 drewpy L Plate Warrior
 Posted: 22:25 - 08 Dec 2008 Post subject: CG rear brake pedal |
Hi again,
first problem, got a 92 cg 125K and bought a new rear brake pedal, I matched it up with the new one and it profiles spot on.
come to fit the pedal and the brake rod end of the pedal fouls the swing arm pivot. So I used kinetic force to clear the majority of the swing arm pivot.
with me so far?....good!
tried to connect up the rod to the pedal and there's no chance, too far away and if it did fit, it would hit the swing arm pivot before the brake worked.
I must have fitted it wrong but can't seem to work out what
can anyone post a pikkie as reference or put me on the right track. the pedal came off a 90 brazillian model
thanks
drewps ____________________ doin' up wifes CG125; XS400; xs400 flat tracker build |
