service at dealership - very annoyed
adamcpi50sx08
PostPosted: 23:12 - 12 Jan 2009    Post subject: service at dealership - very annoyed Reply with quote
i bought my CPI SX50 in november brand new from a local dealership, it went for its 600 mile service and came back with the flywheel cover hanging off with two bolts missing (according to the mechanic they must have rattled out but nothing at all has rattled out for those 600 miles until they touched it, he put ATF gearbox oil (automatic transmission fluid) in a manual 6 speed box and according to him thats what the factory says they should run, i dont care what the factory says its common sense you dont put automatic gearbox oil in a manual gearbox (you would put diesel engine oil in a petrol car would you) and now it jumps out of gear randomly and misses the gear and hits neutral sometimes aswell, also i dont think the plug was changed either, i will be changing my gearbox oil tomorow with some castrol MANUAL gearbox oil from the garage i work at (with mechanics who acctually know things instead of doing everything out of a book) and anytime my bike goes to that garage (its under warranty there) i will be watching them very closely, so i say if you gotta take your bike to a garage u aint that familiar with watch what they take off and how its put back on and check that baby before you go because these guys aint touching my bike again unless they need to for warranty purposes
does anyone know what running the wrong gearbox oil could potentially do to the gearbox or if it can damage anything
CR 125 (OFFROADER) - DEP PIPE ETC
CPI 50 SX 2008 - NO MODS YET EXCEPT FROM A SET OF ACERBIS HANDGUARDS
RS2MATRIX
PostPosted: 23:16 - 12 Jan 2009    Post subject: Reply with quote
whats wrong with atf?
Reiju RS2 Matrix
Kawasaki ZXR400
adamcpi50sx08
PostPosted: 00:25 - 13 Jan 2009    Post subject: Reply with quote
its a manual gearbox so why should it need automatic transmission fluid, it needs proper motorbike manual gearbox oil not the water thin crap they put in mopeds etc
PostPosted: 00:47 - 13 Jan 2009    Post subject: Reply with quote
Have you checked what it's supposed to have?
I presume it's a 2stroke, which often take different oil as it is just a gearbox rather than the whole engine.
PostPosted: 01:40 - 13 Jan 2009    Post subject: Reply with quote
Six litre chevy V8 engines use ATF in their gearbox.
Check the specification in the users manual before sounding off and potentially embarrasing yourself.
If they were wrong, ATF is unlikely to do any damage in the short term but it would wear out a bit more quickly and should be replaced.
tafflade
PostPosted: 10:36 - 13 Jan 2009    Post subject: Re: service at dealership - very annoyed Reply with quote
so why do you question this?
are you a better engineer than the bloke that designed the thing?
Oh right, you do know best. Rolling Eyes
if my mechanics dont use the books supplied I want a fucking good reason why not, they cant possibly know everything
right up to the point where you put the wrong grade of oil despite being told the right stuff is in there.
get off your high horse and do everything yourself if you are ot happy with the garage mechanics. Wink
tafflade
PostPosted: 10:41 - 13 Jan 2009    Post subject: Re: service at dealership - very annoyed Reply with quote
I've hear of people using deisel engine oil in BMW boxer twins so yes to that one.
{A boxer twin is a bike engine by the way} Wink
https://www.therevcounter.com/mechanics/28524-oil-bmw-r1150.html#post567727
and a thread about oil that you may find very interesting.
https://www.ukgser.com/forums/showthread.php?t=91251
PostPosted: 13:09 - 13 Jan 2009    Post subject: Reply with quote
ATF is specified for the gearbox in some 2 stroke engines. I have no info on the CPI, but might be tempted to double check with the importers, but don't find it that unlikely.
As to using diesel oil in petrol car, yes people do it. Diesel oils tend to have higher levels of detergent and so are sometimes used for a while to flush through petrol engines.
If you use the wrong oil then yes you could do damage. And that applies just as much if you go and use gearbox oil in a box designed for AFT. Even using gearbox oil of the right viscosity but the wrong type in a car can cause major problems (eg, using a GL5 gearbox oil on a gearbox will brass synchro rings will trash the synchromesh, they need the older GL1 non EP oils).
iooi
PostPosted: 16:59 - 13 Jan 2009    Post subject: Reply with quote
Perhaps try contacting CPI Importers and ask them......
