Bike FI - why did it take so long?
D O G
PostPosted: 13:24 - 15 Dec 2008    Post subject: Bike FI - why did it take so long? Reply with quote
Was pondering this on the way home. Why did it take so long for FI to become pretty much standard on bikes? It was pretty much universal in cars by the early 90's, but it took another 10 to make the same transition to bikes - why?
Now, I don't want the 'because it was easier to get carbs working well across the rev range' answer, because I know that. What I want to know is why that is the case.
What was the technical problems encountered with FI which held it up for so long?
Thanks!
Faldo
PostPosted: 13:28 - 15 Dec 2008    Post subject: Reply with quote
I don't think manufacturer's wanted to use FI, but emmision laws might of forced them. Perhaps?
Current: ZZR1400
PostPosted: 13:35 - 15 Dec 2008    Post subject: Reply with quote
No real technical problems. BMW were selling fuel injected bikes in the early 1980s (as were Kawasaki), even ignoring the turbo bikes, and Bimota and Ducati were selling pretty high performance injected bikes by the late 1980s (and even Moto Guzzi were selling injected versions of their bikes).
Trouble is cost. Fuel injection costs far more. From memory the kind of difference quoted was £40 for a bank of 4 carbs compared to £150 for an equivalent fuel injection system (prices in bulk to a factory). Even now if I wanted to buy new parts for a bike at retail prices it would cost a fortune to do it with fuel injection even compared to some top of the range flat slides (let alone some of the budget Mikuni RS flat slides).
When carbs work pretty well on a bike (small cylinder, high gas speed, individual carb per cylinder) there was little point in adding a fairly large amount to the final cost of a vehicle.
I suspect that they were largely forced into it to get round emissions rules.
map
Mr Calendar
PostPosted: 13:37 - 15 Dec 2008    Post subject: Re: Bike FI - why did it take so long? Reply with quote
Damofo D.O.G. wrote:
...What was the technical problems encountered with FI which held it up for so long?...
Introduction of new engines.
In the bike world an engine design is tweaked and fettled and used in various guises and bikes for decades. For some reason the companies do not design new engines on a whim. They'd rather use tried and tested technology.
Therefore the need to design a FI system for an engine is a big undertaking.
As said above FI must now be used to meet emission regulations. This is the reason for many bikes being discontinued over recent years.
Despite your sweeping comments the likes of BMW have been using FI engines for decades. That's mainly because it is a car engine! However, BMW do understand it quite well.
HTH Thumbs Up
PostPosted: 13:47 - 15 Dec 2008    Post subject: Re: Bike FI - why did it take so long? Reply with quote
It is not a car engine (twin cams were not common in BMWs at the time), and the fuel injection system is not the dodgy old K jetronic system common in cars at the time.
D O G
PostPosted: 14:37 - 15 Dec 2008    Post subject: Reply with quote
So in actual fact it is nothing to do with carbs being easier to get working well then FI, just a matter of cost and weight. Makes more sense to me.
PostPosted: 14:49 - 15 Dec 2008    Post subject: Reply with quote
Takes a pretty good fuel injection system to get better results than a decent set of carbs.
Used to be a pretty standard trick when tuning cars to dump the fuel injection and go to a pair of decent carbs. The Alfa 33s lost power when they went from having twin choke down draft webers / Dellortos to Bosch fuel injection (and that was a multi point fuel injection system, not a cheapy single point setup). From 118hp to 110hp on the 1.7 for example.
D O G
PostPosted: 14:54 - 15 Dec 2008    Post subject: Reply with quote
So why is that then? Is it because carbs are 'self regulating' - i.e. fuelling reactive to the actual airflow, rather relying on a compromised map (can only have so many data points), which may have poor input data (due to poor sensors).
Are the FI jets not as good as carb jets either?
PostPosted: 15:07 - 15 Dec 2008    Post subject: Reply with quote
Old off hand comment was that fuel injection gave engines what they needed, carbs gave them what they wanted.
Reality is pobably more down to how bad basic fuel injection setups are. Single throttle bodies miles from the valves, tortuous intakes, restrictive air flow meters (or just using slow reacting MAP sensor based systems), no tuned length intakes. Add to that the difficulty in doing any kind of remapping for fuel injection (add ons like Power Commanders are pretty recent), except by burning a new chip (and even that is not always possible). They were pretty much designed to be cheap and run cleanly for emissions just strangely marketted as a performance thing.
Even worse are the psuedo efi Bosch K jetronic systems (basically use a balanced wedge in the air flow to just adjust the flow to some continuous injectors), which were used on loads of 80s cars (eg, XR3i, Golf GTI, etc).
the grim reaper
PostPosted: 17:35 - 15 Dec 2008    Post subject: Re: Bike FI - why did it take so long? Reply with quote
HTH Thumbs Up
Nah, it wasn't the introduction of new engines at all, it's relatively simple to bodge an FI system onto an engine that used to have carbs (Varadero, Blackbird etc), the FI requirement was purely down to emissions for new bikes, hence, as mentioned in this thread, the discontinuation of certain models.
Cost is and always will be the driving factor behind bike evolution, except in the 'money no object' bikes like the MV F4CC and the NR750. All others are built to a budget.
In certain cases, like the Blackbird and Varadero, Honda saw bikes that were still selling well but were going to fail to meet new emissions regs, hence the switch to FI.
Other bikes, like the Fazer 600 and 1000 were ditched in favour of a new bike in the FZS6 and FZ1. Probably because they were old hat and didn't keep up with the competition.
Grim
map
Mr Calendar
PostPosted: 17:53 - 15 Dec 2008    Post subject: Re: Bike FI - why did it take so long? Reply with quote
the grim reaper wrote:
...it's relatively simple to bodge an FI system onto an engine that used to have carbs (Varadero, Blackbird etc), the FI requirement was purely down to emissions for new bikes...
May be simple but can be a pain to setup right on an old engine design.
The first generation Blackbirds with FI were slated and it took a while to sort.
By comparison notice they didn't bother with the likes of the Pan-European but went the new engine route instead (as the ST1100 was getting long in the tooth anyhow).
As a side issue FI helps with fuel economy as it can be shut off while 'coasting' whereas fuel is always flowing through a carb.
PostPosted: 17:58 - 15 Dec 2008    Post subject: Re: Bike FI - why did it take so long? Reply with quote
That is more Hondas pathetic setting up of the fuel injection, and can be sorted quite easily by a half decent custom map (but then the custom map probably wouldn't pass emission tests).
Could be done with carbs as well if required. Merely have a valve to cut the idle jet when vacuum after the butterfly is too high.
That said, cutting the fuel when coasting is one of the worst ways to trigger a jerky throttle response on a crude fuel injection system.
The last post was made 17 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 87.9 Kb
