| lukamon |
 lukamon World Chat Champion
 Posted: 01:33 - 30 Nov 2008 Post subject: overheating - thermostat or radiator? *cage thread* |
hey, took the car into the garage today to have the thermostat replaced, as it's been not heating up at all for a while. the garage is about 200m from my house. took it for a drive this evening and after about 5 miles it started to over heat
was able too keep it at a reasonable temp by having the heater on full blast, and when i had a look later, there is _no_ pressure in the expansion bottle and the water in there is cold. also, the water going in th top of the radiator is hot but the hose to the pump the other side is stone cold
oh, the thermostat + gaskets were supplied by me, as i was going to do it myself but didnt have time, so it had been sitting around for a while.
any help appreciated, cheers. ____________________ killa wrote: Im an ass man myself |
| rotax81 |
 rotax81 Nearly there...
| Robby |
 Robby Dirty Old Man
| lukamon |
| MattEMulsion |
 MattEMulsion World Chat Champion
| Ben. |
 Ben. World Chat Champion
 Posted: 12:56 - 30 Nov 2008 Post subject: |
blocked hose? flush the system out as best as you can, try and make sure no hoses are blocked, if it still does it you know its probably the stat. ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| Stelmer |
 Stelmer World Chat Champion
| Robby |
 Robby Dirty Old Man
| NiteMare |
 NiteMare Spanner Monkey
| lukamon |
| Finglonga |
 Finglonga World Chat Champion
| Rockhopper |
 Rockhopper Trackday Trickster
| stevo as b4 |
 Posted: 22:58 - 01 Dec 2008 Post subject: |
I agree that the stat is the most likely culprit, and it's fairly easy on some cars to get to and remove for testing and replacement. If the Rad is fine, and the hoses are all in good condition, then i have to say id be thinking about the water pump next.
Having said that, most car's that overheat with a failed water pump, usually do it at high speed like barrelling down the motorway at high cruise speeds, when the cooling system has to work harder to get rid of the heat from the engine.
I have some sort of cooling system problem on my Astra, in that the temp needle never seems to move off the cold mark, and yet there is plenty of coolant in the system, and the cabin does still get warm eventually. It's too cold to look at it now before the spring, so i'll wait till then to service the cooling system and change the stat. |
| Ichy |
 Ichy World Chat Champion
| stevo as b4 |
| NiteMare |
| lydanial |
 lydanial Brolly Dolly
| lukamon |
 Posted: 18:40 - 02 Dec 2008 Post subject: |
sigh, the bloke at the garage now thinks it uiasnt the stat it might be a head gasket i doubt it. maybe the system was getting up to temp and took a while to overheat because a teeny bit of water was pissing through the hole in the stat? (there is one drilled in the flange) ____________________ killa wrote: Im an ass man myself |
| Ichy |
| NiteMare |
| lukamon |
 Posted: 19:55 - 02 Dec 2008 Post subject: |
when has any car ever had a waterpump driven by the cambelt?
anyway, its been taken out of the hands of the spannermonkey. headgasket my arse. when i say overheting,i meant it was running at 106 - 115 deg instead of 90.
oh well, have to do it myself i suppose. the stat is beind the alternator meaning you have to take out that and the aux. belt to get to it. sigh.
no water loss and no bubbles coming through the header tank. will change the oil at weekend to check for white crap aswell.
the courtesy car (a fiat difficulttospell) is rather fun though  ____________________ killa wrote: Im an ass man myself |
| NiteMare |
| Finglonga |
| Robby |
 Robby Dirty Old Man
| lukamon |
The last post was made 17 years, 311 days ago. Instead of replying here, would creating a new thread be more useful? |
