Suzuki USA recall GSXR1000 K5 and K6 frames
WelshWizard
PostPosted: 09:53 - 19 Jan 2009    Post subject: Suzuki USA recall GSXR1000 K5 and K6 frames Reply with quote
Came across this in my travels today
https://www.roadracingworld.com/news/...?article=35357
Suzuki USA have done a voluntary recall on the gsx-r 1000, due to issues with cracking/breakage of the frame under some situations
They state only 1/2 of 1% of all gsxr 05/06 world wide have this issue (but thats still alot of bikes)
Whole article can be found in above
SoND
PostPosted: 10:05 - 19 Jan 2009    Post subject: Reply with quote
Linky no worky.
PostPosted: 10:10 - 19 Jan 2009    Post subject: Reply with quote
No UK recall yet, so don't worry about it. It may well be that the affected batch was ear marked for the USA, so it's not a problem for anyone else.
Link still not working btw, I checked the VOSA site.
WelshWizard
PostPosted: 08:41 - 20 Jan 2009    Post subject: Reply with quote
try here
https://www.roadracingworld.com/news/article/?article=35357
USA state its a world wide problem!
FASTERTHANSID
PostPosted: 22:21 - 20 Jan 2009    Post subject: Reply with quote
I've personally seen two frames fail like this in the U.K and both were on the track. Very poor welding on the joint as the frames on both had spilt the weld straight down the middle.
Mr Nice Guy
PostPosted: 00:05 - 21 Jan 2009    Post subject: Reply with quote
Can't be too weak, remember McGee sat on one for quite a while.
Suzuki GSX-R750K4 ~ Mivv GP
The Artist
PostPosted: 00:16 - 21 Jan 2009    Post subject: Reply with quote
I read about this happening ages ago.
Welds were not penetrating deep enough around the headstock. I thought they had recalled them already.
gateleyjk
PostPosted: 17:57 - 08 Feb 2009    Post subject: Recall hits UK. Reply with quote
Guys. This has hit the UK now. Had a letter from Suzuki yesterday. Hard to believe a motorcycle manufacturer can't weld!
Second time in the last few years. They are offering to put a 'brace' over the welds and use some adhesive! They have got to be joking. Why don't they use some masking tape as well? Unbelievable.
I wouldn't let a dealer near this kind of work nor do I want a bloody great brace showing on both sides of the frame. Resale value? Probably just lost a couple of grand off the market value which Suzuki will need to compensate each bike affected. Sad
John G.
BanditsHigh
Worse than a woman
PostPosted: 18:12 - 08 Feb 2009    Post subject: Reply with quote
Correct me if I'm wrong, but wouldn't this be deemed as selling a product which wasn't fit for purpose ... refund anyone?
If I had one of these I don't think I ride it again ... unless you want the possibility of going face first into the deck!!
SoND
PostPosted: 18:16 - 08 Feb 2009    Post subject: Reply with quote
Any pictures of this new brace?
I'd imagine the brace will sort it out ok. They would have spent a whole lot of money developing it to save themselves more in the future.
You'd be suprised at how strong some adhesives are.
PostPosted: 18:53 - 08 Feb 2009    Post subject: Reply with quote
I've posted a few pictures here Shocked
https://www.bikechatforums.com/viewtopic.php?t=166684
Second post down
Triumph Trophy Launch Edition
McGee
O RLY?
PostPosted: 19:52 - 08 Feb 2009    Post subject: Reply with quote
The new brace is two brackets and a metal rod that gets epoxied on near the head.
I got the paper work somewhere.
Simple enough but takes a couple of days as they dye test it and all that.
Its pronounced Jixxer!
Mr Nice Guy
PostPosted: 20:02 - 08 Feb 2009    Post subject: Reply with quote
McGee are you gonna change your sig to "Gixxers are made of adhesive" now?
MattEMulsion
PostPosted: 20:06 - 08 Feb 2009    Post subject: Re: Recall hits UK. Reply with quote
I don't think it is a welding problem as such, more of a design issue. I also believe that if the bike is used normally then you are unlikely to suffer a problem, but as soon as you start wheelie-ing the bike and slamming the front on and off the floor, that is what causes the problem to surface.
Yamaha YZF-R6
gateleyjk
PostPosted: 20:12 - 08 Feb 2009    Post subject: Reply with quote
The pictures on the web look like the weld has failed - totally sheared. I agree that you hope it is only under extreme handling that this could happen. Wheelies are not that extreme of course! Why has it taken them 3 years to pick this up?
What's the advice out there? Leave it as it is or have the work done?
John G.
MattEMulsion
PostPosted: 20:33 - 08 Feb 2009    Post subject: Reply with quote
Well I've not got a GSXR but if I did then I would certainly take it for the work to be done.
Yamaha YZF-R6
UrbanRacer
PostPosted: 23:57 - 08 Feb 2009    Post subject: Reply with quote
adhesive isn't going to hold the frame together if you start braking at 150mph and the frame gives way. so whats the point in getting it fitted?
MattHirst
PostPosted: 02:28 - 09 Feb 2009    Post subject: Reply with quote
You do know that epoxy is the strongest man made adhesive 'ever made' don't you?
I'd put my bets on the epoxy holding up more than a brittle weld in the event of a crash.
ZaphodBeeble
PostPosted: 09:11 - 09 Feb 2009    Post subject: Re: Recall hits UK. Reply with quote
Well for some people wheelying is normal. Besides, what happens if you hit a speed bump with similar force to landing a dodgy wheely? Or a pothole for that matter? The simple fact is; the frame should be able to handle anything you throw at it without breaking. It should be designed to bend not break.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
PostPosted: 10:26 - 09 Feb 2009    Post subject: Reply with quote
Don't fly on any modern Airbuses or the new Boeing dreamliner then... It might fly apart at 150mph...
UrbanRacer
PostPosted: 10:34 - 09 Feb 2009    Post subject: Reply with quote
cos it'll be same stuff eh? and even if it is would you expect a motorcycle mechanic to mix the epoxy for Boeing to use on there aircraft? i think not so shut yer yap!
PostPosted: 10:59 - 09 Feb 2009    Post subject: Reply with quote
Its not that different, and there are less stresses on a motorcycle frame than on an airbus wing...
SoND
PostPosted: 13:26 - 09 Feb 2009    Post subject: Reply with quote
It hasn't sheared at all, the weld has failed because of lack of penetration and fatigue. If the brace is designed properly it will divert the cyclic stresses away from the weld preventing it from failing.
The last post was made 17 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 120 Kb
