High Mileage Cars?
iCraig
PostPosted: 22:14 - 19 Jan 2009    Post subject: High Mileage Cars? Reply with quote
Hello,
Just wondering what people think of high mileage cars these days? Are the days gone where 130k+ doesn't matter anymore?
The reason I ask is there is 2 diesel cars I've seen, one had 140k and the other 180k. Both have comprehensive service histories and drive fairly well, infact the 140k drives much better than a 90k car I test drove the other day.
They are both French cars and very cheap. Would you consider them if you were doing alot of miles and needed a cheap diesel?
Craig
NSR Mick
PostPosted: 22:23 - 19 Jan 2009    Post subject: Reply with quote
Wouldnt buy a french car under any circumstances but that's another discussion.
My Beemer had 150000 on it when I bought it and it drives as well as my 100000 mile Passat and my 40000 mile Bora did.
With a French car at 100000+ the engine would be the least of your worries I would suspect.
The View Askew
PostPosted: 22:25 - 19 Jan 2009    Post subject: Reply with quote
Service history high milers are relatively ok, with diesel its a must engine oil was changed when required, motorway miles are better but you can't tell, check to see if parts that normally expire before this point have been replaced recently eg shocks/discs/belts/pads/wishbones/bushes/clutch ect.
Check the tyre tread, move steering from lock to lock, see if there is noise or play, make sure you drive it, test abs if it has it, as we have been through in great detail with siggi, it is bad news.
Check for electrical faults such as ecu errors or ecu light.
General interior condition is also a good tell tale, as is number of owners, see if mileage throughout history adds up.
It's always a gamble with a car THAT high though, I'd look for maybe 100k on a diesel, a 180k car will lose its big end bearings before long/cv joints/driveshafts all worn.
The View Askew
PostPosted: 22:32 - 19 Jan 2009    Post subject: Reply with quote
Sorry just seen the word french, I am now assuming these are mechanically injected D Turbo Peuguot/Citroen models, not the HDI equivalent.
They are Isuzu engines and are reliable, and can be played with by shortening the wastegate arm on the turbo (gotta stick a gauge on it) and upping the fuel a the pump, and depending on whether having a lucas or bosch fuel pump can run on veggie oil and a bit of diesel.
I had mine on 114k-130 and it didnt let me down, but the chassis and everything attached to it was groaning, and the BIGGEST factor with these cars is, a citroen zxara IS a 306, and vice versa, a 405 estate is an exception to this problem - The cables from chassis into the doors, are silly taught when closed, and will crack up, fray, and snap, leaving you with no leccy windows.
If it's a D Turbo, the engines are good, the rest, is very very rickety in my experience.
Edit: my 306 also had a FREAKISHLY abysmal turning circle.
Edit: there is also the issue of there being NO space in the engine bay, and if you need so much as an alternator belt, the engine needs to come off the mounts, and labour on changing belts ect will be higher.
iCraig
PostPosted: 22:35 - 19 Jan 2009    Post subject: Reply with quote
One is a 2.0 HDi Xsara, thats the one that has 180k on it. And the other is a Laguna II 1.9dCI Expression with 140k on it.
Its the latter I am considering the most, and I've had a good check over it and can't find much if at all anything wrong with it. Its only £1100 on a 52 plate too.
Nb
PostPosted: 22:42 - 19 Jan 2009    Post subject: Reply with quote
Steer well clear, and dont EVER buy a renault laguna 2. Especially the laguna 2 with a dci engine. Exclamation Exclamation Exclamation
PostPosted: 22:51 - 19 Jan 2009    Post subject: Reply with quote
I would reccomend against anything over 100k that isn't German.
That renault, if the engine hasn't gone pop (which they are reputed to on the Laguna 2 diesels) then the shocks, bushes, bearings and linkages will all be shagged by now.
Personally I'd either pay more and get a car that has done around 50k, or go older and get a car that has done about 50k. Or go German.
The View Askew
PostPosted: 22:52 - 19 Jan 2009    Post subject: Reply with quote
MarJay wrote:
Go German.
