CRB check
Pie-Roe
PostPosted: 01:03 - 04 Jan 2009    Post subject: CRB check Reply with quote
Hi all, quick one, I'm thinking of applying for a new job, same sector but working in a hospital.
However it requires a disclosure check thing, but I got a reprimand when I was 17. I was told this would be wiped when I turned 18, but is this the case?
Pyro
BBCTom
PostPosted: 01:12 - 04 Jan 2009    Post subject: Reply with quote
Yep, it will have been wiped when you were 18. Also, a reprimand/caution is not a criminal conviction therefore you are not at liberty to disclose such information. If you are asked its always best to 'come clean', but it will certainly not show up on the CRB check.
Hope this puts your mind at rest
Tom Smile
GSXR600 Corona Alstare SRAD + Race Tuned Aprilia SR125 Very Happy see public bio for specs.
steppen22
PostPosted: 14:16 - 04 Jan 2009    Post subject: Reply with quote
public sector application forms usually require details of any time spent in the company of the plice, including cautions.
Fill out the form honestly.
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
AC
PostPosted: 14:52 - 04 Jan 2009    Post subject: Reply with quote
be trueful and state you were reprimanded at 17, the reason (public disturbance etc) that way if it does get mentioned on a CRB check (and that will depend on the type of CRB check that is carried out and what the reprimand was for) you are covered and not caught out with lying by omission.
It doesnt necessarily have to be put on your application form but via an informal chat with the team advertising the job, to get an idea if it would affect the job application.
Tim.
PostPosted: 17:51 - 04 Jan 2009    Post subject: Reply with quote
CRB is simply the department that carrys out the check.
There are 2 main types of check - The CRC and the CTC.
Make sure you are clear what is being asked for first.
If its for a CRC (criminal records check) then I would recommend that you DO NOT reveal that you were reprimanded.
UNLESS specifially asked for it.. ie: if the application form itself says "have you ever been reprimanded".
The reason I say this is that the CRC check wil NOT show any spent convictions or reprimands. (note: certain convictions are never spent .. such as murder, rape, serious assault ,etc)
You have obviously moved on and there is no need for you to drag this up again - so dont own up to something they are not asking you to!
It may be nice to think that its all private and decent being open - but life isnt like that and it could act against you later in your career / life.
However, a CTC (counter terrorist check) is different.
This is usually required by those working in Airports or
That bad boy is carried out by MI (whatever number - 5 ?) and they will report on every single clash with the law - even pre adulthood.
It even looks at the background of immediate relatives.
PM me if you need any further info or have any trouble.
But the extract below says it all for you really:
Cautions, reprimands and final warnings are not criminal convictions and so are not dealt with by the Act. So if people with cautions, reprimands or final warnings only are asked whether they have any 'criminal convictions' they can answer 'no'. Sometimes people are asked if they have a 'criminal record'. This is a less precise term, but it is usually understood to mean convictions. So people who are asked if they have a 'criminal record' may also answer 'no' if they have no convictions.
However, people who are specifically asked if they have cautions, reprimands or final warnings should disclose them until they are deleted from police records. Records of cautions should be deleted after five years if there are no convictions on the record. (In practice, some police forces may retain records of cautions for much longer than this or indefinitely.)
Moonie
PostPosted: 21:40 - 04 Jan 2009    Post subject: Reply with quote
Would be helpful if you could tell us what the job was.
I was meant to be helping with my mums youth group, and I did when I was 15 (they're like 6-10) but then when I turned 16 I couldn't because The CRB would have revealed drugs convictions.
Peter3hg
PostPosted: 16:44 - 05 Jan 2009    Post subject: Reply with quote
I'm pretty sure that you can't even have a CRB check done until you turn 18.
DANKZii
PostPosted: 18:26 - 05 Jan 2009    Post subject: Reply with quote
You can have them done pre-18.
People in my 6th form (16/17) are having them for Duke Of edinbourough etc, if part of their corse means working with children.
nasty
PostPosted: 14:08 - 06 Jan 2009    Post subject: Reply with quote
Don't even worry about it Pyro Thumbs Up
The last clearance level I was put in for by a company I worked for involved far worse checks than what you're going to have to do, they interviewed you and members of your family, checked bank accounts and your financial history, in detail. Checked your ISP for any suspicious activity, phone records. They left no stone unturned, literally! Some people even said your phone got tapped when you gained the clearance. Afterwards you are constantly being monitored for anything and everything that could indicate a threat.
I'd been arrested a few times and been banned from driving etc etc blah blah and it didn't worry me.
As long as it's nothing serious like armed robbery, sex offending etc then you'll be ok, trust me Thumbs Up
ZX6R F3
s44678
Guest
PostPosted: 10:30 - 08 Jan 2009    Post subject: Reply with quote
I think this is pretty standard now for anyone working with children or 'vulnerable adults'. I wouldn't worry about it even if it did show up (which by the sounds of the very informative post above it won't). They aren't trying to suss you out, just covering thier backs. Even if you nicked a car or smacked someone I don't think it would affect your chances of getting the job. They just want to check you don't have previous convivtions for sticking your willy into comatose old people or something, which would obviously cause problems if they were to let you loose in a hospital.
Pie-Roe
PostPosted: 15:17 - 08 Jan 2009    Post subject: Reply with quote
Darn, you found me out Laughing no it was for a very trivial matter that has no relevance to anything really in preventing getting any kind of job.
Thanks for all the advice
pyro
Clanger
Stirrer
PostPosted: 12:32 - 24 Jan 2009    Post subject: Reply with quote
Declare it. It probably won't make a blind bit of difference...
The last post was made 17 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 73.99 Kb
