SV650s refusing to start :(
onfire
PostPosted: 18:35 - 05 Dec 2008    Post subject: SV650s refusing to start :( Reply with quote
Hi all, yet another problem Sad
I tried to start my bike on Monday (i think) when it first started to snow, just thought it was because it was very cold.
It turned over a couple of times, then started to make this buzz. Sounded like something electrical was going on, hard to describe apart from saying "DZZZZ DZZZZ DZZZZ".
Still not starting even though the weather isnt as bad as Monday, any one have any idea what this could be at all?
My bike: Honda CG 125cc Blue
CBT - Passed 12/01/08 - Bike - Yamaha YBR 125
Theroy - Passed - DAS - 21/07/08 - Bike - ER-5
Nb
PostPosted: 18:40 - 05 Dec 2008    Post subject: Reply with quote
Battery flat?
PostPosted: 18:48 - 05 Dec 2008    Post subject: Reply with quote
Nb wrote:
Battery flat?
Agreed. Sounds like a flat battery. 'tis the season for them.
When a battery is too flat to turn over the starter motor, it makes the solenoid click rapidly on and off resulting in a buzzing noise.
onfire
PostPosted: 18:50 - 05 Dec 2008    Post subject: Reply with quote
hmm i would agree but can still turn lights on. Does starting the engine require a lot more power than having the lights on for a short period of time?
PostPosted: 19:23 - 05 Dec 2008    Post subject: Reply with quote
Yes. Lots more.
If it isn't too icey, you could always try bump-starting it.
Flat battery is the simplest and most obvious explanation, as such, it should be the first one you eliminate.
onfire
PostPosted: 19:31 - 05 Dec 2008    Post subject: Reply with quote
Ok cheers guys, have a charger of sort due to the fitted alarm. There is a cable under the seat to drip charge it or something. Will try that.
Now on to the CG Razz
PostPosted: 19:42 - 05 Dec 2008    Post subject: Reply with quote
The presence of an alarm makes it even more likely to be the battery.
Keir
PostPosted: 11:04 - 08 Dec 2008    Post subject: Reply with quote
that will be for an optimate or similar. I keep my bike on this at all times when its in the garage so i never have this problem. Thumbs Up
Current : '08 Yamaha FZ1s
the grim reaper
PostPosted: 13:52 - 08 Dec 2008    Post subject: Reply with quote
Until you go away for a few days and your battery dies.
Optimates charge a battery slowly to about 14.2V, which causes the plates to coat in sulphate. This eventually kills the battery but you don't know about it until you don't have the charger available.
Grim
The last post was made 17 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 62.73 Kb
