pillion questions...
steppen22
PostPosted: 02:32 - 30 Nov 2008    Post subject: pillion questions... Reply with quote
This seems to be a topic never covered. However, it could well be the difference btwn passing and failing.
What exactly are the pillion questions at the end of the test and how difficult are these to answer?
I would have thought that carrying a passenger would affect: suspension, balance at low speeds, braking distances, weave and wobble, the angle of the lights beam, the capacity to lean into bends, tyre pressure requirements, mpg, etc.
The advice to a passanger would be: shut up, sit still, lean with me, don't interfere with the controls, sit nice and tight with your hands round my waist and your chest pressed pleasingly against my back if you're a pretty female but get your fucking hands on the luggage rack if you're a bloke, don't indicate for me, don't offer advice on when the road is clear, etc, etc.
Am I missing something here? I'm not going to be asked realy awkward questions like, if your passanger weighs 130 kg, what pressure should your tyres be at? etc etc.
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
nick606
PostPosted: 03:55 - 30 Nov 2008    Post subject: Reply with quote
thats it. All they will ask is how a pillion effects your riding / your bike.
NinjaLee
PostPosted: 04:06 - 30 Nov 2008    Post subject: Reply with quote
I didn't get asked any pillion questions on my test, the examiner must have forgotten.
Most of what you have put is right, but also carrying a pillion affects acceleration times, (slower) and your mirrors would need to be adjusted too.
The questions are (If i remember them right Laughing) : What advice would you give to a novice?
For that question break it down into two parts. Part one is before they get on the bike, and part two is when they are on the bike.
Part one: Make sure they have a helmet and that the strap is done up properly, advise them on reflective, protective clothing, tell them where to put their feet and where to hold onto. Tell them not to get onto the bike until you've told them to do so.
Part two: So on the bike now. Tell them not to signal for you, not to fidget. Tell them to lean in with you on the corners (stay in line with your body) and tell them to communicate before you get off the bike, keep feet on footrests at all times.
Next question is what are the legal requirements for carrying a pillion passenger?
So they need their own seat and footrests. Obviously helmet etc.
Last question is: How would carrying a pillion passenger affect the handling of the machine, and what would you need to adjust?
So, adjust suspension, mirrors, lights and tyre pressure. Slower accelerating time, longer braking distance etc.
I think thats everything Laughing Maybe you'll be lucky and not get asked the questions like i did Thumbs Up
(I'm sure i've worded the questions correctly, im sure someone will correct me if i'm wrong.)
Current bike: 2006 zx636 C6F Smile
Previous bike: 2000 zx6r J1, 1990 cbr400rr nc29
Restriction ended: 17th november 2010
Danny77
PostPosted: 08:46 - 30 Nov 2008    Post subject: Reply with quote
I got told by an instructor that they can be used as a kind of tie breaker if your ride has been 50/50 pass or fail and the right or wrong answers can mean it goes one way or the other.
Affects carrying a pillion has on bike handling
slower acceration, longer stoping distances, less stable at low speeds, front end will be lighter
what you should tell a pillion.
only get on and off the bike when told by you and to lean with the bike in turns.
legal requirements for carrying a pillion.
There feet must reach the passenger footrest and they must wear a correctly fitted safety helmet with meets current safety standards.
Adjustments you may need to make to the bike for carryinga pillion.
Rear tyre pressure and rear suspension, mirrors and headlight as the front of the bike will be slightly higher.
Just off the top off my head i'm sure all the show me tell me questions can be found on the dsa website.
deanoet
PostPosted: 22:30 - 30 Nov 2008    Post subject: Reply with quote
they ask 2 questions before you start the test
A wrong answer counts as a minor I believe and are added up with the rest at the end of the test
Or to put it another way: learn the questions and answers, they arent hard
I am pretty sure the questions are listed on the DSA website somewhere
As a side note if the examiner doesnt tell you otherwise ask before you do something to the bike he / she didnt directly ask you to do
IE
If they ask you to show that the horn is working
Point to the horn button and say you would press that, the horn wont work unless the ignition is on, is it okay to switch the ignition on?
They will either say, go ahead, or no, that is okay
tutton
PostPosted: 22:54 - 30 Nov 2008    Post subject: Reply with quote
^ thats a bit dim to be honest tho isnt it.
if he asks to hear the horn function hes already gave you permission to do whatever you need to do to make the horn function..
Nicky-Jano
PostPosted: 13:32 - 01 Dec 2008    Post subject: Reply with quote
I was asked two questions about pillions.
One: How should a pillion sit, the instructor literaly meant should he/she sit facing forwards or backwards or sidesaddle etc Laughing .
Two: What should I do to the bike, if anything, when taking a pillion.
Obvious answer being adjust suspension and tyre air pressure to the recommended setting in your manual or on swingarm.
Kal
PostPosted: 13:49 - 01 Dec 2008    Post subject: Reply with quote
It's how the question is phrased, I can't remember it off hand but there is a trick in it. It's best to side on dim and go through everything like a civil servant being paid overtime....
Kal...
multijoy
PostPosted: 15:49 - 01 Dec 2008    Post subject: Reply with quote
I'm not sure there's enough hours in the day to do that!
And I should know!
MattHirst
PostPosted: 16:09 - 01 Dec 2008    Post subject: Reply with quote
Well not quite, i was asked that question on my test and he said 'Show me how you would operate the horn'
He didn't say use the horn, or show that it is working (thats not exactly a question is it). I just said turn the ignition on and press the horn button (pointing to it), but only test that it is working off the road.
Also, they WON'T ask you questions that could intefere with other road users (ie, having to actually operate the horn) if the test starts on the road. I mean some test centres don't have off road parking, some start actually on the road. Fortunatley mine started in the test centre carpark Smile
tutton
PostPosted: 17:48 - 01 Dec 2008    Post subject: Reply with quote
As you may well know theres 2 types of questions - Show me or Tell me.
The horn question is a show me, not a tell me.
thats what my instructor taught me.
MattHirst
PostPosted: 18:14 - 01 Dec 2008    Post subject: Reply with quote
Yes i know, its like 'show me where you would check your oil level'
So he will ask you to show him how the horn operates, but listen carefully as he may OR may not ask you to actually do it, he may just ask you to show him how you would do it.
A tell me question is like the pillion ones where you wouldn't actually touch/pointing to anything on the bike, you will just tell him what you would do/how you would do it.
tutton
PostPosted: 18:19 - 01 Dec 2008    Post subject: Reply with quote
"Show me how you would check that the horn is working (off road only)
Check is carried out by using control (turn on engine if necessary)."
Quoted from internet,
and on my test i got asked to check its working, so i turned the cg engine on as you need to.
Plus my instructors sheet with the questions thats in my hand says to show its working not just show how.
deanoet
PostPosted: 18:51 - 01 Dec 2008    Post subject: Reply with quote
Just what I was told Very Happy
I was told to not do anything without his / her say so
Diff test centres may have different ettiquette for these sorts of things
neil.
PostPosted: 22:42 - 01 Dec 2008    Post subject: Reply with quote
The two show/tell me questions are safety questions asked at the beginning of the test, whereas the question about carrying a pillion passenger are asked after the ride when you're back in the test centre, just before the debrief.
Arrow Here are the safety questions they ask at the beginning.
Arrow Here are the pillion questions.
The last post was made 17 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 91.44 Kb
