few questions..
RooRoo
Anal Intruder
PostPosted: 20:02 - 05 May 2004    Post subject: few questions.. Reply with quote
when on the center stand and in first gear when i use the back brake the engine cuts out, just dies, not sure why..also, having not done yb cbt yet i tried to use it in the garden and as soon as i put it into first gear it stalled, when it was in first gear the bike kept moving (slowly) and i had to brake to stop it going,..
carvell
Scuttler
PostPosted: 20:04 - 05 May 2004    Post subject: Reply with quote
Your clutch will need adjusting.
There will be a guide floating about on here or around the net about making small adjustments to the clutch. It's a pretty standard procedure and applies to most bikes.
Yamaha TDM 850
RooRoo
Anal Intruder
PostPosted: 20:09 - 05 May 2004    Post subject: Reply with quote
also, why would braking in first gear kill the engine?
PostPosted: 20:11 - 05 May 2004    Post subject: Reply with quote
Why do you think? It stops the bloomin' engine from turning!!! Wink
RooRoo
Anal Intruder
PostPosted: 20:16 - 05 May 2004    Post subject: Reply with quote
so what when you're on the road going at 50 and you brake to slow down your engine just cuts out?
Robby
Dirty Old Man
PostPosted: 20:18 - 05 May 2004    Post subject: Reply with quote
No. But if the revs get too low, it will stall. Of course the fact you are rolling along keeps it going.
RooRoo
Anal Intruder
PostPosted: 20:21 - 05 May 2004    Post subject: Reply with quote
i dont wanna adjust my clutch myself, how much will a garage charge?
PostPosted: 20:28 - 05 May 2004    Post subject: Reply with quote
Don't get a garage to do it.
If you do, they'll see you coming a mile off as someone who doesn't know anything about bikes and charge you a rip off price.
Find someone who knows what they are doing and get them to show you. If you learn how its done you are more likely to be able to fix/diagnose problems next time.
I can't stress enough how much easiler life is if you learn to do basic maintenance. If you don't have anyone who can show you then I suggest you look for a decent workshop/haynes manual. Thumbs Up
RooRoo
Anal Intruder
PostPosted: 20:32 - 05 May 2004    Post subject: Reply with quote
I can get a friend to come over to do it for me, hes good at them..what tools would he need to adjust the clutch and change the lughtbulb?
carvell
Scuttler
PostPosted: 20:35 - 05 May 2004    Post subject: Reply with quote
It really is very simple - do it yourself. As Mark says, it is important that you learn some basic maintenance.
Say you are stuck at the side of the road, a mechanic says he can come out in 3 hours. You sit there waiting, he turns up, twiddles a little knob to adjust the clutch, charges you £100 and drives off.
If you do take it to a garage, ask them if they can show you how to do it whilst they do it, they may well show you a few other bits 'n' bobs too, if they are nice!
The more basic maintenance you learn the better. Thumbs Up
Yamaha TDM 850
RooRoo
Anal Intruder
i justr phoned him and he told me i need to use the clutch to a: brake, and b: stay still when you're not moving..
RooRoo
Anal Intruder
PostPosted: 20:37 - 05 May 2004    Post subject: Reply with quote
okay ill try the clutch then...the only problems i have are A: the engine cutting out when i brake (which apparenbtly isnt a problem) and B: when on the center stand and i put the bike in first it goes fine, but its on the ground it just stalls
carvell
Scuttler
PostPosted: 20:39 - 05 May 2004    Post subject: Reply with quote
Erm...did you pull the clutch in when you were engaging first gear..?
Your friend is sort of wrong on both counts. What the clutch does is basically disengage the back wheel from the engine. This allows you to change gear, and keep the engine running without the back wheel moving.
To move off with a motorbike you pull in the clutch, select first gear, and balance the throttle and clutch as you move off.
You use the engine combined with the brakes to slow down, and you pull the clutch in just before the back wheel stops moving, to stop the engine stalling.
I'm sure Mark or Keith could give you a better explanation of how the whole system works.
These two "problems" sound perfectly normal - you have to pull the clutch in before you come to a standstill when braking.
You are probably not controlling the clutch and throttle properly when the bike is off the centre stand.
