What the buggery?
Omar15
PostPosted: 23:09 - 09 Dec 2008    Post subject: What the buggery? Reply with quote
Bit of a problem - not sure whats going on...
I was riding my bike back from climbing yesterday and it was pissing down with rain - everything was fine for the first 5 or 10 minutes, but then I was just pulling away in a traffic jam when the revs went right down. I pushed the bike to the side of the road where it stalled.
I started it again and tried to give it some throttle in neutral, but it wasn't really having it - revs would build up and then go right down again.
To cut a long story short, it eventually got going again and riding it today, everything was fine. Better even.
I also noticed the engine sounded like it was making a sort of knocking sound...the only conclusion I can come to is that water was getting in the air filter or something?
I've got a Yamaha Virago 125 btw, if that makes any difference. And the oil was changed the day before.
Omar
yankeedoodle
PostPosted: 23:35 - 09 Dec 2008    Post subject: Reply with quote
could be an electrical problem
check spark plug(s) and HT lead(s) to make sure theres no water.try spraying a bit of WD40 in these areas to displace any water and see how that works
Bandit 600
doggone
PostPosted: 01:27 - 10 Dec 2008    Post subject: Reply with quote
Electrical so not major.
HT leads leaking juice sounds feasible, could be an ignition coil on the way out.
Sometimes they behave strange on & off for a while before giving up completely.
yankeedoodle
PostPosted: 13:41 - 10 Dec 2008    Post subject: Reply with quote
+1 my bike acted very strangely, and it was very unpredictable.replacing the coil did the trick
Bandit 600
Omar15
PostPosted: 20:07 - 10 Dec 2008    Post subject: Reply with quote
I think it must be water getting into the spark plugs as it only happened once and while it was pissing down - it was dry today and everything was perfect.
yankeedoodle
PostPosted: 20:42 - 10 Dec 2008    Post subject: Reply with quote
sounds about right mate. I believe it was actually water getting into my spark plug etc that caused the damage to my coils.
try and avoid leaving the bike standing outiside while its raining
if you are riding in the rain, the water is less likely to get to your spark plug in mass volume but carry some wd40 with you and spray it around the plug before the weather gets heavy
Bandit 600
The last post was made 17 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 47.78 Kb
