sprocket carrier
The Artist
PostPosted: 15:28 - 27 Nov 2008    Post subject: sprocket carrier Reply with quote
ok, new bearing came for my sprocket carrier today. cbr 125 04.
I fit it and replace chain etc and go along and it make a weird grinding noise. I can't tell if it is the sprocket carrier or chain hitting something or anything else.
does someone have a picture of how one of these should be put together. I want to make sure I have done it right. Thanks
Order of items on the bike from the middle going to left hand side if you know what I mean.
wheel - wheel bearing - small spacer - sprocket carrier - sprocket carrier bearing - rubber seal on top of bearing - big spacer - swingarm.
Thanks
rotax81
PostPosted: 15:42 - 27 Nov 2008    Post subject: Reply with quote
get it up on a stand/paddock stand, its the only way to check it.
remove the chain and eliminate that first.
are you sure the chain is not too tight?
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
The Artist
PostPosted: 16:01 - 27 Nov 2008    Post subject: Reply with quote
hi, chain is set perfectly to specs.
I found an exploded diagram
https://www.mmra.org.uk/marci/cbr125/cbrtech/pages/f13rearwheel.htm
just no list to go with it.
im guessing here
23 = wheel bearing
10 = seal
1= cush drive rubbers
4=?
7= sprocket carrier
22= bearing
20?
5= spacer
18= washer
3= axel
what the hell is 4 and 20.
I have something that looks like 4 but has no ridges, it is just a cylinder with a hole in the middle. currently being used as a spacer on the outside.
help! ta
sickpup
Old Timer
PostPosted: 22:08 - 27 Nov 2008    Post subject: Reply with quote
They are the two spacers you forgot to fit. Shocked
The Artist
PostPosted: 01:16 - 28 Nov 2008    Post subject: Reply with quote
ok turns out i had the wrong diagram. some parts that just dont exist are on there.
but
i sorted the problem! I didn't realise there were 2 spacers on the brake side meaning it was making a different grinding noise to the one before! I had put the spare spacer in a gap that doesnt need it!
Doh!
Ah well, sorted now with only minor scratching to the big plate that holds the calliper.
The last post was made 17 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 44.21 Kb
