KX80 carb problem
Moonie
PostPosted: 21:01 - 28 Dec 2008    Post subject: KX80 carb problem Reply with quote
Just picked up my KX 60 with a KX80 engine, and when I turn the fuel on the bike is fine until i tilt it over even slightlty, and then two jets, one on the side and one on the back just piss petrol everywhere until I turn it off.
What's going on? Crying or Very sad
sumpgard
PostPosted: 22:19 - 28 Dec 2008    Post subject: Reply with quote
i would say that the float level needs setting or the float is stuck first try gently tapping the side of the carb towards the bottom with the petrol on if this does not work take of the carb remove the float chamber clean all the jets and reset the float level if you re not confident get some one who knows what they are doing to do it
Moonie
PostPosted: 22:30 - 28 Dec 2008    Post subject: Reply with quote
Should have mentioned I checked the float level and made sure it was moving freely, tapped it a few times whilst attatched too.
It's got a few people completely baffled, no idea whats going on.
cheers though
joe
sumpgard
PostPosted: 22:50 - 28 Dec 2008    Post subject: Reply with quote
when you say jets do you mean breather pipes and does it do it when its running or stoped
Moonie
PostPosted: 23:04 - 28 Dec 2008    Post subject: Reply with quote
One of them is the brether and one of them is God knows what, one comes from just below whenre the throttle cable and spring etc are and one is at the bottom of the carb.
It happens when it is stopped, can't get it running atm.
sumpgard
PostPosted: 23:22 - 28 Dec 2008    Post subject: Reply with quote
i would look at the float needle and make sure the little seal on the end of it is in good condition also did you set the float level properly you hold the carb so that the float hangs down at an angle and the little pin on the end of the float needle is just the metal tab on the float . touching and not pushed in then measure from the base of the carb to the top of the float i dont no the setting for your bike but this is normaly around 18mm i have recently repair a bike with exactly the same symtoms as yours and the lad had set the float level incorectly hope this helps
Moonie
PostPosted: 23:42 - 28 Dec 2008    Post subject: Reply with quote
cheers mate I'll have a look at that tomorrow morning and post up the results Cool
Moonie
PostPosted: 17:26 - 29 Dec 2008    Post subject: Reply with quote
OK set the float level correctly and it's still pissing everywhere.
Got it going today though and someone in the village will give me a new(ish) carb for a fiver, so I'm happy Very Happy
The last post was made 17 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 55.67 Kb
