| Wise1 |
 Wise1 World Chat Champion
| Joish |
 Joish Two Stroke Sniffer
| andi |
 andi Crazy Courier
 Posted: 17:29 - 29 Dec 2008 Post subject: |
Can you drill the head off the bolt holding the bung on?
Mind you from the pictute ,it looks feasable to get a spanner on the inboard nut. If you can then its just a socket on the bung end and all should be good?  ____________________ Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929 |
| Wise1 |
| Ichy |
 Ichy World Chat Champion
 Posted: 18:14 - 29 Dec 2008 Post subject: |
Does there look enough room to get a nut splitter on there?
Doesn't look like there is anything good for leverage but maybe a carefully placed pry bar or piece of wood to place pressure of the end of the bolt, forcing it out, while using a spanner on the nut.
A lot of patience and a file on the nut. Or just a small hacksaw blade, not in the frame. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| FZX-er |
 FZX-er Nova Slayer
 Posted: 18:38 - 29 Dec 2008 Post subject: |
are you 100% sure the socket is fitting over the bolt head inside the bung,as you said the nut is just spinning which would not happen its the bolt that you should see turning when you have the spanner on the nut.  |
| Ichy |
| Wise1 |
| sumpgard |
 sumpgard Nova Slayer
| sumpgard |
| FZX-er |
 FZX-er Nova Slayer
| Ichy |
 Posted: 12:08 - 30 Dec 2008 Post subject: |
I 'm guessing that they may well make them out of softer material simply so that it doesn't damage the frame when they hit the floor. No idea if this is true just that in the crash photo's I've seen most bungs seem to bend. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Wise1 |
 Posted: 01:20 - 31 Dec 2008 Post subject: |
Cheers Keith never thought of that, will give that a go first as there should just be enough space, if not I can just about get the nut splitter on it  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600 |
The last post was made 17 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
