4 months of change
PostPosted: 02:10 - 08 Dec 2008    Post subject: Reply with quote
Over inflate the tires buy an optimate and cover all the metal in wd40.
Run it really low on petrol then poor 5 litres of fresh petrol in a day or so before you want to use it.
If you have paddock stands use them.
alun111
PostPosted: 02:48 - 08 Dec 2008    Post subject: Reply with quote
Why do you suggest 5 litres of petrol? I'd personally suggest either brimming the tank with petrol or using an additive of some sort to stop the tank from rusting.
Drain the float bowls of the carbs, to stop them icking up. I'd also buy an exhaust bung to stop condensation from getting in to the engine. Also - a teaspoon of oil down each cylinder and then putting the plugs back in would be a good idea to make sure the engine remains free.
I'd look into a way of making sure the clutch doesn't stick on as well.
Also... be prepared to service your brakes as they may stick on when you first press the levers.
PostPosted: 09:55 - 08 Dec 2008    Post subject: Re: 4 months of change Reply with quote
4 months? Remember to take any stuff off it when you've used it as a shelf, before you next ride it, sorted Thumbs Up.
Though from the question, I presume you were actually treating it as a magpie might her nest; wanting to cover it in shiny baubles. In which case, my advice is still relevant Smile.
PostPosted: 10:35 - 08 Dec 2008    Post subject: Reply with quote
It'll be reet for four months, may need a bump start when you come to reuse it though.
Bendy
Mrs Sensible
PostPosted: 11:03 - 08 Dec 2008    Post subject: Reply with quote
If it's inside I wouldn't bother doing anything particularly. Optimate on the battery if you've got one, otherwise just let it be.
I'd only worry about all this 'laying up' stuff if it's gonna be outside getting wet, then I'd try and prevent it getting wet. Smile
My bikes have often sat for more than 4 months without being used, never bothers them in the slightest.
salty21
PostPosted: 19:23 - 08 Dec 2008    Post subject: Reply with quote
i would have thought someone would have said "rat it" by now Confused , but looks like im the first so.........."rat it" Wink
Whosthedaddy
PostPosted: 20:44 - 08 Dec 2008    Post subject: Reply with quote
Rear sets
Pazzo levers
Double bubble screen
Braided lines
HH sintered pads
Wavy discs
Single seat conversion
Undertray
Hugger (CF)
Front mudguard (CF)
Race fuel cap
lllN30lll style numberplate
PostPosted: 21:46 - 08 Dec 2008    Post subject: Reply with quote
big bore kit. Wink
Sell it and buy a quicker bike in all honesty.
Otherwise exhaust can, fork re-valve, new shock. Thumbs Up
Mil17b
PostPosted: 21:55 - 08 Dec 2008    Post subject: Reply with quote
Just a word of advice. Don't put WD40 on the bike's chain.
fatsamurai
PostPosted: 22:31 - 08 Dec 2008    Post subject: Reply with quote
It's a myth, or at the very least unproven that WD40 destroys chains. I certainly wouldn't use it as the sole chain lubricant but i'd be happy to use to clean it or stop it from rusting in storage.
https://www.yamahafz1oa.com/forum/showthread.php?t=8987&highlight=WD-40+letter
Hyosung GT125 Thumbs Up [SOLD] -> Suzuki GSX 750W Thumbs Up [SOLD] -> SV650S Sick [Crashed] -> FZ6 Cool
m0l0t0v
PostPosted: 23:03 - 08 Dec 2008    Post subject: Reply with quote
If it is 100% completely and utterly stock (and I mean brake pads, and tyres) then definately change them. Especially the tyres. Brake pads are a must as well and braided brake lines will improve the braking a lot.
Get a new exhaust, or even a full system (not that expensive if I remember from Scorpion) as the stock exhaust is absolute pure shite. Laughing And get an undertray and/or tail tidy. And a seat cowl if you can find a /nice/ one as the ones I've seen are fugly to shit.
PostPosted: 00:22 - 09 Dec 2008    Post subject: Reply with quote
Keep the tyres off the ground. A full tank of fuel to reduce condensation. Remove spark plugs and spray some lube in, refit plugs.
Plug end cans.
Either use a optimate or just disconnect if its lead/acid type.
As Gordon Ramsey would say " Bike tucked away for winter...DONE"
As for mods...Nitros Baby
PostPosted: 00:58 - 09 Dec 2008    Post subject: Reply with quote
I thought as it was a pentrating spray it gets in the orings and destroys the grease in there.
As to the why 5 litres of petrol I was thinking abit to much there, I said 5 litres purely because that is the size of my jerry can. Laughing
Mil17b
PostPosted: 16:35 - 09 Dec 2008    Post subject: Reply with quote
I have been told that WD40 eats other lubricants and grease.
alun111
PostPosted: 17:34 - 09 Dec 2008    Post subject: Reply with quote
Considering o-rings are made of RUBBER and WD40 perishes rubber after some time I wouldn't use it on a chain.
PostPosted: 19:15 - 09 Dec 2008    Post subject: Reply with quote
It may not perish all rubber.
The fact that it's often used to clean oil and grease off things is a very good reason not to use it, to my mind!
It is a lubricant and will keep it lubricated if used enough; but it'll dry out a lot quicker than other choices, leaving you with nothing.
bazza
PostPosted: 19:32 - 09 Dec 2008    Post subject: Reply with quote
I've drawn up a detailed list of everything you'll need:
1. A pair.
Then you won't have to stop riding.
Moonie
PostPosted: 19:40 - 09 Dec 2008    Post subject: Reply with quote
Why aren't you riding?
Also did you mean modification or storage in the OP?
Whosthedaddy
PostPosted: 19:41 - 09 Dec 2008    Post subject: Reply with quote
Mod as he had another thread about storage.
The last post was made 17 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 113.22 Kb
