| squishio |
 squishio Spanner Monkey
 Posted: 21:15 - 13 Dec 2008 Post subject: wiring diagram for fog lights |
Hi All
I am going to be fitting hella micro DE fog lights to my bike tomorrow.
Just need someone to confirm my wiring.
see below paint diagram...
https://w4.bikepics.com/pics/2008%5C12%5C13%5Cbikepics-1508613-full.jpg
does that look correct?
I want the lights to only be turnonable when the ignition is on hence taking the 12v feed for the relay from the headlights.
thanks a lot,
Rich ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250 |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 21:28 - 13 Dec 2008 Post subject: |
You need to put a fuse in the feed between battery and relay as well, just in case.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 21:40 - 13 Dec 2008 Post subject: |
Can't remember where I got this piccy from, but it has a bit more detail on the relay and the aforementioned fuseholder  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| squishio |
 Posted: 22:01 - 13 Dec 2008 Post subject: |
cheers guys.
have got an inline fuse ready to go now. thanks finlonga
great diagram v. helpfull
thanks a lot!  ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
 Posted: 22:26 - 13 Dec 2008 Post subject: |
If you take the feed from the headlight you might make the foglights flash on/off if you switch between dip and full beam. Take the feed from the sidelight if you want the foglights to only work if the lights are on or from the feed to the rear break light switch if you want the foglights to work at any time the ignition is on. ____________________ a.k.a 'Geri'
| Finglonga |
| squishio |
 Posted: 23:32 - 13 Dec 2008 Post subject: |
good point about the high beam thing.
Will wire to the 'position light' as you cant turn that off.
thanks geri ____________________ Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| Peirre oBollox |
 Peirre oBollox Could Be A Chat Bot
| NiteMare |
 NiteMare Spanner Monkey
| Peirre oBollox |
 Posted: 13:46 - 15 Dec 2008 Post subject: |
| NiteMare wrote: | if they are rear fog lights (red) then just fit led bulbs, the current draw is so low as to not matter ...
if you are fitting driving/fog lights to the front as a pair with 55watt bulbs i'd make them switchable so they aren't on all the time, only when needed to allow your battery time to recover from the start and lighting drain...
its not the load on the battery I`d be worried about, its the load on the alternator and the OEM wiring from it, you could possible fry the alternator & reg/rec drawing too much load from it, & you don`t want to suddenly find out the wires are overloading, overheating, melting, shorting out, and leaving you stranded, or setting the bike on fire senarios I`m thinking about ____________________ I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter. |
| Finglonga |
 Posted: 14:05 - 15 Dec 2008 Post subject: |
| Peirre o`Bollox wrote: |
its not the load on the battery I`d be worried about, its the load on the alternator and the OEM wiring from it, you could possible fry the alternator & reg/rec drawing too much load from it, & you don`t want to suddenly find out the wires are overloading, overheating, melting, shorting out, and leaving you stranded, or setting the bike on fire senarios I`m thinking about |
Fitting LEDs in all the lights other than the headlights ought to free up sufficient amperage to run a set of fogs quite happily.
The way it's been drawn there is with the new lamps hard-wired to the battery through a relay so the wiring is protected by a fuse. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| NiteMare |
| NSR Mick |
 NSR Mick World Chat Champion
| frez |
 frez Nova Slayer
 Posted: 16:51 - 15 Dec 2008 Post subject: |
See those ones? They are half blanked off.
If you take the back off them, you'll see a curved metal plate held in with two screws that is blanking off half the reflector.
You can work out the rest... ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| map |
 map Mr Calendar
| Finglonga |
The last post was made 17 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
