Soon To Have An Rs50
Bagger's
PostPosted: 11:51 - 02 May 2004    Post subject: Soon To Have An Rs50 Reply with quote
Hello,my dad agreed to buy me a bike worth £1000 for my 16'th
so i am loooking towards an second hand rs50.
Have i chose the right bike?
Are there major differances?
Also i would like a bike that i can add aftermarket parts.
Thankyou
Bagger's
Every One Likes A Good Ride.
PostPosted: 12:17 - 02 May 2004    Post subject: Reply with quote
Good luck finding a half decent one. Too many are wrecks (after all they are peoples first bikes, and they learn the effect of no maintenance on them Laughing ).
I went looking for one for a neighbour. Finding one for under £1000 is difficult. For £1200 to £1500 you should be able to find a fairly new one.
The engines seem fairly reliable. Build quality is not that great (but plenty don't last long enough for that to be a problem).
Watch out for things that have been wrecked by the previous owner. For example, wrecked chains and sprockets, broken fairing mounting tabs, the wrong type of bolt forced in, blown fork seals, bald tyres.
Also the choke levers on the carb seem quite prone to becoming loose. Without the choke they are a pig to start (although will bump start OK).
Don't buy a new one as you will loose loads of money.
The one we found he paid £750 for. It is cosmetically tatty but mechanically all there. Replaced the clutch lever, clutch cable, speedo cable and a plastic drive gear for the rev counter (after replacing the rev counter cable then finding the rev counter still did not work Rolling Eyes ). Hopefully at that kind of price he can sell it for not that much of a loss.
There are big differences in the models of RS50. The number of gears varies, older ones had a single sided swinging arm, some have pillion foot rests.
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
madmurphy
PostPosted: 13:33 - 02 May 2004    Post subject: Reply with quote
i should be getting a gpr50 soon. i went through a long stage of deciding which bike to choose out of the aprillia rs50, motorhispania rx50 and a rieju rs2. think ive made the right choice.
Carl
PostPosted: 14:31 - 02 May 2004    Post subject: Reply with quote
Heres mine
https://www.crystalentertainments.co.uk/carl/DSCF0040.JPG
https://www.crystalentertainments.co.uk/carl/DSCF0037.JPG
https://www.crystalentertainments.co.uk/carl/DSCF0011.JPG
my dad rides the 900 fireblade, and he said it was VERY impresive for a 50
spec:
Aprilia RS50 2002 GP-1 : Malossi 68cc MHR Race Aluminum Cylinder - Malossi 21mm Dell-Orto Carb - MetraKit Competition Exhaust
Thanks for looking Smile
Bagger's
PostPosted: 16:19 - 02 May 2004    Post subject: Hi Reply with quote
Hi,what year modal is that as i like it allot.
What are the main things i should look for in buying?
thanks
Carl
PostPosted: 18:10 - 02 May 2004    Post subject: Reply with quote
2002 gp-1
well ride it, listen for clangs and bangs, the suspension, also the expansion chamber. take a look at the bike its self, was it look after, is it dirty?
a well cared bike is worth the extra money.
zerocool
PostPosted: 20:16 - 18 May 2004    Post subject: Reply with quote
Hi im new to this forum i came accross it because of this descussion you have been having.
I have a 2000 Model RS50 as you can see in the pic and i am supposed to be getting an arrow exhaust system in a few days. What sort of difference will it make my bike does about 50mph at the mo and takes about 7 seconds to get to 30mph.
PostPosted: 00:16 - 19 May 2004    Post subject: Reply with quote
The rs50, rx50 and rs2 matrix all run on the same motor and give pretty much the same output. Only the rieju and MH are considerably cheaper than the likes of an RS. You made the right choice though.
As its only a 50cc, the pipe will alter the powerband nicely to cope with high rpm better but speed wont increase amazingly. You might see it reaching about 60mph at a struggle but no guarantee because a lot depends on the way the carb is adjusted. You should feel a nice boost in acceleration though. I definitely did when i fitted a MetraKit pipe onto my senda.
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
priller
PostPosted: 11:35 - 19 May 2004    Post subject: Reply with quote
RS50 should easily reach 62 with an arrow pipe.
zerocool
PostPosted: 14:32 - 19 May 2004    Post subject: Reply with quote
Cheers 4 that. Very Happy
What is the risk of it blowing up with the exhaust on, do any of you have a standard rs50 with an arrow exhaust on?
Is there any other modifications i could put on my bike to increase speed and acceleration without causing and mayor problems?
I just dont want to go and spend loads of money and then have my bike blown up within a week. Neutral
bikedudextrm
PostPosted: 16:19 - 19 May 2004    Post subject: Reply with quote
When you derestrict them you're meant to change the front sprocket. My mate has a aprilia rx50 which derestricted would do about 55-60mph but we put front sprocket on 1 tooth bigger (from 12 to 13), his top speed is about 65mph now but on a long a road he reached 70mph slip streaming behind a big lorry Laughing .
