1977 honda cj250t clutch problem
shitfan
PostPosted: 19:28 - 27 Dec 2008    Post subject: 1977 honda cj250t clutch problem Reply with quote
Have just rebuilt a cj250t from a box of bits .Everything fine exept i cannot sort clutch out.I can engage gears ok but ,when you pull clutch in on centre stand its still in gear and wheel keeps spinning ,if you try and stop wheel spinning bike will cut out.
Iv tryed adjusting cable at both ends.But if i adjust it to much ,it just goes pop! and to much slack then nothing at all. Exclamation
hmmmnz
PostPosted: 21:51 - 27 Dec 2008    Post subject: Reply with quote
a bit of a long shot, but is the circlip still there
number 11
https://images.powersportsnetwork.com/fiche/images/Honda/1976/Motorcycles/2146_CLUTCH.gif
to me it sounded like the ball bearing was missing from the end of the push rod..... but it doesnt look like the cj has one any way,
good luck
the humans are dead
I kick arse for the lord
NiteMare
PostPosted: 22:24 - 27 Dec 2008    Post subject: Reply with quote
it's a very long time since i worked on one of those engines, but here goes off the top of me head .....
slacken both ends of the cable off (loads of slack) ...
now on the cover the cable goes thru there's another cover to remove, under that is a screwhead with a 12mm locknut ...
slacken the locknut then screw the slotted head in until it loads up, back it off half a turn and tighten the locknut ....
adjust the cover end of the cable until you have approx 10mm of play at the lever ...
then at the lever adjust until you only have 5mm of play ....
clutch should now work ...
if the clutch slips you won't have backed off the slotted head enough and will have to readjust the cable as well
it ain't broke...
i ain't fixed it enough
shitfan
PostPosted: 09:34 - 28 Dec 2008    Post subject: Reply with quote
IN reply to ideas .
Not sure about which circlip you mean.
ball bearing is in place.
and have tried adjusting cable as in manuel.
beginning to think i may need a new set of clutch plates?
sumpgard
PostPosted: 11:49 - 28 Dec 2008    Post subject: Reply with quote
did you oil the clutch plates may be they are stuck together alot of bikes do this when stood for along time ride it up the road in first gear hol the clutch in and stand on the back brake at about half throttle that should free it up
NiteMare
PostPosted: 13:08 - 28 Dec 2008    Post subject: Reply with quote
out of curiosity, when you reassembled the engine and fitted the clutch basket/hub there is a big nut and washer holding it onto the shaft (going by memory), you did fit them both correctly and the hub doesn't slide back and forth does it ??
if it does then you'll not get the clutch to release as the release mech' doesn't have enough travel to take up any play
it ain't broke...
The last post was made 17 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 47.88 Kb
