PS3 Online
Courageous T
PostPosted: 21:38 - 05 Jan 2009    Post subject: PS3 Online Reply with quote
Hi,
Got my own PS3 the other day(have been using brothers) and have been trying to connect wirelessly(brothers is wired). It works sometimes but often i can only get internet browser to work and not able to sign into PSN. Really annoying. The router is pretty far away from my own room though and sometimes the signal is not so good, this is probably why isn't it?
cheers
Kwaks
I'm not a fast rider
PostPosted: 21:45 - 05 Jan 2009    Post subject: Reply with quote
Most prob, i kept having a fluctuating signal on xbox live when the wireless router was only 15 ft away, ended up going back to wired.
The wireless signal can also be getting interference from other electrical appliances in the home
www.cliqueycuntsmcc.co.uk
DanceLikeAMon...
PostPosted: 22:40 - 05 Jan 2009    Post subject: Reply with quote
Yeah, exactly same problem I had with wireless and in the end went to a wired connection.
Since my router is a couple of rooms away from my living room I went to PC world and bought a couple of those network adaptors that go into your plug sockets and wired it through them. Actually downloads slightly faster than my PC now and never have any disconnection problems.
Courageous T
PostPosted: 22:46 - 05 Jan 2009    Post subject: Reply with quote
cheers for replies, can u get me a link for those adaptors or something?
So they just plug into the wall and then the wire goes into the playstation and it works as if im wired?
cheers
DanceLikeAMon...
PostPosted: 22:56 - 05 Jan 2009    Post subject: Reply with quote
The ones I got from PC World was the Advent Starter Kit 85 Mbps Powerline twin pack. £40 if you reserve it online or get it delivered, £63 off the shelf.
You just plug one in near your PS3 and one in near your router and then connect the router and the PS3 to the plugs using an ethernet cable. Easy as that.
Oh yeah, and it is just as fast as a wired connection - because that's basically what it is.
Visitor Q
$25 whore
PostPosted: 04:13 - 06 Jan 2009    Post subject: Reply with quote
My mate tried that with a netgear, but it just suddenly died and the support is in yankee land Evil or Very Mad
We currently resort to moving the PS3 periodically to different positions, using anything available, to get high signal.
I keep telling him to wire it, but his mum has (basically) got OCD, and the chance of a wire going unpunished from upstairs to down is nil.
tribal_tiger
PostPosted: 08:52 - 06 Jan 2009    Post subject: Reply with quote
Now I had a few problems with my PS3 this weekend. I was finding internet was fine, but games kept crashing out as soon as I started playing them online.
It turned out my PS3 was connected using NAT3 instead of NAT2.
To sort this out I had to configure my PS3 to have a static IP and then config the router to put that IP in a DMZ, remove the address from DHCP so my PC doesn't steal it, and then allow direct port transfer for the following
TCP: ports 80, 443, 5223
UDP: ports 3478, 3479, 3658
After all this I now get NAT2 and all my network problems have been sorted!
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
LimehouseCBF
PostPosted: 12:25 - 06 Jan 2009    Post subject: Reply with quote
i had similar problem with mine however it was so easy to solve but easy to forget - come routers require you to select "pairing mode", i could find my router but it wouldnt connect - when i pressed the pair mode on the router worked fine, so have a search mine was i had to switch channels
And on the 7th day the lord said..lets get pissed
The last post was made 17 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 55.86 Kb
