Dodgy lock?
Jamrock
PostPosted: 09:41 - 16 Dec 2008    Post subject: Dodgy lock? Reply with quote
I have found it increasingly hard to start my bike because of my lock. It takes me 5 - 10 minutes of going up and down with they key until it 'clicks' into the right spot and the key turns. Is there anything I can do or does it look like a new lock jobby?
UkBikeGear
PostPosted: 10:58 - 16 Dec 2008    Post subject: Reply with quote
sounds like either your ignition or key are really worn and in need of replacement, but try putting the key in and tilting it back slightly as you turn, might save a bit of time in the mornings!
motorcycle clothing online at www.ukbikegear.com... we're here to serve!
McJamweasel
BCF Junkie
PostPosted: 11:35 - 16 Dec 2008    Post subject: Reply with quote
What bike is it? Suzuki ignition locks wear pretty easily, but there is a knack to getting them to turn. Simply push the key forwards slightly as you turn and it will go easily.
Kris
PostPosted: 12:10 - 16 Dec 2008    Post subject: Reply with quote
Agreed. The key on my 04 SV needs to be inserted then tilted forwards by a few millimetres before it turns.
Caused a few puzzled moments after buying it. Rolling Eyes Mr. Green
www.prisonplanet.com
neil.
PostPosted: 12:26 - 16 Dec 2008    Post subject: Reply with quote
On my YBR a squirt of WD40 in the barrel helps with this sort of issue. Not sure how well it would work on other bikes. Thumbs Up
ZaphodBeeble
PostPosted: 13:07 - 16 Dec 2008    Post subject: Reply with quote
My Firestorm does this every few months. I squirt a bit of brake cleaner into the barrel first then I spray some good old WD40 when it's dried out. The brake cleaner gets rid of any filth and the WD lubes the tumblers. Smile
Put the key in and work it all around for a bit until the motion is smooth. Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Syx
PostPosted: 16:02 - 16 Dec 2008    Post subject: Reply with quote
Useful info guys, my key is just starting to get this way so I might give it a go before it gets worse!
The last post was made 17 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 51.86 Kb
