| smegballs |
 smegballs World Chat Champion
| mattjs895 |
 mattjs895 Spanner Monkey
 Posted: 00:36 - 26 Dec 2008 Post subject: |
not to sure about what plastic you can use but mz spares to find many spare parts for all mz's.
also, i believe, dropping the forks will make the bike turn into the corners better but there's no need to drop the forks that much, normally an inch is all that's required.
cheers
matt |
| virus |
 virus World Chat Champion
 Posted: 00:55 - 26 Dec 2008 Post subject: |
Araldite and a penny is your friend.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| stinkwheel |
 Posted: 01:32 - 26 Dec 2008 Post subject: |
I'm not entirely sure what would hold brake fluid. I think virus has the best idea with an epoxy resin.
I just wonder if araldite would be the best thing or if it would be better to use something like JB weld.
In any case, don't use araldite "rapide", use the slow setting "precision" version.
Dropping the forks through the yokes effectively shortens the wheelbase slightly and decreases the rake on the front. This will make the bike fall into corners more readily but at a cost of stability and with more tendancy to develop speed wobbles. It will also be harder to get it back up out of a corner.
You should be thinking millimetres rather than inches. Adjust it a little at a time then go out and have a try. No more than 4 or 5mm at once or you could come a cropper.
EDIT: What about using a dome headed spout bolt in the hole (dome to the inside with a rubber gasket, penny washer and nylok nut to the outside)?
One of these:
https://www.fastfixdirect.co.uk/images/prodimages/P371.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| smegballs |
| metal ken |
 metal ken Spanner Monkey
 Posted: 13:48 - 26 Dec 2008 Post subject: |
Hi,
i have just got in a MZ ETZ 251 for breaking, i could see what the master cylinder is like on it if you are still needing one,
Ken,  ____________________ My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400 |
| smegballs |
| metal ken |
 Posted: 16:17 - 26 Dec 2008 Post subject: |
Cool  ____________________ My motorbike breakers metalken.co.uk
| mattjs895 |
| metal ken |
| ms51ves3 |
 ms51ves3 Super Spammer
| smegballs |
| sumpgard |
 sumpgard Nova Slayer
| stinkwheel |
| smegballs |
| stinkwheel |
| smegballs |
| stinkwheel |
 Posted: 22:56 - 28 Dec 2008 Post subject: |
Is the battery flat?
Takes a few kicks to excite the coil enough to make a spark with a flat battery with the ignition switch in the "emergency" position.
I'm pretty sure the coils would be different.
There is not a whole hell of a lot to go wrong with a hall effect sensor. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| smegballs |
The last post was made 17 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
