| tutton |
 tutton World Chat Champion
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 14:36 - 01 Dec 2008 Post subject: |
Give your carburettor a few lights taps with the handle of a screwdriver. It might be a sticky carb float. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| tutton |
 Posted: 14:53 - 01 Dec 2008 Post subject: |
Not sure on the bike. However at a guess it is something with a vacuum fuel tap.
With these petrol only flows when the engine is running. Hence when you start it petrol can cause the float bowl to over flow.
If the float bowl is overflowing it suggests a worn needle valve, some dirt in the needle valve, sticking floats or damaged carb floats. Dirt in the needle valve is the most likely. Tapping the float bowl (as above) can sometimes dislodge this.
Next quick attempt. Drain the float bowl fully. Then turn the petrol on (either onto prime, or crank the engine over). With luck the dirt will be flushed out by the rush of petrol from the tank with the floats at their low point.
| ZaphodBeeble |
 Posted: 14:54 - 01 Dec 2008 Post subject: |
You may have some dirt lodged in the float needle then. Not much you can do short of stripping the float bowl off and checking it. Have you recently run out of fuel or run the tank almost empty? It could have dragged some crap into the float needle. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| tutton |
 Posted: 14:55 - 01 Dec 2008 Post subject: |
Not recently ran it down
to drain float boal its the screw above the overflow right.
ill go do that now
keep your eyes peeled for a reply within 5 mins  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| tutton |
 Posted: 15:06 - 01 Dec 2008 Post subject: |
Afraid it sounds like you will have to do the job properly (or at least, less of a bodge way).
What bike is it? Can you get the float bowl off quickly? If so whip the float bowl off (you may be able to slacken the clamps on the carb and rotate it to make it easier to get at the float bowl). Find the needle valve (it will be near the pivot for the floats). If poss remove the floats and remove the needle. Blow through the needle valve orifice (maybe use carb cleaner if available). Check the needle is clean and undamaged. Reassemble.
Also possible that the pipe inside the float bowl that is the overflow has snapped off.
| tutton |
| ms51ves3 |
 ms51ves3 Super Spammer
| tutton |
 Posted: 18:58 - 02 Dec 2008 Post subject: |
Didnt get there in time.
I had to go find a mechanics who had a float bar, so took me a bit of a trek.
by which time it was already 3:30 and appointment was 3:00.
O well  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
The last post was made 17 years, 283 days ago. Instead of replying here, would creating a new thread be more useful? |
