.
Sparks!
Sir Tart-a-lot
PostPosted: 15:57 - 26 Nov 2008    Post subject: Reply with quote
HMmm that's a bit unlike you G, giving out wrong advice!
They wire in series. From one to the next, the final light will have just one cable to it.
Here is how I would do it
So
Supply --> Switch --> Light 1 --> Light 2 --> Light 3 --> Light 4
Take supply to common side of the switch and then connect the outgoing cable to the switch live and connect neutrals together using connector block. Connect earths at switch earthing point or use connector block if there is no earth point.
Each light will have 2 cables at it except for the last light which will have one. All lights will come on when you flick the switch.
Sparks!
Sir Tart-a-lot
PostPosted: 15:59 - 26 Nov 2008    Post subject: Re: Electricians - Wiring in flourescent lights in garage? Reply with quote
For a few quid you could change the light switch for a PIR sensor, it will turn the lights on when you walk in and turn them off after X amount of time once it senses no movement.
The industrial clunk you're refering to is the sound of a contactor pulling in, which won't be neccessary unless you've got a lot of lights or really high powered lights etc... for your average fluro's in a garage it's really not neccessary Smile
Fawbish
PostPosted: 16:11 - 26 Nov 2008    Post subject: Reply with quote
Sparks, is it necessary to put a CBR on its back wheel and go around in circles?
I reckon it wouldnt be very expensive to wire up (relatively simply aswell) an oldschool timer/relay set up for each fluorescent light, wired in parallel, with a 1 second, 2, second, 3 second timer respectively.
Also, take a feed off each relay to a simple small speaker in the wall that has a "CLUNK" noise to play.
supply* ----->switch** -----> Time Delay/Relay (1s) --->Light 1/BOOM
supply* ----->switch** -----> Time Delay/Relay (2s)--->Light 2/BOOM
supply* ----->switch** -----> Time Delay/Relay (3s) --->Light 3/BOOM
supply* ----->switch** -----> Time Delay/Relay (4s)--->Light 4/BOOM
supply* ----->switch** -----> Time Delay/Relay (5s)--->Light 5/BOOM
* One single supply for all 5 lights
** A single switch for all 5 lights
A little complex for a simple lighting system, but it could be done. Laughing
PostPosted: 16:55 - 26 Nov 2008    Post subject: Reply with quote
Interesting, though it seems there is a bit of argument about this… still my bad, obviously posted from a rather limited point of experience rather than real knowledge (I’ve got them running in parallel fine in my garage fine.)
Surely running in parallel is not really different to having two separate ones plugged into a multi-socket extension that’s plugged in to turn it on?
And, incidentally, you’ll note that I mentioned already have an IR switch. I’m aware the ‘clunk’ isn’t needed, I just like the aesthetic… I’d probably do it with some small sound effects system Smile. I suspect half the time you seen it in films it's done with a sound effect anyway!
Matthie
PostPosted: 16:59 - 26 Nov 2008    Post subject: Reply with quote
How many plants you growing?
Barry_M2
PostPosted: 17:01 - 26 Nov 2008    Post subject: Reply with quote
I get this bit....
So
But not this bit....
I'm not quite sure what you mean when you say 'Each light will have 2 cables at it except for the last light which will have one.'?
Barry_M2
PostPosted: 17:07 - 26 Nov 2008    Post subject: Reply with quote
Do you mean like this?.......
Fawbish
PostPosted: 17:15 - 26 Nov 2008    Post subject: Reply with quote
No Im pretty sure he means each light will have two cables (ie 2 twins (grey sheathing covering 1 brown and 1 blue)) one going in, and one going out.
That last fluorescent light will have one twin cable to it (ie 1 brown and 1 blue in grey sheathing)
supply > switch > light <> light <> light <> light
where <> is one grey cable in, and one grey cable out.
and one grey cable contains 1 live and one neutral.
I think.
EDIT: something like this attachment, I think?
Barry_M2
PostPosted: 17:21 - 26 Nov 2008    Post subject: Reply with quote
Yeah, I think I get it, although each light fitting will also need an earth too, surely?
Fawbish
PostPosted: 17:24 - 26 Nov 2008    Post subject: Reply with quote
Meh, Its ages since I've done it, but im not sure if fluorescents need an earth.
If they do, just use twin and earth cable.
Sparks, any light on using earths with fluro? (pun intended)
Fawbish
PostPosted: 17:32 - 26 Nov 2008    Post subject: Reply with quote
I remember something about a general rule that over about 24", or in unfavourable conditions (areas that could get damp, like a garage), you should ground it out.
But realistically, I reckon Sparks (being a proper, legit sparky an all) will most likely ground most situations anyways.
SoulRider
PostPosted: 17:33 - 26 Nov 2008    Post subject: Reply with quote
Mains cable is on AC so should be wired in series (only knew as my garage has recently been done with lights). one cable into the light and one out apart from last light which will just have the one cable in.
My Bike Pics
Barry_M2
PostPosted: 17:35 - 26 Nov 2008    Post subject: Reply with quote
Yeah, I think I'll ground it anyway as it a 3 core cable.
Sparks!
Sir Tart-a-lot
PostPosted: 17:51 - 26 Nov 2008    Post subject: Reply with quote
Yes it needs an earth connected at each light and at the switch.
The PVC sheathed cable is called Twin & Earth, it has a brown and blue sheathed core and an un-sheathed earth. When you buy the cable, ask for some earth sleeving as well (green and yellow) and place that over the bare core and connect to the earth terminal of each light.
At the switch if its plastic you'll need to use a connector block (you also need some connector block for the neutrals) so also ask for some 5 Amp connector block when you get the cable. (or get that and the sleeving from Homebase/B&Q etc) If you are using metal clad switch boxes etc then there will be a specific earth terminal on it.
Hope that helps.
Barry_M2
PostPosted: 17:56 - 26 Nov 2008    Post subject: Reply with quote
Thats great, cheers Sparks.
Got plenty of connector blocks, loads of cable too. It is a plastic weatherproof switch I'll be using, I'm sure there is an earth point in there!? Its a two-way with one spare switch, the other I used for the outside flood lights.
Right, looks like my weekend is going to be busy.... Making up another door for shed, move existing door, make up a frame for that one, putting up the lights. And finally clearing out the shed!!! Sad
The last post was made 17 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 99.38 Kb