At least then if it is the guy at the shop thats wrong they can sort it out and get your engine fixed....
adamcpi50sx08
PostPosted: 23:26 - 13 Jan 2009    Post subject: Reply with quote
i know a brand new gearbox shouldnt be jumping out of gear into neutral 4 times in one gear and for the mechanic to seem to think its okay.
when the head mechanic told me to change the oil to the proper motorcycle gearbox oil i sed in the first place because he also didnt believe that it should be running on atf because it was too thin and would foam when its too hot as it was when i drained it.
the reason is that the gearbox oil it told them to run is not right, its funny how the bike was jumping out of gear all the time into neutral i put castrol mtx 2 stroke gearbox oil in today and its running and shiffting perfect see if the supplied books explain that then eh and i work in a garage mate and do you think i need a great big manual of every single car to diagnose a problem when it comes in
i would rather do it myself but they need to do the relevent service intervals for warranty purposes, atleast the stuff i take off when i do work on cars, bikes and anyway anything i work on goes back on the same as it was before i touched it, not hanging off with two bolts half way in and two missing thats good workmanship for ya int it
tafflade
PostPosted: 10:14 - 14 Jan 2009    Post subject: Reply with quote
ok, you've satisfied me that being 16 you do know everything Cool
lonner
PostPosted: 22:18 - 14 Jan 2009    Post subject: Reply with quote
they do grow up fast these days Laughing Laughing
adamcpi50sx08
PostPosted: 23:43 - 14 Jan 2009    Post subject: Reply with quote
whats being 16 got to do with anything
lukamon
PostPosted: 02:29 - 15 Jan 2009    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
he IS!
killa wrote: Im an ass man myself
PostPosted: 02:34 - 15 Jan 2009    Post subject: Reply with quote
If only I knew now, what I knew then.
faddius
PostPosted: 05:41 - 15 Jan 2009    Post subject: Reply with quote
Deal with it, if you crash because the gear box blows up - theyre liable.
If the gearbox blows up and you dont crash and die horribly - you get a new bike.
And the gearbox can jump for alot of other reasons too.
Damn 16 year olds Rolling Eyes
Children in the back of cars cause accidents : Accidents in the back of cars cause children
Riding since OCT '05 - Sym Jet 50cc, Honda Varadero 125cc, Suzuki GS500, Honda VFR750, SV650s current & in posession of Aprilia RS125, Honda NS125R
tafflade
PostPosted: 10:02 - 15 Jan 2009    Post subject: Reply with quote
you come across as an intelligent young man, if I hadn't have looked at your profile I wouldn't have known you were still at school, most school kids on forums cant put a sentence together properly without using txt spk Mad you can.
MrsTaff is a computer engineer and looks after big networks and stuff, she has a saying -
'a little bit of knowledge is a dangerous thing'
she means that people that think they know how computers work are the one that are likely to fiddle with the computer worky bits (the BIOS?) and fuck the machine up, they then go crying to her to fix it which will normally take a days work.
Numpty's like me will just ask her to sort out whatever is the minor problem in the first place and she'll do it in 5 mins.
do you see where I'm going with this?
yes your a bright lad but (I assume) you dont quite have the knowledge and experience to be having orgasmic rants over someone else's work, dont ever assume you know everything.
for what its worth, I've been an aircraft mechanic for coming up to 17 years, and as I said in an earlier post, I dont know everything and the things that I do know can change without much warning, I will always use the books provided to make sure what I'm doing is correct and if those under me dont use them they had better have a fucking good reason Wink
PostPosted: 10:16 - 15 Jan 2009    Post subject: Reply with quote
To be fair to the original poster; the gearbox was obviously not working after the garage changed the oil, so we can presume they did something wrong.
It's reasonable to assume that it was a problem with the oil from his experiences - however, as mentioned, I'd go and check to see what it should be, before hassling them.
Trying to make warranty claims can be pretty nasty and often result in you still with a broken bike, but also with a load of wasted time and money trying to get them to sort it.
adamcpi50sx08
PostPosted: 12:53 - 15 Jan 2009    Post subject: Reply with quote
wel why didnt you talk like that in the first place taff instead of trying to take the mick, i have been and told the head mechanic that the oil has been changed and it seems okay now and he told me not to worry because the bike is covered on warranty and if i have any more problems gearbox or not dont hesitate to take it striaght back, i am happy with this kind of service but not where your are telling them something that sounds wrong and they just look at your and nod there head and then tell you that he thought it was the wrong oil but he put it in anyway and then telling me that i would have to pay for a gearbox oil change even though it was the wrong oil that they put in
tafflade
PostPosted: 15:37 - 15 Jan 2009    Post subject: Reply with quote
because your first post was an I'll thought out, poorly constructed rant where you seemed to be saying 'I know better than the mechanic at the shop' whilst stamping your feet just like my little boy does Wink
The last post was made 17 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.88 - MySQL Queries: 13 - Page Size: 117.09 Kb
