1999 MITO cant find neutral?
spitfire123
PostPosted: 20:47 - 02 Dec 2008    Post subject: 1999 MITO cant find neutral? Reply with quote
hi all,
i have a cagiva mito and it just cant seem to find neutral(AT ALL)!
it used to be hard finding it...but now there is no neutral Mad
i know there is a star shape gear selector on 4-stroker(well on my old 140 thumper there was)? maby this is to rounded and worn? ive seen people take it out and "dremel it out" pointyer them-selfes?
if so is this start on the left or right of the engine caseing?
cheers Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
PostPosted: 20:55 - 02 Dec 2008    Post subject: Reply with quote
A mito's a two stroke, and most modern "proper" bikes use selector forks to select the gears.
Checked your chain tension/ lubed it recently?
It's not a selector fork problem if you can't get neutral if all the other gears select fine.
spitfire123
PostPosted: 21:00 - 02 Dec 2008    Post subject: Reply with quote
chain is okay,
and no its not greased at all as i just put it on( and tentiond it woth 1cm of play)?
does that matter?
im only going up and down the garden with it untill its totaly ready, as in ive done a whole rebuild of the bike Laughing
cheers Thumbs Up
MaybeGuy
PostPosted: 21:02 - 02 Dec 2008    Post subject: Reply with quote
sometimes you have to buy them seperately.
tried ebay?
(tighten your clutch cable, can you find it in neutral?)
spitfire123
PostPosted: 21:04 - 02 Dec 2008    Post subject: Reply with quote
tried ebay?
sorry?
buy what seporatly?
MaybeGuy
PostPosted: 21:06 - 02 Dec 2008    Post subject: Reply with quote
neutral gears Rolling Eyes
gahhhd
PostPosted: 21:21 - 02 Dec 2008    Post subject: Reply with quote
1cm is wayy too tight for most bikes, although I don't know the exact value for the mito off the top of my head usually a ball park figure is 3-4 cm for the road.
It may also need to get properly warm. Some bikes can be tricky to get into neutral until they warm up properly.
spitfire123
PostPosted: 21:24 - 02 Dec 2008    Post subject: Reply with quote
hi,
oh okay ill loosen it a bit more then.
also the bike was more or less cold....i left it idoling for more or less 15 mins and it wasnt even on the 40 degree mark so still cold....
could this be my problem?
i think the mits running heat is around 60ish
PostPosted: 21:27 - 02 Dec 2008    Post subject: Reply with quote
If you leave a highly strung two stroke like that idling for ages it's a great way to foul your plug.
Idling it doesn't get it warm.
I guess it goes into neutral fine when it's not running? Have you tried selecting neutral while you're still rolling along. My GSXR used to be hard to find neutral in when it was hot when stationary. Was fine if you clicked it into neutral when it was rolling though.
MaybeGuy
considering the mitos chain is STUPIDLY long id say yeah, way too tight. up it to about 1", and hope you havnt bent your output shaft.
PostPosted: 21:28 - 02 Dec 2008    Post subject: Reply with quote
Or fucked the output shaft's bearing.
spitfire123
PostPosted: 21:31 - 02 Dec 2008    Post subject: Reply with quote
ive just checked and its more along the lines of 3cm...so i should be okay Smile
spitfire123
and no when i mov ethe bike along it still dosent want to go in to netural....
the neural llight does come on but it just slips out of it and turns off...
and it comes on between 1st and neutral gear?
Alex-RS
PostPosted: 21:58 - 02 Dec 2008    Post subject: Reply with quote
Last gearbox oil change?
binge
Emo Kiddy
PostPosted: 22:45 - 02 Dec 2008    Post subject: Reply with quote
Last owner would be a better question.
Its a 9 year old 125 2 stroke supersports bike. Its clearly been owned by a 17 year old teenager who knows bugger all about bikes. They all have. And its probably been spanked everywhere since the day it was built. Laughing
Ariel Badger
PostPosted: 22:52 - 02 Dec 2008    Post subject: Reply with quote
Is the clutch adjusted correctly? Dragging clutches can give a lot of neutral problems.
kev...
PostPosted: 22:58 - 02 Dec 2008    Post subject: Reply with quote
they are a pain to get into netural at the best of times i just click mine in as i am slowing down.
once your at a standstill you will struggle lol.
oh change your gear oil 15w 50 0.8L from empty.
as for it not warming up mito's have a stupidly large radiator as there designed for hotter climates.
most owners gaffertape between 1/2 - 2/3rds up during the colder months because you will not get it up too temp otherwise.
mines taped up 2/3rds at the moment it now sits at 60 degrees which is about right for mito's.
hope this helps kev. Thumbs Up
Tricolor Fan
PostPosted: 23:14 - 02 Dec 2008    Post subject: Reply with quote
What he said is what I would say.
That is all!
Give me ambiguity or give me something else.
PeterNSR
PostPosted: 23:35 - 02 Dec 2008    Post subject: Reply with quote
give it a few revs to find neutral m8
or get fixed Mr. Green
Current: Honda NSR 125 Smile
My bike
spitfire123
PostPosted: 13:57 - 03 Dec 2008    Post subject: Reply with quote
2 days ago Laughing
spitfire123
PostPosted: 13:58 - 03 Dec 2008    Post subject: Reply with quote
[quote="kev..."]
quote]
hi mate,
not sure what it had in it before but the bloke at the bike shop said put morris 10w 40 in it?
is that okay or do i need the 15w 50?
spitfire123
PostPosted: 13:59 - 03 Dec 2008    Post subject: Reply with quote
no its not....the biting point is basicly at the end of the lever.....yes the cable is slightly streached Laughing
spitfire123
PostPosted: 14:01 - 03 Dec 2008    Post subject: Reply with quote
this is in bvery nice condition acturly and just had a rebuild....and internaly looks very clean.
was dynod in to the 30hps
so its on form,lol
spitfire123
PostPosted: 23:16 - 03 Dec 2008    Post subject: Reply with quote
bump!
Alex-RS
PostPosted: 23:19 - 03 Dec 2008    Post subject: Reply with quote
spitfire123 wrote:
bump!
Take out and inspect your clutch if you can.
The last post was made 17 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 131.31 Kb
