CG rear brake pedal
drewpy
PostPosted: 22:25 - 08 Dec 2008    Post subject: CG rear brake pedal Reply with quote
Hi again,
first problem, got a 92 cg 125K and bought a new rear brake pedal, I matched it up with the new one and it profiles spot on.
come to fit the pedal and the brake rod end of the pedal fouls the swing arm pivot. So I used kinetic force to clear the majority of the swing arm pivot.
with me so far?....good!
tried to connect up the rod to the pedal and there's no chance, too far away and if it did fit, it would hit the swing arm pivot before the brake worked.
I must have fitted it wrong but can't seem to work out what Embarassed
can anyone post a pikkie as reference or put me on the right track. the pedal came off a 90 brazillian model
thanks
drewps
doin' up wifes CG125; XS400; xs400 flat tracker build
drewpy
PostPosted: 19:50 - 21 Dec 2008    Post subject: update Reply with quote
well I ended up shortening the lever and drilling a new hole for the brake rod, couldn't see how it would work other wise
The last post was made 17 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 31.01 Kb
