Coolant mixing with engine oil.....kawasaki ER5
Jamie S
PostPosted: 20:57 - 10 Jan 2009    Post subject: Coolant mixing with engine oil.....kawasaki ER5 Reply with quote
Been for a run today (dad on the ER me on the TS) Did just over 150 miles, and when we got back I noticed that the ER coolant had mixed with the oil making a grey emulsified sludge in the sight glass.
The Expansion tank is empty so it seems fairly sure that it is coolant and not just condinsation.
Is this a common fault with ER's? If so what causes it?
The causes I can think of are
1) The head could be warped
2) Cracked cylinder block
3) Water pump seal leaking
4 Head gasket failure
Is there any easy way to determine which might be the cause? I don’t really want to pull the engine apart if I can avoid it.
PostPosted: 21:02 - 10 Jan 2009    Post subject: Reply with quote
My first thought was head gasket....
Jamie S
PostPosted: 21:16 - 10 Jan 2009    Post subject: Reply with quote
Just dropped the oil and it's fine ..... Thinking
It's lost coolant and has a cloudy sight glass, yet the oil is like normal..... Confused
Ichy
Its a bit vague but usually if the leak is the head or the cylinders then it tends to pressurise the system causing coolant to blow out.
I seem to remember that they can leak around the thermostat but that shouldn't get into the engine?
I'd check all the hose connections and water pump housing first, its easy if nothing else.
Whosthedaddy
PostPosted: 21:34 - 10 Jan 2009    Post subject: Reply with quote
My little brains first thought was check for a leak before stripping engine bits unnecessary.
Was the expansion chamber and fluid actually correct and topped up or has it been going down rapidly lately? If the oil is fine but you have some gloop in the sight glass and tubing then it could just be a coincidence and a small leak.
PostPosted: 21:42 - 10 Jan 2009    Post subject: Reply with quote
From what you say about the oil appearing fine and with the cold weather it could be that the stuff on the oil window is from condensation. I presume that going at the speed of the TS in this weather the bike had just not managed to warm up.
Was the coolant level in the ER OK before you set off?
Jamie S
PostPosted: 22:05 - 10 Jan 2009    Post subject: Reply with quote
Hi, the coolant level was fine around a week ago, it has only been to the petrol station and back (5 mile), and the run today (150 mile)since it was last checked basicaly,the level was fine when it was last checked.
Ariel Badger
PostPosted: 22:08 - 10 Jan 2009    Post subject: Reply with quote
I would not worry Jamie. I think the bike needs to get hot and clear the condensation.
Well done on 150 miles in this weather BTW.
Ichy
PostPosted: 22:19 - 10 Jan 2009    Post subject: Reply with quote
Since its not mixing with the oil then it must be leaking outwards.
I would fill it up and leave it standing for a few hours (got a center stand?). Go back and see if there are any drips or a pool of water.
Next I would start it up and let it run, revving it a bit while checking for drips, steam, or obvious leaks.
PostPosted: 23:10 - 10 Jan 2009    Post subject: Reply with quote
Agree with the above, but has any work been done on it recently?
Most dodgy place for a coolant leak would be the O rings where the metal water pipes join the head.
Dalemac
PostPosted: 02:17 - 11 Jan 2009    Post subject: Reply with quote
yes, and if these o-rings are not sealed properly, coolant will leak from a hole in the side of the head in between the engine fin things, then collect at the front of the engine.
however as stated above, when its cold and the bike has stood (even overnight) water can collect and get mixed with the oil, tainting the colour. it needs to burn off the excess water, but it really needs to get warm to do this properly.
Dale
YBR125 -> GPZ500S -> SL1000
There is a gap of 11 years, 159 days between these two posts...
martin3863
PostPosted: 16:26 - 16 Jun 2020    Post subject: Reply with quote
kawasaki er 5 water in oil steamed up window emuslified white oil, water pump seals two one spring loaded one oil sel type cost 25 pounds aprox slight crack in spring loaded one giveing direct lleak into crank case dissemble water pump replace .|..
The last post was made 6 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 75.22 Kb
