| Darth |
 Darth World Chat Champion
| G |
 G The Voice of Reason
| Itchy |
 Itchy Super Spammer
 Posted: 21:05 - 29 Dec 2008 Post subject: |
Although I don't know what the bike is (could be a scootay?) bump start it...
Clutch in
Ie stick it in 2nd , run with the ignition on erm ON, run to about 5-10mph let out the clutch jump on the seat at the same time to give bit more traction on the rear wheel , a small bike <500cc should bump easily , I can do it on the NTV easy in as little as 10ft. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Darth |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 21:23 - 29 Dec 2008 Post subject: |
| G wrote: | I've done it many times, not a problem.
Some would say it can damage fancy electronics, but if you don't have the car running, really can't see it being an issue.
Not that I ever have, but might be worth unplugging the terminals on the car to be sure nothing happens to the car electronics. |
As you say, no problem jumping off a car - but if your bike battery has been flat for a while, it might not hold charge any more
As for removing the terminals on the car, I wouldn't recommend that, most modern cars store the ECU settings in memory. Remove the battery, and it goes back to default. It'll run fine on default, but it will then need costly 'computer time' to get it back to idyllic settings .. this might be necessary for modern cars MOTs as they are pretty strict ... also the default setting is bound to run a bit richer, therefore a waste of fuel  ____________________ The purpose of life is to fight maturity. |
| Villers |
 Villers World Chat Champion
| Blue_SV650S |
 Posted: 21:41 - 29 Dec 2008 Post subject: |
| G |
| Villers |
| Blue_SV650S |
| finpos |
 finpos World Chat Champion
| Villers |
 Posted: 22:33 - 29 Dec 2008 Post subject: |
I understand that settings 'change' whilst on the run but 'learning' and subsequent retaining for the next time its run seems pointless to me. I know that ECU's adjust fueling etc for engine temp, air temp and stuff and that makes sense as every day there is different ambient temperatures, more moisture about in the air and stuff. The learning bit would need the ECU to find out what is perfect and not perfect about that particular engine and then apply it, but again that would be like the first instance where it starts fresh every time and simply adapts.
Then to go on and wipe it to a safe point seems completely ludicrous  ____________________ RS125 > CBR6 > SV650S > ZX636R > GSX1300RZ Hayabusa > 06 RSVR Mille > SV1000S > Street Triple 765 RS |
| tutton |
 tutton World Chat Champion
| Darth |
 Posted: 23:09 - 29 Dec 2008 Post subject: |
Interesting direction this thread has taken! When i had my skyline it was always advised to me to disconnect the battery after doing any new minor mods to allow the ECU to relearn - just go out and let it warm up and then give it a good thrashing basically. Obviously major mods required remapping.
Any ways to the original problem - jumped it. Car and bike both seem happy. Bike especially so - is much more spritely now both front calipers are free and clean!  |
| Villers |
 Posted: 23:40 - 29 Dec 2008 Post subject: |
Nice one!
Sorry for running off at an angle for a moment there  ____________________ RS125 > CBR6 > SV650S > ZX636R > GSX1300RZ Hayabusa > 06 RSVR Mille > SV1000S > Street Triple 765 RS |
The last post was made 17 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
