Puncture advice
wizzzard
PostPosted: 12:07 - 12 Jan 2009    Post subject: Puncture advice Reply with quote
When i got to work this morning i noticed my back tyre was a little low on air, after just going to check on it its flat as flat can be.
I have had a good ring round all the tyre centers around here and none will do a bike repair for some reason.
Does anyone know of any of the larger stores that either plugs tyres or at least sells the kits for emergencys.
Probably should have put this in workshop but im kind of desperate to get it sorted.
PostPosted: 12:09 - 12 Jan 2009    Post subject: Reply with quote
Ring the nearest bike garage. To be fair most places that do bike tyres should be able to plug it provided it isn't too near the sidewall.
Graprilia
PostPosted: 12:11 - 12 Jan 2009    Post subject: Reply with quote
i took mine recently to ATS , but like most places they insist your remove the wheel first, then take it to get plugged.
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
kitty kat
PostPosted: 12:24 - 12 Jan 2009    Post subject: Reply with quote
ATS did mine for me a while ago, luckily though I work in the shop next door to them, but they will plug punctures in bike tyres for you
wizzzard
PostPosted: 12:43 - 12 Jan 2009    Post subject: Reply with quote
Thanks very much for the replies it seems im hitting a brick wall because nobody here will touch the speed rating on a 750 tyre. Ill keep trying if not its a new tyre for me.
Blue_SV650S
PostPosted: 13:12 - 12 Jan 2009    Post subject: Re: Puncture advice Reply with quote
Have you actually isolated where the puncture is? or if it is a puncture at all (could be a leaking valve).
You need to check where the puncture is (or if it is a puncture) before going any further. If the puncture is in the 'wrong' place, it can't be repaired.
wizzzard
PostPosted: 13:26 - 12 Jan 2009    Post subject: Reply with quote
Its definately a puncture and its pretty much center of tyre so if anything is repairable that should be.
Blue_SV650S
PostPosted: 15:11 - 12 Jan 2009    Post subject: Reply with quote
Ok, cool.
Surely your nearest bike shop can sort you out?
wizzzard
PostPosted: 15:15 - 12 Jan 2009    Post subject: Reply with quote
Thanks again for the help iv managed to find one at last that will repair it for me but i tried most of the ones in the phone book and was told not a prayer at each one.
I thought it would be a lot easier to sort out a puncture, i will invest in an emergency plug kit for next time.
Walloper
PostPosted: 15:41 - 12 Jan 2009    Post subject: Reply with quote
Slime 8 quid a go Halfrauds.
***Walloper runs and takes cover from the 'Oh Never user Slime in a bike tyre' mortar attack***
If the tyre's on it's last life then what harm is there?
ps Make sure the garage air pump is 'working' before pulling the valve out the wheel though Embarassed
Blue_SV650S
PostPosted: 15:48 - 12 Jan 2009    Post subject: Reply with quote
Walloper wrote:
Slime
A note about that stuff ...
If that is put in the tyre, it deems the tyre non repairable 'properly' i.e. you can't use it to get you out of trouble, then get a garage to fix it properly after.
PostPosted: 09:28 - 13 Jan 2009    Post subject: Reply with quote
Blue_SV650S wrote:
Walloper wrote:
Slime
Spot on, although I thought it could still be repaired sometimes. All down to the luck of the draw.
stokeheingeri...
PostPosted: 11:56 - 13 Jan 2009    Post subject: Reply with quote
why not but a plug repair kit and do it yourself??
most bike shops will have them in stock
[email protected]
ring us on 01782 612111
www.4theride.co.uk
Walloper
PostPosted: 14:14 - 13 Jan 2009    Post subject: Reply with quote
I have used slime in bike tyres, wheel barrow tyres and have had it in my car tyre now for two years. No problemo...
Whoever says it deems the tyre unrepairable is talking horse shite.
This next bit is true though:
I have found a lot of lazy bastarts who own/operate/or work (Loosest sense of the word) selling/fitting tyres.
You can wash slime out of the tyre using plain water. They do not like the extra hassle when they budget their by the hour rate to repair tryes. It just costs more.
You MUST abrade any tyre back to base carcass before applying plugging solvent. So any 'activated' slime will be removed anyway if properly prepared for repair.
So slime will not damage a tyre.
Agreed if the tyre has been injured past the point of a structurally sound repair or is in sidewall you will need a new tyre. Karma
neatbik
PostPosted: 14:22 - 13 Jan 2009    Post subject: Reply with quote
Any tyre with a z speed rating or above cant legally be repaired.
I would be wary of getting one repaired to be honest - running around the tyre are kevlar belts, if a screw goes in and tears one or two of these then it will potentially affect the strength of the tyre.
Obviously the chances of this happening are quite slim, its up to you if you want to risk it or not. Confused
Blue_SV650S
PostPosted: 14:36 - 13 Jan 2009    Post subject: Reply with quote
Supposedly once the 'slime' is in the tyre, you cannot repair it because you can't get rid of the slime ... i.e. you can't stick the repair down inside Wink
That is what I was told/advised when thinking about getting some anyway ...
Walloper
PostPosted: 14:52 - 13 Jan 2009    Post subject: Reply with quote
https://www.slime.com/
https://www.slime.com/index.php?p=faq#answer_1401_loc
As pasted all over bcf you can read a lot of shite on T' Internet.
The skill is to read between the lines and ask the correct questions.
