Ticky CG
camby
PostPosted: 11:58 - 26 Dec 2008    Post subject: Ticky CG Reply with quote
Hi just done the cylinder head on my cg and its really ticky and smokey Sad anyone know what causes this? seems to be running perfect other than that.
Camby Smile
VFR400 NC24 & YBR 125 Smile
bladerunner
PostPosted: 12:32 - 26 Dec 2008    Post subject: Reply with quote
Did you check the valve clearance after fitting? also going along the route of it's smoking badly as well..did you fit new valve seals to the new head? What were the guides like?
camby
PostPosted: 12:41 - 26 Dec 2008    Post subject: Reply with quote
Hi yeah iv checked the clearances should I beable to get the feeler gauge right under?
The valve seals were in it (second hand head)
Guides look fine, its had a new piston and rings aswel..
bladerunner
PostPosted: 12:50 - 26 Dec 2008    Post subject: Reply with quote
yes the feeler gauge should be a good sliding fit but be able to pass under the adjuster. What I'm wondering is are the valve guides worn maybe not the valve seats but the guides that the valves run in? you say it smokes..has this cleared up yet(oil from rebuild getting burnt off1) or is it still doing it? If it's still doing it does it do it more on the over run ie oil being sucked past the valve stem seal
Ichy
PostPosted: 12:53 - 26 Dec 2008    Post subject: Reply with quote
The ticking is likely to be valve clearance, either they were tight before and you never heard them or they are too big now. Is it a regular ticking that changes with revs?
Smoke might be down to oil from assembly. Otherwise the valve stems or seals are not as good as you think they are or the head gasket is leaking into the bore. Is the new piston and rings the right size? did you measure the ring gap when fitted?
NiteMare
PostPosted: 13:26 - 26 Dec 2008    Post subject: Reply with quote
ticking could also be a gas leak where the downpipe meets the head if it hasn't been sealed properly (new gasket there ? )
it ain't broke...
i ain't fixed it enough
camby
PostPosted: 14:13 - 26 Dec 2008    Post subject: Reply with quote
Hi thanks for all th replys the ticking is fixed now still really smokey think ile just try replacing the valve seals once i figure out how to. Doubt its excess oil from the rebuild ive ran it for ages and it just keeps comming..
Hutchysrs50
PostPosted: 14:39 - 26 Dec 2008    Post subject: Reply with quote
Not to sound stupid here Rolling Eyes but i dont know your bike very well.
is isnt going to be the type of 2 stroke oil your using is it? my 50cc 2 stroke used to smoke loads with this red oil i used to use Embarassed
hope this helps. Good luck fixing it.
Gilera SC 125 - Current
Xenocide
PostPosted: 15:43 - 26 Dec 2008    Post subject: Reply with quote
CG's a 4t bud
KTM LC4 400 | Honda VTR1000
Hutchysrs50
PostPosted: 18:59 - 26 Dec 2008    Post subject: Reply with quote
Xenocide wrote:
CG's a 4t bud
Well there is my immence knowledge for you then Smile
Thanks for letting me know Karma
Finglonga
PostPosted: 20:40 - 26 Dec 2008    Post subject: Reply with quote
Does it smoke more when you first start it up than when its running? If so it's a fair sign of stem seals on the way out as the oil runs down them when the engine stops into the cylinder.
Also are you 100% sure you put the piston rings in the right order and way round?
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 70.76 Kb
