What size bolts please? BMW K1200S
Alkydale
PostPosted: 11:10 - 31 Dec 2008    Post subject: What size bolts please? BMW K1200S Reply with quote
The ones which hold the front disc to the wheel please? And will I be OK using stainless? BMW K1200S.
Thank you Smile
PostPosted: 11:18 - 31 Dec 2008    Post subject: Re: What size bolts please? BMW K1200S Reply with quote
Ideally you should use official disc bolts - these are actually designed to 'stretch' slightly when done up I believe. They often have a specific shoulder design too.
metal ken
PostPosted: 11:26 - 31 Dec 2008    Post subject: Reply with quote
It has been a while since have worked on Any K1200 models, can't remeber the bolt size, But you will have to watch if you put stainless ones in, i can't quite remember about the K1200 range but some bolts and other parts are made of a metal that is sacrificial, which will start to corrode before wheels which are made of magnesium alloy
Found this little bit on the net giving a brief explanation.
In electrochemistry, a more reactive metal used to protect a less reactive metal from corrosion. When the two metals are in close contact, the more reactive will always react first. For example, zinc is used as a coating to protect steel (galvanization), chromium electroplating is used for the protection of steel and other alloys, and iron may be connected to magnesium or aluminium to prevent rusting.
As said the BMW ones are designed for that bike, would keep to standard ones myself.
Ken Thumbs Up
My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400
Alkydale
PostPosted: 11:44 - 31 Dec 2008    Post subject: Reply with quote
Thanks guys, will stick to originals to be on the safe side, cheers and Happy New Year Very Happy
Walloper
PostPosted: 13:08 - 31 Dec 2008    Post subject: Re: What size bolts please? BMW K1200S Reply with quote
Do you mean Bolt Grade?
This refers to a Rockwell scale or SAE/ISO/API and other specifications.
All bolts are designed to stretch as the stretch is a functional part of the fastener that keeps things together.
The grade determines exactly how much stretch a bolt can withstand before it fails or loses its elastic properties.
Stretched beyond it's elastic limit by component loading or over torquing during assembly and the bolt will not retain the parts with sufficient force. Possible work it's self slack.
This is why it is important to use a torque wrench to tighten critical items.
To get back on topic. I would not fuck about with brake components unless I was certain the parts I was using were compatible with OEM spec.
Some OEM recommend not re-using certain bolts and to fit new.
This is possibly due to a locking compound pre applied to the bolts. I have re-used this type of bolt and not had any come-back.
You must ensure the threads are spotlessly clean and apply a good thread locking compound though.
PostPosted: 13:13 - 31 Dec 2008    Post subject: Reply with quote
Some bolts are meant to be single use stretch bolts, which do not stretch the same way when reused (and serious bolts like this tend to be done to a specific lowish torque and then tightened through a certain further angle.
For brakes I would stick to OE bolts, or equivalent ones designed for that use.
Alkydale
PostPosted: 13:16 - 31 Dec 2008    Post subject: Reply with quote
Thanks guys for the further answers. I will stick with OE bolts, I just want to change them as they have corroded and look a bit tatty, so much for BMW build quality......
HAPPY NEW YEAR!!!!
The last post was made 17 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 53.71 Kb
