Sand paper ? / wet n dry?
Itchy
PostPosted: 17:50 - 22 Dec 2008    Post subject: Sand paper ? / wet n dry? Reply with quote
Over the few days I have off over new years I'm going to strip and repaint the Africa Twin , probably to a red/white/blue scheme sort
like this
https://farm4.static.flickr.com/3110/2367195754_af8e6c83ff.jpg?v=0
except where it is white have it red, and where it is red have it white (using stickers) ...
Question is what sand paper do I need , grain/brands etc....since I've no idea at all , keeping it hammerite black isn't ideal as I intend to cross deserts on this bike and having a black bike may mean more heat gets absorbed and the CBR in Spain was like riding a small oven in an oven.
And how much will I need to cover the entire surface area (sand paper).
OR
Can I rig up my angle grinder / drill with some sort of sanding disc?.
Thoughts appreciated.
Ta
tutton
PostPosted: 19:18 - 22 Dec 2008    Post subject: Reply with quote
There are several brands doing sandpaper etc,
and usually the only advantage of the more expensive ones are less prone to clogging up with paint, as when its clogged its useless.
The more expensive better finishing products are 3M & Mirka
Depending on what your doing with the job depends on the P grade needed,
~ If just preparing it for paint then P800 wet and dry. or around 500 if using a dry pad or sheet.
~ If you have fairing scuffs etc, then you will need to move down around the 320/400 dry stage, Although minor stonechips etc can be done with the 800 wet and dry.
Well most places that sell the stuff sell it in packs of 10 sheets upwards.
Example, although this link is 10 half sheets making 5 whole sheets, it would be do-able with that amount but im just countering in for if you paint it, and it dosnt come out how you like and have to restart the process, as of course it does happen to the best of us.
[url=https://cgi.ebay.co.uk/Wet-Dry-Abrasive-Sanding-Paper-3M-Pick-And-Mix_W0QQitemZ370107163627QQcmdZViewItemQQptZUK_Body_Shop_Supplies_Paint?hash=item370107163627&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318#ebayphotohosting[/url]
You can rig angle grinders up with backing pads to do it, but this is hard to find the right backing pad with the right velcro underside to take the sanding discs you can buy on the market, but if you can find a backing pad to fit to a angle grinder the sandin discs are 150mm, although they will be dry pads and not wet&dry ones as you'd expect.
Hope that helps.
If you need any more just post again and ill try.
Itchy
PostPosted: 19:35 - 22 Dec 2008    Post subject: Reply with quote
Thanks ,
Very Happy Thumbs Up
finpos
PostPosted: 20:48 - 22 Dec 2008    Post subject: Reply with quote
See if you can find a special paint stripping wheel for a drill or grinder - it's like a pan scourer on steroids and won't get clogged or damage the surface underneath (too much...). I think I saw one last in either halfords of machine mart, so they are not too hard to come by.
f.
tutton
PostPosted: 20:49 - 22 Dec 2008    Post subject: Reply with quote
f.
Paint stripping wheels usually metal or plastic ones which are for METAL preperation, and will damage her fairings. and will then likely need be reprimed etc, which wont be needed if just wet and drying.
HTH
finpos
PostPosted: 20:52 - 22 Dec 2008    Post subject: Reply with quote
Nah, work just fine on hammerited fairings. Some care required, but less than sandpaper.
f.
tutton
PostPosted: 20:55 - 22 Dec 2008    Post subject: Reply with quote
OO my bad, didnt read it was hammerite on there,
if thats the case, id go for dry 320/400
and work to 800.
as if its like normal hammerite its really bumpy and shit texture aint it.
finpos
PostPosted: 21:00 - 22 Dec 2008    Post subject: Reply with quote
Well, Itchy said that. If it's not hammerite it'll probably just wash off with enough thinners (but I'm sure he was told that somewhere else and has given it a shot).
f.
The last post was made 17 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 59.38 Kb
