Please could you help me about my nrg
Jordan Mc3
PostPosted: 13:54 - 01 Dec 2008    Post subject: Please could you help me about my nrg Reply with quote
hi there i have a piaggio nrg mc3 jordan ed & its done about 17000 km & iv had an gianelli exhaust upjetted to 0.75mm i belive & had the rollers on about 4-5months ago all done by a piaggio specialist & recently its performance and acceleration has dropped and will top out at 40 pushing it when it used to cruise around at 50-55 quite easily
please could someone help i always change the oil and use fully synthetic putoline oil (recomended)
Thankyou
Regards Conor
Current Ride - Piaggio Nrg Mc3 Jordan Edition (For Sale)
Next Ride - Derbi 125 GPR Racing
rotax81
PostPosted: 14:02 - 01 Dec 2008    Post subject: Reply with quote
a new spark plug is a good start.
has the engine ever been serviced, as in 'cleaned out of all its carbon deposits'
could be a new set of rings needed.
many things could be the prob.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Jordan Mc3
PostPosted: 14:14 - 01 Dec 2008    Post subject: Reply with quote
Thankyou will try sparkplug tonight & as for cleaning it out il book it in for a service & rings???
and as for the it could be many things....thats what im worried about Sad
thanks
tutton
PostPosted: 21:46 - 01 Dec 2008    Post subject: Reply with quote
As rotax has said the rings usually start going out
or the systems get bunged up with carbon.
Peticularlly exhaust system, which is vital for 2 strokes with backpressure nd all.
stevo as b4
PostPosted: 23:07 - 01 Dec 2008    Post subject: Reply with quote
I'd still check the belt and rollers first, as they don't last that long on a tuned twist and go from my experience. If the engine doesn't sound right or rev as well as it used to then a compression check is a good idea, but i doubt that the performance would suddenly drop off like that from engine wear alone. Unless you have been unlucky and snapped a ring etc?
chillpill
PostPosted: 19:58 - 02 Dec 2008    Post subject: Reply with quote
^^^^ Thumbs Up
yeah the rollers develop flatspots over time wich lowers performance
clean the air filter , check the belt for wear, you could clean the carb , de-coke the exhasut as rotax said and just give it a generall service ,
when was the last time it had a new piston or rings ? 17000km is a fair bit for a 50
Jordan Mc3
PostPosted: 12:29 - 09 Dec 2008    Post subject: Reply with quote
Hi there everyone thanks for help but i done what anyone should do.......take it to a scooter garage and let them fix it properly
basicly the gianelli was comming apart which is now changed new rollers and racing belt and a good service and elbow grease
£170 in total but its worth it Very Happy
thanks for everyones help
happy scootering
chillpill
PostPosted: 16:48 - 09 Dec 2008    Post subject: Reply with quote
you got ripped , i would of got it done for you for a quater of that and in a few hours
i think your local as well arent you Confused
Jordan Mc3
PostPosted: 14:57 - 16 Dec 2008    Post subject: Reply with quote
Sad i think that now bike still running shit on top end just accelerating better after it stalls kinda & my mates have bloody vivacitys n stuff that are doing about 60 and mines got all tht done and barely hitting 50 Sad
also where you from mate ?
might pop in
chillpill
PostPosted: 17:27 - 16 Dec 2008    Post subject: Reply with quote
north london
if you payed for a garage to fix it atleast make them do it properly Confused
Jordan Mc3
PostPosted: 17:29 - 16 Dec 2008    Post subject: Reply with quote
im taking it back tomorow they didnt even put the mallosi belt & rollers in like they said just a standard belt n stock rollers Sad
stevo as b4
PostPosted: 23:51 - 17 Dec 2008    Post subject: Reply with quote
don't think the Malossi belt is too important or even worth fitting with a std variator TBH. The rollers however should have been changed to the type and weight reccomended by the manufacturer of the race pipe that you are using. The clutch springs may also need to be changed to suit some pipe's which actually make alot less power than std before the power band, which is why you sometimes need to get the clutch to bite at higher rpm than std for some race pipes to work properly and not bog down off the line.
The last post was made 17 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 72.18 Kb
