Brake seized - how to prevent it in the future?
dabigginger
PostPosted: 22:29 - 18 Dec 2008    Post subject: Brake seized - how to prevent it in the future? Reply with quote
I last used my Hornet back in mid-October. A few weeks later, I went to wheel it out the garage to wash it. There was a fair bit of resistance coming from the front brake (it was a fair struggle to push). A few weeks later, I had to move it out the garage again and it was really hard to move. I mean when I pushed it forwards, the front of the bike dipped quite a lot. The front brakes are almost completely seized on the front! Anyway, they free up if the calipers are tapped lightly with a rubber mallet. I'm hopefully getting this fixed shortly (I don't feel 100% confident working on the most important part of the bike).
Anyways, I was wondering if there is anything in particular I can do to avoid this happening again? Was this possibly just caused by lack of use? If I get it fixed up, then don't use the bike for a couple of months, is it likely to happen again so soon?
hmmmnz
PostPosted: 22:43 - 18 Dec 2008    Post subject: Reply with quote
clean your brakes with warm water everytime you ride in the uk's shitty salt covered roads,
better yet start patitioning your local mp to get salt gritting stopped,
it fucks bikes and cars and is bad for the enviroment,
regular grit (small stones) will give a decentish grip for cars (the only people who matter, apparently) and wont rust everything to buggery
the humans are dead
I kick arse for the lord
dabigginger
PostPosted: 18:38 - 20 Dec 2008    Post subject: Reply with quote
I thought warm water was a big no no where salt is involved as it speeds up how quickly it corrodes metal and helps dissolve it into harder to reach areas...
Itchy
PostPosted: 18:42 - 20 Dec 2008    Post subject: Reply with quote
Strip them down every 6 months , should be no problem,
As a preventitive when you ride in winter (and summer) let the bike cool down a bit and hose the bike off a bike...
Also you might want to use a bit of red rubber grease when you reassemble the calipers and pistons.
hmmmnz
PostPosted: 10:51 - 21 Dec 2008    Post subject: Reply with quote
warm water should be fine, anything to dissolve the salt really
the humans are dead
iooi
PostPosted: 11:51 - 21 Dec 2008    Post subject: Reply with quote
Make sure when you park the bike up you don't use the front brake to stop the bike..
Or give the calipers a tap, spin wheel to make sure that the pads are moved away from the disk.
Sounds like the pads are sticking/rusting to the disk when parked up rather than anything else.
I would also stop washing it and putting it back in the garage for a few weeks, at least without taking if for a good ride to clear all the excess water of the hard to reach places like pads and disks.
PostPosted: 11:55 - 21 Dec 2008    Post subject: Reply with quote
My view on this is that it is possibly true that warm salty water is more corrosive than cold salty water, but that doesn't mean that warm salty water will cause stuff to instantly disolve. I would doubt in the short while the water is warm and in contact with the brakes it would make any difference at all, and I would expect the warm water to wash the salt off more effectively (and also mean you are more likely to do the washing when you don't have to plunge your hand into freezing water on a cold day to do it).
metal ken
PostPosted: 13:23 - 21 Dec 2008    Post subject: Reply with quote
I sometimes use a non penatrative grease like silicone grease on the pistons and either copper of aluminium paste on the back and side of the pads, be carefull not to get any on the pad friction material or disc.
Or Sometimes for a quick fix i spray the pistons/back of the pads with a non-penatrating lube that doesn't react with rubber. Lubes like wd-40 are penatrating and are a big NO-NO on calipers.
As said on this post it is always good to give them a service on a regular basis, servicing and prevention is the best method for fixing a lot of bike problems.
Good luck, Ken Thumbs Up
My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400
Itchy
PostPosted: 14:40 - 21 Dec 2008    Post subject: Reply with quote
You obviously haven't seen a made in China CG125 copy or a 1980s ford.
PostPosted: 15:34 - 21 Dec 2008    Post subject: Reply with quote
Shouldn't matter given the tiny difference. Be sort of like saying a Big Mac is more fattening than a Cheeseburger. Not enough difference to care about, and both are a lot better than starving.
The last post was made 17 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 70.85 Kb
