Quick advice needed before i blow up my bike!
Darth
PostPosted: 20:58 - 29 Dec 2008    Post subject: Quick advice needed before i blow up my bike! Reply with quote
It has been laid up for a few weeks and have just got it all back together again but battery is dead. Have somehow lost my charger and really want a test ride tonight. Can i jump it off a car battery or will this fry things? They are both 12V and it would only be on few seconds?? Help!
PostPosted: 21:04 - 29 Dec 2008    Post subject: Reply with quote
I've done it many times, not a problem.
Some would say it can damage fancy electronics, but if you don't have the car running, really can't see it being an issue.
Not that I ever have, but might be worth unplugging the terminals on the car to be sure nothing happens to the car electronics.
Itchy
PostPosted: 21:05 - 29 Dec 2008    Post subject: Reply with quote
Although I don't know what the bike is (could be a scootay?) bump start it...
Clutch in
Ie stick it in 2nd , run with the ignition on erm ON, run to about 5-10mph let out the clutch jump on the seat at the same time to give bit more traction on the rear wheel , a small bike <500cc should bump easily , I can do it on the NTV easy in as little as 10ft.
Darth
PostPosted: 21:16 - 29 Dec 2008    Post subject: Reply with quote
Cheers for the advice. Tried running but i injured myself the other week and the first attempt nearly crippled me!
Its a 97 GSX600F and a MK1 golf so shouldnt think there are too many fancy electronics to fry either side!?
Blue_SV650S
PostPosted: 21:23 - 29 Dec 2008    Post subject: Reply with quote
As you say, no problem jumping off a car - but if your bike battery has been flat for a while, it might not hold charge any more Sad
As for removing the terminals on the car, I wouldn't recommend that, most modern cars store the ECU settings in memory. Remove the battery, and it goes back to default. It'll run fine on default, but it will then need costly 'computer time' to get it back to idyllic settings .. this might be necessary for modern cars MOTs as they are pretty strict ... also the default setting is bound to run a bit richer, therefore a waste of fuel Wink
Villers
PostPosted: 21:33 - 29 Dec 2008    Post subject: Reply with quote
Run that by me again? So what youre getting at is if I had to change the battery on a car it would lose some magical ECU settings that arent stored and then go back to some other settings that make the car unable to pass an MOT? Where do these original one off settings come from, do they set each one up individually?? Have you seen this happen or is it something youve heard about? Confused
Blue_SV650S
PostPosted: 21:41 - 29 Dec 2008    Post subject: Reply with quote
I think you will find that when places swap batteries these days they have a little temporary battery clipped on so the settings are not lost during the replacement ...
And yes, this happened to my car (I didn't know prior either Wink) ... I am however supposing the settings are far enough out to perhaps fail an MOT. But it doesn't take much these days does it Wink .... remember default is a 'safe' setting, when new the cars will be put on a computer and set up individually, not running on the default ...
This all came about for me as I had to replace a faulty ECU on a previous car. The garage that fitted the new one (recon) told me all this stuff so that after it was fitted and 'set up' I didn't lose the settings they just put in ...
I have kept it in mind ever since Wink
PostPosted: 21:44 - 29 Dec 2008    Post subject: Reply with quote
I thought the ECU settings were usually one that adapted to the style of riding/driving.
Jay always had a go at me when I hit the kill switch of his 675; I think I pointed out that resetting it was probably a good idea as we were putting it in a van after a track day and he'd next be using it for commuting or something.
Villers
PostPosted: 21:49 - 29 Dec 2008    Post subject: Reply with quote
So the vehicle learns its own settings? Just sounds ridiculous, what would be the advantage of that in the real world?
Blue_SV650S
PostPosted: 21:51 - 29 Dec 2008    Post subject: Reply with quote
Yes they do ... but they adjust so the adapt for conditions, so it is running exactly how you told it to .. i.e. it tries is hardest to do what it needs to do to get the sensors showing what they did when you set it up ... so if it was at default, then it would be adjusting to a different pre-set point!! Wink
To be fair, this learning was all about 5 years ago .... the newer and even more intelligent ECUs might not suffer the same plight ... but this is just supposition ... I'd ask a main dealer if you particular car will have a problem ...
Finally the dude that replaced my ECU could have been talking testicles ... but it DID make sense and I have heard someone else say the same thing since putting weight on what the first guy said ...
Oh and not sure how the Kill Switch would re-set anything? Or again are we talking about the ECU's 'learning' on that ride?
finpos
PostPosted: 22:04 - 29 Dec 2008    Post subject: Reply with quote
There's plenty of learning ecus about - most go back to sensible default when they loose power and just re-learn what they need. Some go into a stupid limp-home home which needs it to go to a dealer to be re-educated.
f.
Villers
PostPosted: 22:33 - 29 Dec 2008    Post subject: Reply with quote
I understand that settings 'change' whilst on the run but 'learning' and subsequent retaining for the next time its run seems pointless to me. I know that ECU's adjust fueling etc for engine temp, air temp and stuff and that makes sense as every day there is different ambient temperatures, more moisture about in the air and stuff. The learning bit would need the ECU to find out what is perfect and not perfect about that particular engine and then apply it, but again that would be like the first instance where it starts fresh every time and simply adapts.
Then to go on and wipe it to a safe point seems completely ludicrous Shocked
tutton
PostPosted: 22:34 - 29 Dec 2008    Post subject: Reply with quote
On most cars theres a backup, When we used to do it i think its about a 5 min before car forgets the set up and then they often struggle to start for a few seconds when reconnected, as the settings are cocked up, then the ecu (being a minicomputerjiggery) sets using the sensors on the cars. The only time this is a big issue is when youve had the car remapped etc i think?, as you can chip ecu's with fuel maps etc and stick em on without being on a battery for ages and itll be fine.
Similar to car radios if your battery goes flat you usually loose all the radio stations, unless theres a backup for the player.
Darth
PostPosted: 23:09 - 29 Dec 2008    Post subject: Reply with quote
Interesting direction this thread has taken! When i had my skyline it was always advised to me to disconnect the battery after doing any new minor mods to allow the ECU to relearn - just go out and let it warm up and then give it a good thrashing basically. Obviously major mods required remapping.
Any ways to the original problem - jumped it. Car and bike both seem happy. Bike especially so - is much more spritely now both front calipers are free and clean! Smile
Villers
PostPosted: 23:40 - 29 Dec 2008    Post subject: Reply with quote
Nice one!
Sorry for running off at an angle for a moment there Thumbs Up
The last post was made 17 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 89.55 Kb
