clickety-click is my bike sick??
northernfaced
PostPosted: 09:50 - 22 Dec 2008    Post subject: clickety-click is my bike sick?? Reply with quote
Kawasaki GT550. 22k miles, W reg. Normally top runner, does 30-50miles every day of the year. Owned for 2.5 years
This past week there's a clicking noise when i accelerate seems to be from front of engine, can't tell which side, it's not affected by speed in that it clicks at it's own constant rate, is more audible when accelerating, no vibrations, no drop in power, recently fitted new (to bike ) wheel and disks.
Any advice please???
peels on wheels
Davie_G71
PostPosted: 09:54 - 22 Dec 2008    Post subject: Reply with quote
Did you replace the pads at the same time? If not the new discs could be causing the pads to move around in the calipers, causing your clicking sound.
Also, make sure the wheel is aligned properly.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
hmmmnz
PostPosted: 10:20 - 22 Dec 2008    Post subject: Reply with quote
does it only do it while you are moving??
or if you are stationary as well,
if stationary i would be looking at valve clearances or cam chain/tensioner
if only while moving
then could be loose disc,pads, fuct wheel bearings, or may be someone put a spokey dokey on your wheel (did you get spokey dokeys in the uk?)
Very Happy
the humans are dead
I kick arse for the lord
Davie_G71
PostPosted: 10:26 - 22 Dec 2008    Post subject: Reply with quote
Spokey dokeys!!
I remember i had so many of them on my bike wheels that they didn't actualy make any noise.
That and a coke can to make it sound like a motorbike!!
Anyway, back on topic, it could be bearings if it's a new wheel. Also, just check everything is tight.
Azonicben
PostPosted: 11:30 - 22 Dec 2008    Post subject: Reply with quote
If youve recently had the wheel out could it not be the speedo drive? I`ve got a mechanical kph/mph converter on mine and that has a similar tick to it.
northernfaced
PostPosted: 12:40 - 22 Dec 2008    Post subject: Reply with quote
Break pads - not changed with new wheel + seem to've bedded in ok.
ticking sound is audible when stationery and moving, seems to appear on throttling past 1500rpm. more noticable when moving but i think thats more to do with being in front of the engine noise. the ticking noise doesnot speed up/slow down with riding.. cam chain/tensioner done less than 1yr ago so maybes valve clearances??
never was lucky enough to have spokey-dokeys, had a bit of cardboard and a clothes peg was where it all began for me!
I have the same speedo drive and it's a similar noise but louder.. and the fact it clicks at a constant rate regardless of engine speed i reckoned it to be not that..
ps i'm rarely right when i reckon these things.
Confused
peels on wheels
Davie_G71
PostPosted: 12:47 - 22 Dec 2008    Post subject: Reply with quote
What about cam chain tensioner? Does your bike have one?
northernfaced
PostPosted: 13:32 - 22 Dec 2008    Post subject: Reply with quote
yes i believe it does. i'm going to check the wheel bearings.. check everythings tight then check into the workshop for investigation.
tbc Wink
peels on wheels
The last post was made 17 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 55.61 Kb
