| RooRoo |
 RooRoo Anal Intruder
| carvell |
 carvell Scuttler
| RooRoo |
| MarJay |
 MarJay But it's British!
 Posted: 20:11 - 05 May 2004 Post subject: |
Why do you think? It stops the bloomin' engine from turning!!!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| RooRoo |
| Robby |
 Robby Dirty Old Man
| RooRoo |
| MarJay |
 Posted: 20:28 - 05 May 2004 Post subject: |
Don't get a garage to do it.
If you do, they'll see you coming a mile off as someone who doesn't know anything about bikes and charge you a rip off price.
Find someone who knows what they are doing and get them to show you. If you learn how its done you are more likely to be able to fix/diagnose problems next time.
I can't stress enough how much easiler life is if you learn to do basic maintenance. If you don't have anyone who can show you then I suggest you look for a decent workshop/haynes manual.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| RooRoo |
| carvell |
 carvell Scuttler
 Posted: 20:35 - 05 May 2004 Post subject: |
It really is very simple - do it yourself. As Mark says, it is important that you learn some basic maintenance.
Say you are stuck at the side of the road, a mechanic says he can come out in 3 hours. You sit there waiting, he turns up, twiddles a little knob to adjust the clutch, charges you £100 and drives off.
If you do take it to a garage, ask them if they can show you how to do it whilst they do it, they may well show you a few other bits 'n' bobs too, if they are nice!
The more basic maintenance you learn the better.  ____________________ Yamaha TDM 850 |
| RooRoo |
| RooRoo |
| carvell |
 carvell Scuttler
| RooRoo |
| carvell |
 carvell Scuttler
 Posted: 20:45 - 05 May 2004 Post subject: |
| RooRoo wrote: | well i pulled the clutch in, put it in first, released clutch, then tried accelerating which resulted in the bike shooting foward and stalling, did i do it wrong? |
Yes, you did.
You need to feather the clutch out and balance it with the throttle. It takes a while for you to get this technique sorted.
| RooRoo wrote: | with braking, i just held down the brake until the engine died, i didnt know i had to use the clutch just before i stop moving, does that mean at traffic lights you have to hold the clutch down? |
Yes, you need to hold the clutch in at traffic lights.
A better idea would be to put it in neutral at traffic lights, then put it in first on amber, and move off on green, balancing the clutch and throttle as you do so.
The best bit of advice I had was "don't let the clutch completly out until you hit 10mph". This should help you to get the technique. ____________________ Yamaha TDM 850 |
| RooRoo |
| RooRoo |
| carvell |
 carvell Scuttler
 Posted: 20:48 - 05 May 2004 Post subject: |
Yep - the CBT assumes you know literally nothing about a motorbike.
The fact that you're learning off the forum will mean you will have an advantage!  ____________________ Yamaha TDM 850 |
| carvell |
 carvell Scuttler
| RooRoo |
 Posted: 20:56 - 05 May 2004 Post subject: |
thanks a lot guys which leaves me with one final task of replacing the bulb in my spider egg infested speedo... |
| carvell |
 carvell Scuttler
 Posted: 20:58 - 05 May 2004 Post subject: |
No problem!
Good luck with your CBT.  ____________________ Yamaha TDM 850 |
| MarJay |
 Posted: 21:02 - 05 May 2004 Post subject: |
yes, but you kinda need to know what a clutch is and what gears are etc before you go. Get someone to explain it.
The clutch really is just a way of controlling the amount of power going from the engine to the back wheel when the throttle isn't enough, IE when you need to change gear or when the engine might stall. The throttle gives you control over how quickly the engine revs, but the engine can't rev slowly enough to get you going, so you feed in the power by using the clutch. Think of the clutch like two wheels with sandpaper on that touch each other face to face. When you pull the clutch, the wheels move apart, and when you let it out the plates move together. If yuou think the wheel that is connected to the engine is always spinning, then you need to let the wheels grip each other slowly, otherwise the spinning wheel will suddenly stop (a stall) or the stopped wheel will suddenly start spinning (you wheelie away from a standstill and crash).
To be honest I'm surprised that they don't teach this kind of stuff in schools! After all I think it would be much more useful to me to learn this in a science or techology lesson than what the anatomy of the male and female parts of a plant is, or why a clock radio is the shape it is.
Give me mechanical engineering any day!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| carvell |
 carvell Scuttler
 Posted: 21:04 - 05 May 2004 Post subject: |
Biology tells us where we have been.
Engineering tells us where we are going.
I know which I'd rather know.  ____________________ Yamaha TDM 850 |
| RooRoo |
The last post was made 21 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