You don't sound like you know an awful lot about how to control amotorbike - it's completly different to a moped, it's not "twist and go". We all have to start somewhere, I spent many hours stalling my first bike up and down the garden! Get your friend to show you the basic controls of the bike and how to move off etc.
Yamaha TDM 850
RooRoo
Anal Intruder
PostPosted: 20:42 - 05 May 2004    Post subject: Reply with quote
well i pulled the clutch in, put it in first, released clutch, then tried accelerating which resulted in the bike shooting foward and stalling, did i do it wrong? with braking, i just held down the brake until the engine died, i didnt know i had to use the clutch just before i stop moving, does that mean at traffic lights you have to hold the clutch down?
carvell
Scuttler
PostPosted: 20:45 - 05 May 2004    Post subject: Reply with quote
Yes, you did.
You need to feather the clutch out and balance it with the throttle. It takes a while for you to get this technique sorted.
Yes, you need to hold the clutch in at traffic lights.
A better idea would be to put it in neutral at traffic lights, then put it in first on amber, and move off on green, balancing the clutch and throttle as you do so.
The best bit of advice I had was "don't let the clutch completly out until you hit 10mph". This should help you to get the technique.
Yamaha TDM 850
RooRoo
Anal Intruder
hehe, i know nothing..will the cbt teach me this stuff?
RooRoo
Anal Intruder
PostPosted: 20:47 - 05 May 2004    Post subject: Reply with quote
ah okay, one last question i have is, why would the wheel turn on center stand in first, yet when on the ground stall?
carvell
Scuttler
PostPosted: 20:48 - 05 May 2004    Post subject: Reply with quote
Yep - the CBT assumes you know literally nothing about a motorbike.
The fact that you're learning off the forum will mean you will have an advantage! Smile
Yamaha TDM 850
carvell
Scuttler
PostPosted: 20:50 - 05 May 2004    Post subject: Reply with quote
Does it turn with the clutch in?
If so, this is normal and is just a bit of clutch slipping as there is no resistance on the wheel.
If you did not have the clutch in then you have managed to fluke getting the bike going on the centre stand, as there is no resistance on the back wheel it will be very easy to get the back wheel going.
When the wheel is touching the ground you will need to balance the clutch and throttle properly, as you have to move your weight plus the weight of the bike etc. When you have the technique mastered it will all be fine. Smile
Yamaha TDM 850
RooRoo
Anal Intruder
PostPosted: 20:56 - 05 May 2004    Post subject: Reply with quote
thanks a lot guys Very Happy which leaves me with one final task of replacing the bulb in my spider egg infested speedo...
carvell
Scuttler
PostPosted: 20:58 - 05 May 2004    Post subject: Reply with quote
No problem!
Good luck with your CBT. Very Happy
Yamaha TDM 850
PostPosted: 21:02 - 05 May 2004    Post subject: Reply with quote
yes, but you kinda need to know what a clutch is and what gears are etc before you go. Get someone to explain it.
The clutch really is just a way of controlling the amount of power going from the engine to the back wheel when the throttle isn't enough, IE when you need to change gear or when the engine might stall. The throttle gives you control over how quickly the engine revs, but the engine can't rev slowly enough to get you going, so you feed in the power by using the clutch. Think of the clutch like two wheels with sandpaper on that touch each other face to face. When you pull the clutch, the wheels move apart, and when you let it out the plates move together. If yuou think the wheel that is connected to the engine is always spinning, then you need to let the wheels grip each other slowly, otherwise the spinning wheel will suddenly stop (a stall) or the stopped wheel will suddenly start spinning (you wheelie away from a standstill and crash).
To be honest I'm surprised that they don't teach this kind of stuff in schools! After all I think it would be much more useful to me to learn this in a science or techology lesson than what the anatomy of the male and female parts of a plant is, or why a clock radio is the shape it is.
Give me mechanical engineering any day! Smile
carvell
Scuttler
PostPosted: 21:04 - 05 May 2004    Post subject: Reply with quote
Biology tells us where we have been.
Engineering tells us where we are going.
I know which I'd rather know. Thumbs Up
Yamaha TDM 850
RooRoo
Anal Intruder
PostPosted: 21:07 - 05 May 2004    Post subject: Reply with quote
you know what, i think those b astard spiders are the reason my speedo light isnt working..
The last post was made 21 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 122.12 Kb
