wiring diagram for fog lights
squishio
PostPosted: 21:15 - 13 Dec 2008    Post subject: wiring diagram for fog lights Reply with quote
Hi All
I am going to be fitting hella micro DE fog lights to my bike tomorrow.
Just need someone to confirm my wiring.
see below paint diagram...
https://w4.bikepics.com/pics/2008%5C12%5C13%5Cbikepics-1508613-full.jpg
does that look correct?
I want the lights to only be turnonable when the ignition is on hence taking the 12v feed for the relay from the headlights.
thanks a lot,
Rich
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
Finglonga
PostPosted: 21:28 - 13 Dec 2008    Post subject: Reply with quote
You need to put a fuse in the feed between battery and relay as well, just in case. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
PostPosted: 21:40 - 13 Dec 2008    Post subject: Reply with quote
Can't remember where I got this piccy from, but it has a bit more detail on the relay and the aforementioned fuseholder Smile
squishio
PostPosted: 22:01 - 13 Dec 2008    Post subject: Reply with quote
cheers guys.
have got an inline fuse ready to go now. thanks finlonga
great diagram v. helpfull
thanks a lot! Thumbs Up
PostPosted: 22:26 - 13 Dec 2008    Post subject: Reply with quote
If you take the feed from the headlight you might make the foglights flash on/off if you switch between dip and full beam. Take the feed from the sidelight if you want the foglights to only work if the lights are on or from the feed to the rear break light switch if you want the foglights to work at any time the ignition is on.
Finglonga
PostPosted: 23:31 - 13 Dec 2008    Post subject: Reply with quote
You wouldn't need fog lights on with the main beam anyway, also saves the alternator if it is struggling with the extra load. Wink
Andy Sez....
F.Y.Y.F.F.
squishio
PostPosted: 23:32 - 13 Dec 2008    Post subject: Reply with quote
good point about the high beam thing.
Will wire to the 'position light' as you cant turn that off.
thanks geri
Im-a-Ridah
PostPosted: 01:23 - 14 Dec 2008    Post subject: Reply with quote
thanks geri
Why do you want fog lights on at all times?
PostPosted: 08:52 - 14 Dec 2008    Post subject: Reply with quote
thanks geri
He doesn't, if you look at his wiring diagram there's a switch in it. You're only supposed to display fog light if visibility is less than 100yds. Any other time is risking 3 points.
Peirre oBollox
PostPosted: 10:23 - 14 Dec 2008    Post subject: Reply with quote
I`d check that the alternator can kick out enough power before fitting the lights. Otherwise you are gonna cause yourself some major problems if it doesn`t
NiteMare
PostPosted: 13:38 - 14 Dec 2008    Post subject: Reply with quote
if they are rear fog lights (red) then just fit led bulbs, the current draw is so low as to not matter ...
if you are fitting driving/fog lights to the front as a pair with 55watt bulbs i'd make them switchable so they aren't on all the time, only when needed to allow your battery time to recover from the start and lighting drain...
also if you haven't already got one i'd get a charger you can plug in at night if you intend to use them all the time...
i fitted an extra pair of lights on my Goldwing (bates with dip/main) fully relayed and fused but also with a switch so they could be turned off to give the battery chance to recover when they weren't needed, put the switch in series with the relay feed so that minimal current is drawn thru it you only want the current going thru the relay(s)
https://i259.photobucket.com/albums/hh311/NiteMare_08/my%20Goldwing/100-0003.jpg
it ain't broke...
i ain't fixed it enough
Peirre oBollox
PostPosted: 13:46 - 15 Dec 2008    Post subject: Reply with quote
its not the load on the battery I`d be worried about, its the load on the alternator and the OEM wiring from it, you could possible fry the alternator & reg/rec drawing too much load from it, & you don`t want to suddenly find out the wires are overloading, overheating, melting, shorting out, and leaving you stranded, or setting the bike on fire senarios I`m thinking about
Finglonga
PostPosted: 14:03 - 15 Dec 2008    Post subject: Reply with quote
Hella DE fog lights are for the front like these (the lower set) . . .
https://img.photobucket.com/albums/v112/finglonga/DSCF1296.jpg
Andy Sez....
F.Y.Y.F.F.
PostPosted: 14:05 - 15 Dec 2008    Post subject: Reply with quote
Fitting LEDs in all the lights other than the headlights ought to free up sufficient amperage to run a set of fogs quite happily.
The way it's been drawn there is with the new lamps hard-wired to the battery through a relay so the wiring is protected by a fuse.
NiteMare
PostPosted: 15:51 - 15 Dec 2008    Post subject: Reply with quote
if the battery is small (unlike a goldwing) the start drain on it can be quite heavy, then running with the foglights on immediately will be giving the alternator no chance (or very little) to catch up and replenish the battery...
that is what i meant in my previous post...
if you're worried about the wiring/alternator catching fire/stranding you then the first thing i'd do is check all charging circuit joints and ensure they're clean and making a good connection ...
bad connections generate heat and put un-necessary stress on wires and charging components...
check the wires from your alternator to the reg/rec, often the plug is overlooked and steadily cooks itself resulting in a fried alternator on older bikes...
as already said elsewhere, feed the foglights via relays and a fuse directly from your battery that will protect older harnesses from excessive load and just switch the relays using the pilot light switch (i'd still include an isolating switch)
it ain't broke...
NSR Mick
PostPosted: 16:11 - 15 Dec 2008    Post subject: Reply with quote
When is it ever foggy enough to justify fog lights?
PostPosted: 16:19 - 15 Dec 2008    Post subject: Reply with quote
Don't know, I can think of at least a couple of times in the last 20 years Wink .
frez
PostPosted: 16:23 - 15 Dec 2008    Post subject: Reply with quote
Every day judging by some of the idiots on my way to and from work.
PostPosted: 16:51 - 15 Dec 2008    Post subject: Reply with quote
See those ones? They are half blanked off.
If you take the back off them, you'll see a curved metal plate held in with two screws that is blanking off half the reflector.
You can work out the rest...
map
Mr Calendar
PostPosted: 16:55 - 15 Dec 2008    Post subject: Reply with quote
Rather than fog lights might be worth using the micro driving lights (as seen on chav cars).
Offers a bit more flexibility than just fogs.
Also if you're fitting matching rear fogs then the following regulations come into force...
a) have an illuminated switch or separate tell-tale bulb to warn the operator that the fogs are in operation,
b) be mounted a minimum distance of 100mm from the brake lights, and
c) be no lower than 250mm and no higher than 1000mm from ground level.
It might be worth checking but I think for the front fogs they can be no higher than 1 meter and no lower than 400mm from the road.
Schedule 11 Part 1 of the Road Vehicles Lighting Regulations 1989
Finglonga
PostPosted: 17:09 - 15 Dec 2008    Post subject: Reply with quote
After that you can also convert them to HID without much grief. Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 117.73 Kb