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
PostPosted: 21:37 - 19 May 2004    Post subject: Reply with quote
remember that all 50cc speedo's are only accurate to approximately 40mph, then they slowly go out. So one thats indicating 70 may only be doing 58mph for example.
I'm sure changing the front sprocket also alters the speedo's accuracy, you'll have to confirm this with The Oracle Wink
zerocool
PostPosted: 14:46 - 21 May 2004    Post subject: Reply with quote
Well i got my exhaust this morning and put it on. Everything seemed to be ok untill it just stopped as if everything cut off. But i was running on reserve so i went and filled up and it went again but then about 50 yards down the road it did the same thing again? Sad Sad Sad Sad Sad
Any ideas?
It was working ok for about 45mins before this happened and i wasnt really hammering it the fastest i went is about 45-50.
But god the acceleration was 10x better.
PostPosted: 20:45 - 21 May 2004    Post subject: Reply with quote
you need to adjust your carb to cope with the change to a high rpm pipe.
check your spark plug and see what colour it is.
black = rich
light brown = lean
brown (somewhere in the middle) = about right
chances are its been working fine while the cylinder has had a decent supply of 2 stroke oil left but as soon as that burned, its been running dry. I'd get it checked rather quickly as it could lead to rather bad problems.
PostPosted: 21:45 - 21 May 2004    Post subject: Reply with quote
First thing I would check is that you haven't trapped the fuel hose to the carb when you have been fiddling with the bike.
Jack2004
PostPosted: 23:54 - 21 May 2004    Post subject: Reply with quote
Carl your rs50 looks stunning.
BikerBen
PostPosted: 14:24 - 22 May 2004    Post subject: Reply with quote
Zero. The same thing happened with my mates 50cc. As his bike had never had a race pipe on it before, the engine was not used to being caned so much more. The pipe was fitted and we went for a ride straight after. In fact i was riding it at the time. Going along the A316 full throttle and it seemed to cut out so released throttle and pulled again and it jittered a bit and went really slow so had to pull over. The bike cut out, smoke was coming from the front and it wouldn't start. We proceeded to go to the garage where we bought the exhaust and they had had MANY similar problems. I can't explain it perfectly because I don't know the correct names for everything. Basically he said as the bike had never had a race pipe before, some metal bit (see what i mean Smile) in the engine heated up loads and caused the bike to cut out. He told us to go back to it and said that it would start because of it having time to cool down. Sure enough the bike started. Ever since then the bike has been fine as the engine has adjusted to the new exhaust.
basically if you get a new exhaust and your bike has never had one before it's best not to thrash it straight away. Run it in at 30-40 for a bit and gradually increase the speed and let the engine get used to all the new strain.
I know thats all very un-technical but thats pretty much what you should do or you could risk blowing your engine up Confused
Hope your bike is ok now Zero.
Regards,
Ben
My NSR --> https://members.boards.ie/instinct/Diagonal.jpg
Now proud owner of a 1999 ZXR 400
PostPosted: 17:51 - 22 May 2004    Post subject: Reply with quote
Think if you derestrict the RS50 exhaust you need to increase the main jet to either a 68 or a 72 (think they are a 63 as standard).
Carl
PostPosted: 20:11 - 22 May 2004    Post subject: Reply with quote
Thanks mate
Lee_367
PostPosted: 20:54 - 22 May 2004    Post subject: Reply with quote
how fast does a restricted rs50 go? what do they rev to?
i would like to know because my mate has an rs50 which revs to 10k, and he says its restricted although it goes about 55mph, my restricted derbi only used to do 30mph and rev to 5k? any help would be appreciated. Karma
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
PostPosted: 21:00 - 22 May 2004    Post subject: Reply with quote
If its restricted, then it'll only do 30mph.
So his is obviously de-restricted.
55 is about all you can get out of one.
Lee_367
PostPosted: 21:16 - 22 May 2004    Post subject: Reply with quote
really! Very Happy he keeps telling me its got 12bhp and that it'll eat my derbi, ha ha, someones up for an caining
zerocool
PostPosted: 18:49 - 23 May 2004    Post subject: Reply with quote
Cheers 4 that Ben you were right it did work fine and has been doing for the past day and i have only really used the extra speed once (annoying taxi driver, dont ask)
I have been told to change the jet what ever that is, by one of my friends i think he said i have a 63 in aswell and should get a 68 or 70, i am just going to run it as it is and see how i go.
mr jamez
PostPosted: 18:54 - 23 May 2004    Post subject: Reply with quote
Carl, didn't you post that on the OCUK forums? If I remember correctly your not old enough to ride it yet, and it has a 68cc kit on it. Seeing as you will be 16, your insurance will not be valid Confused Question
The last post was made 22 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 126.83 Kb
