| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:01 - 23 Dec 2008 Post subject: is this symptoms of a nackered fuel pump? ideas gents |
so im going along, its fine at low-medium revs.
if i go close to the redline, its ok for a bit, maybe get a few wheelies out of it before problems start.
starts to run on 3, then gets progressively worse until my 600 becomes a 300 twin and i have to limp home, cutting out several times and being an absolute twunt to start again.
leave it at low RPM for a bit (about 2-3 minutes), and its fine again until the next time. its also starting and running fine before this happens, so i think compression is fine etc, engine is at operating temperature etc.
its getting really irritating as its ruining the few dry days i've had to hooligan around traffic, wheelie-filtering.
SRAD 6, '97
tried with the fuel cap open, and its still the same. no kinks in the fuel lines etc. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| MaybeGuy |
 Posted: 01:24 - 23 Dec 2008 Post subject: |
i had the fuel pump out recently, and the filter didnt look too bad (wire mesh type).
i'll give it a check when i get the time to, if not i'll try to get a replacement  ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Gaz-t1esto |
 Gaz-t1esto Borekit Bruiser
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 10:10 - 23 Dec 2008 Post subject: |
Coils breaking down when you ask too much of them in the heat? ____________________ My Flickr |
| bladerunner |
| Odie |
 Odie World Chat Champion
| MaybeGuy |
 Posted: 16:14 - 23 Dec 2008 Post subject: |
big_ham, after todays tests i think i can eliminate the coils as the problem. motorway speeds, like 70mph, its absolutely fine for about a mile, then the throttle starts to get less responsive, then slowly grinds to a halt. classic fuel starvation symptoms.
as for the carbs, its been running 100% up until recently, and runs fine until the starvation occurs.
i'll whip off the bowls when i can be arsed, and have a look.
the odd thing is, its all started since putting a shot of redex through it :S
since then i've been through 2 normal tanks of fuel. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| MaybeGuy |
 Posted: 21:30 - 25 Dec 2008 Post subject: |
solved it.
checked the fuel lines properly, the main line wasnt on fully, meaning the stopcock in the line wasnt being pressed in, so fuel was being stopped. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
The last post was made 17 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
