zxr 400 1994 starting problem
David-lee
PostPosted: 07:21 - 02 Dec 2008    Post subject: zxr 400 1994 starting problem Reply with quote
hi all
i havnt had my bike long infact just 3 weeks,the bike has been fine starting so far but the last few days have been a nightmare and cant start it.
The bike has had a new battery and been fully charged.Yesterday i tryed starting it again after taking battery off and fully charged it but wouldnt start again.
What other things could be causing problme when starting?
Thanks
PostPosted: 10:14 - 02 Dec 2008    Post subject: Reply with quote
Got fuel?
Got Spark?
Got compression?
These are the three things you need for it to start. Check the fuel's getting through first, it's easiest. Then check the plugs.
Coxyzxr
PostPosted: 11:43 - 02 Dec 2008    Post subject: Re: zxr 400 1994 starting problem Reply with quote
David-lee wrote:
hi all
Thanks
Hi.
Is it turning over at all?
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Smooth
PostPosted: 12:20 - 02 Dec 2008    Post subject: Reply with quote
Check for corrosion in the main (30A) fuse area -confusingly, its' probably on the starter relay, not in the fuse box.
That can cause cause poor charging, starting and running.
TDM850
David-lee
PostPosted: 21:43 - 02 Dec 2008    Post subject: Reply with quote
The bike is trying to start and makes a strong noise.Have plenty fuel and im gonna check spark plugs 2moro
Thanks
David-lee
PostPosted: 21:45 - 02 Dec 2008    Post subject: Reply with quote
how do i queck fuel flow and also how do a check the fuse area?
Thanks
PostPosted: 15:14 - 03 Dec 2008    Post subject: Reply with quote
Crank it over then take the plugs out and see if they are wet.
PostPosted: 15:15 - 03 Dec 2008    Post subject: Reply with quote
Find your fuse box and check all the fuses are good.
Smooth
PostPosted: 15:25 - 03 Dec 2008    Post subject: Reply with quote
The Main Fuse on Kawasakis is on the starter relay (not in the fuse box), which is down below the right hand side of the seat on the ones I've seen. It is wired to the battery and Regulator/rectifier.
TDM850
David-lee
PostPosted: 17:42 - 03 Dec 2008    Post subject: Reply with quote
Hi again i have changed all spark plugs today and then bike fired up first time yayyy
but.... the old spark plugs were in a state,they were very black and olily which i think is a bad sign but im not sure???
Thanks
Renton
PostPosted: 17:52 - 03 Dec 2008    Post subject: Reply with quote
I believe this would be because your fuel to air mixture is running too rich.
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
David-lee
PostPosted: 19:49 - 03 Dec 2008    Post subject: Reply with quote
Hi again
Shall i check the air filter chalky?also when i fitted everything bk to the bike today im sure there was a washer missing that goes on the fuel tap,its a very thin washer.The fuel tap hasnt been leaking since i fitted it bk on but im a little worried,if its not leaking then its ok?
Thanks all
David-lee
PostPosted: 19:50 - 03 Dec 2008    Post subject: Reply with quote
Hi again
Thanks all
David-lee
PostPosted: 19:51 - 03 Dec 2008    Post subject: Reply with quote
Hi again
Thanks all
Renton
PostPosted: 20:11 - 03 Dec 2008    Post subject: Reply with quote
I was thinking about adjusting a screw under the carbs (not sure of the technical term).
I know it needs to be screwed all the way in, and then turned back out a certain amount of times. I don't know how many turns out it should be (sorry), but I'm sure someone else might know.
David-lee
PostPosted: 23:09 - 03 Dec 2008    Post subject: Reply with quote
chalky can i ask why u think its the air filter causing this oily black problem on plugs?can u explain?wanta better understanding
Thanks
PostPosted: 09:27 - 04 Dec 2008    Post subject: Reply with quote
Thanks
If the air filters really blocked then you won't get enough air in to mix with the same amount of fuel causing seriously rich running which will foul your plugs.
The other thing it could be is your piston rings, but since it start up after you changed the plugs it's unlikely.
Check your fuelling system so find that washer to help decrease the amount of fuel going through.
Renton
PostPosted: 11:49 - 04 Dec 2008    Post subject: Reply with quote
Thanks
^^ What Big_Ham said matey Thumbs Up
pixel
PostPosted: 23:20 - 04 Dec 2008    Post subject: Reply with quote
hello everyone - got similar problem (zxr400), after changing the spark plugs it took me almost two hours messing with the wiring and spark coils (cleaning it all up) to start the bike.
Now it backfires on low rew... not only from the exhaust but from carbs as well Sad it produces fuel feedback from the carb air intake tubes when I try to accelerate).
Don’t know what to do, the only thing i did was changing the plugs (it was running normally with the old once so i guess the coils are ok or am i wrong)!
one more thing to mention, the spark plugs are wet (not all though)
What can be the problem here?
Will appreciate any help…
pixel
PostPosted: 00:33 - 05 Dec 2008    Post subject: Reply with quote
solved the problem - plug caps were misplaced!
The last post was made 17 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 103.96 Kb
