| northernfaced |
 northernfaced L Plate Warrior
| Davie_G71 |
 Davie_G71 World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 10:20 - 22 Dec 2008 Post subject: |
does it only do it while you are moving??
or if you are stationary as well,
if stationary i would be looking at valve clearances or cam chain/tensioner
if only while moving
then could be loose disc,pads, fuct wheel bearings, or may be someone put a spokey dokey on your wheel (did you get spokey dokeys in the uk?)
 ____________________ the humans are dead
I kick arse for the lord
| Davie_G71 |
| Azonicben |
 Azonicben Could Be A Chat Bot
| northernfaced |
 Posted: 12:40 - 22 Dec 2008 Post subject: |
Break pads - not changed with new wheel + seem to've bedded in ok.
ticking sound is audible when stationery and moving, seems to appear on throttling past 1500rpm. more noticable when moving but i think thats more to do with being in front of the engine noise. the ticking noise doesnot speed up/slow down with riding.. cam chain/tensioner done less than 1yr ago so maybes valve clearances??
never was lucky enough to have spokey-dokeys, had a bit of cardboard and a clothes peg was where it all began for me!
I have the same speedo drive and it's a similar noise but louder.. and the fact it clicks at a constant rate regardless of engine speed i reckoned it to be not that..
ps i'm rarely right when i reckon these things.
 ____________________ peels on wheels |
| Davie_G71 |
| northernfaced |
 Posted: 13:32 - 22 Dec 2008 Post subject: |
yes i believe it does. i'm going to check the wheel bearings.. check everythings tight then check into the workshop for investigation.
tbc  ____________________ peels on wheels |
The last post was made 17 years, 72 days ago. Instead of replying here, would creating a new thread be more useful? |
