Some advice needed
Alex-RS
PostPosted: 22:09 - 03 Dec 2008    Post subject: Some advice needed Reply with quote
I'm not riding the RS through the winter, want to avoid adding miles to it before I sell it next April. Anyway, it's just going to be sitting in the drive through the week, and i'll take it out once every weekend to keep it going. Is there anything I should be doing with it being this cold and it only being used at the weekend. Any reason to maybe start it once in the middle of the week or anything along those lines. Suppose i'm asking, will it be ok to just leave it there doing nothing inbetween weekend rides.
Forgive my ignorance Very Happy
carlnicholson...
PostPosted: 22:17 - 03 Dec 2008    Post subject: Reply with quote
Give it a good, thorough wash, remove the battery and optimate it if you have one, give it a good spray with either ACF 50 or Scottoil F365, cover it up and don't forget to move it forward every couple of weeks or so to prevent the tyres getting a flat spot.
There is porbably more you could do but the above should prevent it from getting covered with corrosion and ensure it fires up straight away when the time comes. Thumbs Up
:EDIT: Should add, make sure you change all the oils come ressurection time, the condensation over winter may well have added a bit of water to all the lubes! Suppose being a stroker, you only have gear oil to worry about on that one. Thumbs Up
"THOSE WHO RISK NOTHING, DO NOTHING, ACHIEVE NOTHING, BECOME NOTHING."
Itchy
PostPosted: 22:32 - 03 Dec 2008    Post subject: Reply with quote
I would probably ensure the tyres are up to correct PSI , to prevent degradation and rotate them every now and again so the contact patch changes.
Also if you can wrap the tyres as UV light destroys them and causes them to degrade sort of like rubber bands left in the sunlight.
PostPosted: 22:38 - 03 Dec 2008    Post subject: Reply with quote
Don't worry about it. Just make sure the antifreeze is decent.
Itchy
PostPosted: 22:40 - 03 Dec 2008    Post subject: Reply with quote
Infact how do you maintain the bikes that are stuck right at the back of your shed? ,
PostPosted: 22:56 - 03 Dec 2008    Post subject: Reply with quote
Put it this way, I don't worry about starting them every week.
This year I have probably done most of my pleasure miles on a 50.
carlnicholson...
PostPosted: 23:58 - 03 Dec 2008    Post subject: Reply with quote
If the above gentleman manages to keep his personal collection in good order then none of us have any excuses for maintaining our own!!
The Tot
PostPosted: 00:10 - 04 Dec 2008    Post subject: Reply with quote
If you don't want to put on any miles, just remove the speedo cable Wink . Keep using it and it'll be fine although I reckon it'll be fine with the occasional start up anyway.
Keep the bike covered even if it's in a garage. Get some SDoc 100 bike cleaner and rinse the bike down with that just to wash the salt off.
Never argue with autism
tr8theshape
PostPosted: 00:16 - 04 Dec 2008    Post subject: Reply with quote
Will just say that with older cars, the accepted wisdom was that if you were going to start them, make sure that you got them up to temperature and took them for a bit of a run. Not just fire them up for a minute or two as that does more harm than good. Neutral
I am rough on my machines and just neglect them over winter and sort it out in the summer Wink
Regards, Dave.
iooi
PostPosted: 10:29 - 04 Dec 2008    Post subject: Re: Some advice needed Reply with quote
Why not just lay it up for the winter then and not bother. To get any real use of of the weekend running you need to do 30+ miles to get everything nice and warm and burn any condensation out of the oil etc.
So you options are simply just carry on as normal and forget about the miles, or lay it up for the winter.
If you carry on as normal how many miles would you rack up ? Bet even 5K extra miles would not affect the price by as much as a bike that has rusted up.
PostPosted: 12:02 - 04 Dec 2008    Post subject: Reply with quote
Except that whether you take it for a run or not, you have still done the "damage" from starting it (although taking it for a good run should at least get rid of any build up of water). In many ways you are best not starting a 4 stroke as doing so contaminates the oil and it becomes slightly corrosive.
Whether it is of any real consequence for short times off the road is another question.
s44678
Guest
PostPosted: 10:46 - 05 Dec 2008    Post subject: Reply with quote
All this talk of antifreeze has got me worried now.
I assume it has, but how do I know my bike's got it in?
PostPosted: 10:53 - 05 Dec 2008    Post subject: Reply with quote
Your bike's coolant reservoir will have an blue or orange solution in it.
PostPosted: 11:51 - 05 Dec 2008    Post subject: Reply with quote
You can get a small tester for the stuff. Lets you know what state it is in.
Itchy
PostPosted: 13:46 - 05 Dec 2008    Post subject: Reply with quote
hey my stuff is green ,
PostPosted: 13:56 - 05 Dec 2008    Post subject: Reply with quote
Doesn't the blue stuff turn green when it starts to get old?
The last post was made 17 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 100.22 Kb