Mk3 Golf TDI would be a superb choice.
thegubner
PostPosted: 22:58 - 19 Jan 2009    Post subject: Reply with quote
I actually used to work with a lad who when asked about a cars high mileage would reply "well yeah that means its a good runner, its had loads of practice"
He also said I would earn loads of money as a car salesman the lying twat.
Robby
Dirty Old Man
PostPosted: 22:59 - 19 Jan 2009    Post subject: Reply with quote
I wouldn't go so far as to say go German. I'd say go German, Japanese, or Italian.
And don't go audi, the double wishbone jobbies (all of them?) wear their bushes out around 150k, and last I heard you can't just buy the bushes, so its most of a new suspension assembly. My brother was stung for £700 for one corner on a 98ish A4.
The View Askew
PostPosted: 23:03 - 19 Jan 2009    Post subject: Reply with quote
Jesus that is quite the eye opener, on my vectra its a £20 bush tool, and a sub that amount bush, only damn problem is, vectra rear suspension is just shit to be frank.
NiteMare
PostPosted: 23:33 - 19 Jan 2009    Post subject: Reply with quote
i've ran citroen bx diesel estates for the last 14-15 years, two naturally aspirated 1.9 and this present one is the 1.7/1.8 turbo (xud engines) ...
my first had 185k miles on the clock when it finally got scrapped, engine was rattly when cold but fine once warm, it had lost the synchro on second both cv's were clattering and generally the car was on it's last legs but the engine was still pulling strong...
the second had 220k miles on the clock when i finally sold it with 10 months mot and tax (was sold on the basis it still had those and was just a runaround for the duration), it had a sweet engine apart from rattling until warm, bodywork was pretty beat up, tatty interior and intermittent hydraulics failure...
my present one has 185k miles on the clock, engine smokes like buggery when first started but clears pretty quickly, again scruffy bodywork and the engine is starting to show signs of being tired (leaks/burns a little oil) but i've thrashed it for the last 60k miles with minimal maintenance and still load it up to the gunnells and/or drag my 6x4 trailer with it, stuck 99% of a GL1100 inside it then hooked up my bike trailer with another GL1100 on it then dragged the lot up to Doncaster from Birmingham at a steady 60-70mph and still got 45-50mpg , bought the car 5 years ago for 325quid and probably spent no more than 150 on it in essential repairs (i fix things) the nearside windows don't open any more, the central locking is playing up and the car is generally used as a dustbin (unwashed, unloved)...
i'll be keeping it a while longer yet unless i spot a Xantia diesel estate i fancy or a 405/406 estate, i really like the peugeot XUD engine and wish they still made them rather than the fly by wire Hdi stuff, simple and almost bulletproof
it ain't broke...
i ain't fixed it enough
PostPosted: 23:59 - 19 Jan 2009    Post subject: Reply with quote
Not Japanese. All the Japanese cars I've seen over 100k have really annoying faults which cannot be rectified cheaply. Its often stuff that will fail an MOT as well. They are pretty much designed to run to 100k and then die.
My MX3 had done 113k and it destroyed its distributor, the passenger side electric window was broken and the doors wouldn't always unlock even with a key. And it was quite well looked after. Also, I cannot honestly see my Subaru lasting beyond 100k.
trevoriv
PostPosted: 00:03 - 20 Jan 2009    Post subject: Reply with quote
My dad's K reg 2 litre petrol Mondeo GLX estate has been round the clock twice and that's with spending the last 6 years of it's life with half a ton of machinery in the back.
Granted it did once fail it's MOT on 8 counts and was deemed dangerous but a few hundred quid every few years gets it through it's MOT, in fact it just passed it's last once recently without a hitch and it's not even been cleaned or anything for a few years.
PostPosted: 00:05 - 20 Jan 2009    Post subject: Reply with quote
Italian stuff will take it as well. Problem is people not bothering with maintenance.
At 180k it is probably just about due its 4th engine.
