220mph Busa Vid
Bike Chat Forums Index -> General Bike Videos Goto page 1, 2  Next
 Topic moved: from General Bike Chat to by TiN (2 May 2004 - 07:42)
Dup
PostPosted: 03:44 - 02 May 2004    Post subject: 220mph Busa Vid Reply with quote
Probably been posted before no doubt... But you gotta love it!
https://www.mccallcolors.com/video/busa.wmv
Ian (GPX)
PostPosted: 05:50 - 02 May 2004    Post subject: Reply with quote
Mad ... got to be mad ...... Shocked Confused
PostPosted: 09:49 - 02 May 2004    Post subject: Reply with quote
Can you say 'indicated' and 'downgeared'? That definitely doesn't look like 220mph, it doesn't even look like what an indicated 220mph would look like.
When you downgear a modern bike it means that the speedo over reads a fair bit. Judging by the speed the speedo whizzed around the dial later on as well it would suggest that it wasn't getting that fast.
Luke_Retrofly
Silly Lesbian
PostPosted: 10:01 - 02 May 2004    Post subject: Reply with quote
Don't look like 220 MPH at all, look at the lines doubt he was doing 180, looks to me its downgeared to f**k.
Luke
RSixer03
PostPosted: 16:09 - 02 May 2004    Post subject: Not MPH? Reply with quote
Shocked unless my eyes are decieving me it has KM/H on that speedometer
"If everything seems under control, you're just not going fast enough."
Mario Andretti.
Ian (GPX)
PostPosted: 18:18 - 02 May 2004    Post subject: Reply with quote
If you look at the speedo and the rpm's it's reaching 70mph in 1st gear before he / she changes gear Shocked Exclamation Confused
Dr Nick
PostPosted: 18:23 - 02 May 2004    Post subject: Reply with quote
So...., ive had 65mph out of first on my bike.
is that it
craigT19
Jolly Green Giant
PostPosted: 20:55 - 02 May 2004    Post subject: Reply with quote
that vids so fake, the bike goes faster than 220mph, as the spedo hits the end stop, and the revs keep on going also.
just before the end of the movie theres a junction on the right side, at over 220mph, that would flash by soo fast, but it doesnt.
i would estimate that bike was doing no more than 130-150mph
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Mr C
PostPosted: 00:01 - 03 May 2004    Post subject: Reply with quote
mine does that too Wink
187.3bhp = 201mph
Mr C
PostPosted: 00:07 - 03 May 2004    Post subject: Reply with quote
doesn't look fast does it
I may be wrong but that could be SuperKhaos's turbo busa - there's no boost gauge in the shot but look/listen to how it takes off in first once the rpms are up and it's on boost, and I may be kidding myself, it may be wind noise but there is a whistle and the front wheel doesn't come down until 4th gear - under hard acceleration, that's not a balanced wheelie, that's power - more power than a stock busa makes
if it is a turbo then 220 mph is easily within it's grasp - although unless there's a yellow box fitted then that ole Suzuki speedo is gonna be 20-30mph out at that speed
still, you gotta love 200mph
on the public highway Shocked
187.3bhp = 201mph
Mr C
PostPosted: 00:29 - 03 May 2004    Post subject: Reply with quote
confirmed from elsewhere, so the bike is not geared for top speed - no doubt it COULD do over 200 - just apparently wasn't in that clip Wink
yep, thats superkaoss with his rather short gearing, from about 2 years ago??
he has a 180 speedo, with 220 clock faces and I think it was 16/43 gearing if my memory serves me correctly. so in fact at redline he was really only doing about 165 ish....
still a good video though
187.3bhp = 201mph
bikedudextrm
PostPosted: 01:45 - 03 May 2004    Post subject: Reply with quote
I downloaded it from somehwhere else some time ago and it was listed as a fairly modified busa.
Dup
PostPosted: 00:07 - 04 May 2004    Post subject: Reply with quote
Busas turbo boost gauge is either to the bottom right of the clocks, or just right of the tank in the fairing pointing upwards.
Claud 14.7 to 1
PostPosted: 01:21 - 10 May 2004    Post subject: Reply with quote
You cant hear the dump valve, i recon its NA. When i saw that vid a while back, i also didnt think it was that fast...still dont. It is fast, ill give it that. Fast enough.
Mr C
PostPosted: 01:25 - 10 May 2004    Post subject: Reply with quote
it is a turbo, the man has been ideitified, trust me - his name is Kevin
it's wrongly geared and not going 220mph - although it probably could
187.3bhp = 201mph
Dr Nick
PostPosted: 12:37 - 10 May 2004    Post subject: Reply with quote
I don't think any Turbo's come fitted with Dumpvalves, there just an extra, only really for noise difference.
is that it
craigT19
Jolly Green Giant
PostPosted: 13:55 - 10 May 2004    Post subject: Reply with quote
turbos do use dumpvavles, turbos build up the pressure inside the engine, the dump valve lets that pressure out when you push the clutch in so the engine doesnt blow sky high.
dont know about bikes tho Question
i know some cars dont use them because the back pressure going back when the throttle is released can cause the turbo to stall...os stutter etc
Dr Nick
PostPosted: 17:27 - 10 May 2004    Post subject: Reply with quote
i meant come with a turbo as standard, sorry. Aftermarket
is that it
Claud 14.7 to 1
PostPosted: 20:25 - 10 May 2004    Post subject: Reply with quote
All turbo applications must have a dump valve. You get the recirculating dump valves, generally make no noise. Or the bad aftermarket ones which vent the excess boost straight to the atmosphere. Laughing
Susuki make a turbo Busa from the factory right??? It could well be turbo in that case. It seems quite smooth, ie no lag. If it was stock turbo bike, than it wouldnt have a dump valve that "sounded".
I have another vid with a turbod busa, but this one is completely aftermarket. Its certainly more erratic when its on boost, but also devastatingly fast.
Mr C
PostPosted: 00:43 - 12 May 2004    Post subject: Reply with quote
err no they don't
AND IT IS A TURBO - IT BELONGS TO KEVIN AT SUPERKAOS
trust me
there is a top speed event at RAF Woodbridge this weekend
we are expecting 14 turbo busas and 3 turbo zx12rs and one supercharged zx12r
should be an interesting weekend
187.3bhp = 201mph
Claud 14.7 to 1
PostPosted: 08:42 - 12 May 2004    Post subject: Reply with quote
OK,OK i give in, i know nothing about hayabusas
That weekend sounds mad! Thumbs Up Mr. Green Thumbs Up
Ninja
Caption Abuser
PostPosted: 11:35 - 12 May 2004    Post subject: Reply with quote
numpties the lot of you - obviously it was short geared! - look at the way it apparently accelerated from 150-220mph . . . nothing short of 600bhp or a solid fuel rocket attached to each side would've given that sort of performance Laughing Thumbs Up
James
4 wheels transport the Body ... 2 wheels transport the SOUL
Mr C
PostPosted: 13:32 - 12 May 2004    Post subject: Reply with quote
definitely short geared
but we WILL have genuine 220mph this weekend Cool
187.3bhp = 201mph
bikedudextrm
PostPosted: 14:55 - 12 May 2004    Post subject: Reply with quote
Yup all turbos have a blow off valve Laughing to release the built up pressure, i take it this is the same as dump valve.
Slavo
PostPosted: 18:29 - 12 May 2004    Post subject: Reply with quote
If you got mcn today, there is featured a road legal busa capable of 240 mph (in the best conditions).....
The last post was made 22 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.77 - MySQL Queries: 16 - Page Size: 124.89 Kb
