| CaNsA |
 CaNsA Super Spammer
| robbieguy2003 |
 robbieguy2003 World Chat Champion
| bikedemon99 |
 bikedemon99 Spanner Monkey
| Itchy |
 Itchy Super Spammer
 Posted: 23:17 - 11 Dec 2008 Post subject: |
yes you can sort this IIRC correctly the CLR125 is a twin pot sliding front caliper....
I think I know what has happened though , in that the person who fir them did not clean the pistons up before fitting the new pads.....
you need:
A length of plastic tubing (to bleed the brakes)...
some brake fluid
I reckon a 12 spanner,
8 spanner for the bleed nipple
and a set of allen keys ,
Undo pad pin , and plug,
undo the caliper off the fork,
then pump the brake, the pistons should come out, try to get them to come out at the same rate so you can get your thumb in and pull the other one out..
Clean it up , wash it let it dry and use a plastic ruler to clear up any jagged bits on the piston, get some bog roll, and wipe the inside of the piston cylinder (take the seal out for best results and clean that) , try not to get any bog roll stuck in there.
pop it back in both pistons Sickpup recommends you put some brake fluid in the cylinders before hand, then bleed the brakes...
2 hour job ... don't get brake fluid in your eye though make you blind....
if you were closer I'd pop round to fix it , but I'm not so you'll have to have a crack yourself..
The alternative is to ride it carefully , with masses of front obs as you won't be able to stop quickly .... but you risk warping your front disc (an expensive part) , and use your gears to slow down. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| sickpup |
 sickpup Old Timer
| truslack |
 truslack World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 09:44 - 12 Dec 2008 Post subject: |
red rubber grease them? , the motorfactor I bought some off was surprised that somebody under 50 knew what that was. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 19:41 - 12 Dec 2008 Post subject: |
Had the same thing with my bike last week. New pads and discs means the pistons are pushed further into the calipers than normal, so the cru that has built up on them gets pushed into the caliper and makes them stick.
Mine weren't too bad, they wre just dragging a bit. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| CaNsA |
 CaNsA Super Spammer
| Thom |
 Thom World Chat Champion
| Ben. |
 Ben. World Chat Champion
| craigs23 |
 craigs23 Mr Muscle
| sickpup |
 sickpup Old Timer
| craigs23 |
 craigs23 Mr Muscle
| Kickstart |
 Kickstart The Oracle
| smegbrains |
 smegbrains Scooby Slapper
| the grim reaper |
 the grim reaper World Chat Champion
The last post was made 17 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