I have had tyres repaired/swapped from rim to rim at tyre fitter shops. They moan about it. If they refuse take you business elsewhere.
I don't think it would be objectionable to pay for two repairs if the question is time. Or let them remove the tyre and you can wash yourself.
They will try to sell you new rubber of course when ever they can
Rogues some of them Smile
Walloper
PostPosted: 15:03 - 13 Jan 2009    Post subject: Reply with quote
My opinion.
I use my bike/s 365 (if possible) I can't carry a spare and a flat is not funny.
I have ultraseal fitted in the tyres for insurance.
Some folk say it affect balance. Not noticed it below 120mph. You shouldn't be doing that on public roads anyway. Embarassed
Blue_SV650S
PostPosted: 17:33 - 13 Jan 2009    Post subject: Reply with quote
Walloper wrote:
"Can a tire treated with SLiME be professionally repaired?
Yes. When you get to the tire repair shop be sure to tell the service technician that your tire has SLiME tire sealant inside. SLiME is water soluble, non-toxic and non-flammable and can be rinsed away with water. Once the tire and rim are rinsed off they should be wiped down with a dry towel. The tire is now ready for a professional repair."
Interesting ... Thumbs Up
Also if it water soluble, how does it work in the wet?!!? Wink
Walloper
PostPosted: 18:23 - 13 Jan 2009    Post subject: Reply with quote
Awwwe... FFS....
Ahm no a flamin' chemist. Laughing
As it comes in contact with air it forms a scab over the hole. (Matrix/Mesh/Whatever)
I guess: There's a solvent which keeps the compound in solution when a tyre of a certain volume is charged with a specific amount of gloop. So it will remain in liquid form until it meets air and the volatiles are driven off. I think the heat and mechanical effects of the wound help to cure the stuff into a water resistant lump.
OK? Laughing
Blue_SV650S
PostPosted: 18:49 - 13 Jan 2009    Post subject: Reply with quote
Walloper wrote:
Awwwe... FFS....
OK? Laughing
'Comes into contact with air' ... I tend to put air in my tyres, don't you?!?! .... Laughing
I am of course being facetious at this point Wink .. its the same principle as paint in a pot ...
Walloper
PostPosted: 18:52 - 13 Jan 2009    Post subject: Reply with quote
To be as purnickety (as some like to be a bcf....)
You should put pure nitrogen in your tyre.
It is moisture free and will not support combustion in a fire.
But that's me splitting 'airs...
Blue_SV650S
PostPosted: 19:56 - 13 Jan 2009    Post subject: Reply with quote
Air is what 80% Nitrogen IIRC isn't it??!!? ... Wink ... air by itself is not going to be much worse for a fire .. than ... well the air (atmosphere) the burning bike is sat in is it!! Very Happy we are not putting pure oxygen in you know .. its plain old air ... sure it is under pressure, so more air per CC ... but its not really the largest fire risk on a bike is it!! Very Happy
People put pure nitrogen in as it is more stable on pressure over a range of temperature.
PostPosted: 20:42 - 13 Jan 2009    Post subject: Reply with quote
The ones I've seen suggest you keep under 40mph.
Not that I'd know that anecdotal evidence suggests you can do well over 3x that Whistle.
Walloper
PostPosted: 12:09 - 14 Jan 2009    Post subject: Reply with quote
I used to buy in tyres at US$10,000 a pop. about 1.7m US$/year. Tyres last longer in clean nitrogen. They do not catch fire if overheated (no oxygen to support combustion) causing blow-out and pressure was maintained saving fuel and improving traction. But that is splitting hairs to prove a point really.
For your perusal..
https://www.blackcircles.com/general/technology
"Why fill my tyres with Nitrogen?
Why would you want to do this? The benefits of Nitrogen filling are as follows:
* Improved comfort of ride
* Improved safety
* Increased fuel savings
* Improved life of tyre
Nitrogen has long been the accepted gas medium for filling aircraft tyres, racing tyres and heavy mining and construction vehicle tyres. Nitrogen is used for safety reasons and to ensure that tyres are always at a constant pressure. Compressed air, the traditional medium for inflating car tyres, contains both oxygen (21%) and nitrogen (78%).
The rubber tyre is like a membrane, through which oxygen permeates three times faster than the nitrogen. The result is that the oxygen slowly leaks out through the rubber walls, and the under-inflation leads to higher tyre wear with a consequent decrease in safety and comfort, and higher fuel costs."
https://suvs.about.com/od/tiresandwheels/a/nitrogentires.htm
" Ingersoll Rand claims that there are several distinct advantages to filling your tires with Nitrogen:
* Better air pressure retention -- Nitrogen doesn't seep out through the tire walls like Oxygen can, so tires remain fully inflated longer.
* Enhanced fuel economy -- Nitrogen dissipates heat faster than air, and heat causes rolling resistance. "Maintaining tire pressure can boost fuel economy by as much as 6 percent."
* Longer tread life -- Filling your tires with pure Nitrogen makes tires run cooler, which will reduce tire failure. It also prevents oxidation, which can cause tread separation and belt failure. Since Nitrogen doesn't carry moisture, it won't cause rust on the inside of rims and valve stems.
* Slow chemical aging -- "Filling a tire with Nitrogen also significantly slows the chemical aging process of the tire's rubber components." Very Happy
The last post was made 17 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 135.75 Kb