Robby
Dirty Old Man
I sold my MR2 with about 100,000 on the clock and it was behaving fairly well, apart from the rust. It was 20 years old, so rust is allowed.
Your MX3 was shit and you know it, and scoobys are often on ebay with over 100k. The problem is that jap parts prices are generally higher, and when a car hits 100k it becomes worthless, so a difficult clutch change and some knackered shocks will write off a car.
Comparing like with like, I would expect a 150k diesel corrolla to be as good as a 150k diesel golf.
Now the VW fan boys will come in to suck some VW cock in defence, then go back outside and stretch their tyres some more.
D O G
PostPosted: 00:55 - 20 Jan 2009    Post subject: Reply with quote
Just wondering what you think on the 156 1.9/2.4 JTD's, from around the year 2000?
Any common problems with them, or things to look out for? What about the petrol variants?
Thanks!
veeeffarr
PostPosted: 00:57 - 20 Jan 2009    Post subject: Reply with quote
Funny you mention lagunas, was just reading this on PH lol:
https://www.pistonheads.com/gassing/topic.asp?h=0&t=636551&nmt=Why%20do%20new%20shape%20laguna%27s%20sell%20so%20cheap?
Phoenix
Twisted Firestarter
PostPosted: 01:33 - 20 Jan 2009    Post subject: Reply with quote
Wouldn't touch a French car with that kind of mileage on, no way the engine will last and would be suprised if it's still running the original engine or at least one that hasn't been rebuilt in some way, the chassis won't last either.
I bought my current BMW on 168,000 miles without hesitating, on 178 now with no problems and am confident it'll get to 250 without anything major, you need to test drive a high mileage car to make sure the engine still feels tight and to make sure the cars not falling to bits though. German, Swedish or Japenese will all go for 250K easily if serviced properly, an unserviced car won't obviously, but will still probably last longer than a fully serviced French/Ford/GM. I'd trust a Hyundai to last longer than a french car.
As for Alfa 156s, a guy at work bought one not long ago and the engine broke permanently a week later, oil pump failed, he said it's a known problem apparently, his was only about 70,000 I think, his was the petrol not a Diesel.
thegubner
PostPosted: 08:53 - 20 Jan 2009    Post subject: Reply with quote
I know people keep saying don't go French but I bought a Peugeot 406 diesel with a quarter of a million miles on the clocks.
It had no problems at all, I even managed to sell it for a tenner more than I bought it.
A guy bought it for his Dad, the tax and MOT were running out when I sold it to him but he e-mailed me telling me it flew through its next ticket.
I know the French don't have a great reputation for cars but diesel 406's are belting motors. I have no doubt in my mind that with a service every year that car will make half a million miles.
My uncle had a 406 with over 300,000 on the clock, the clocks reset and go back to zero (on the earlier models at least) at 300,000.
That was a couple of years ago, its still driving about now.
Don't ignore all French cars.
mooserx
PostPosted: 09:48 - 20 Jan 2009    Post subject: Reply with quote
exactly,
i've got a megane coupe with 150k on the clock, still runs sweet as a nut. my 2p is it all depends on how the motor is maintained, if its well looked after then it'll see you right.
Bendy
Mrs Sensible
PostPosted: 11:09 - 20 Jan 2009    Post subject: Reply with quote
MarJay wrote:
Or go German.
Like my mk3 Golf with the knackered shocks, knackered turbo, knackered rear leccy window, knackered sunroof, knackered clutch and knackered brakes?
At least my french car only had a knackered clutch, knackered battery and developed a knackered bonnet that put a stop to topping up the oil it was burning.
My japanese one had knackered brakes, knackered clutch slave cylinder, knackered exhaust and developed a knackered stereo.
It's all about the maintenance. And most people don't bother. I sure as hell never did. Smile
Cigaro
PostPosted: 11:35 - 20 Jan 2009    Post subject: Reply with quote
I've known people with 504Ds to get 300,000 miles + from them.
As said, not all french stuff is crap.
jayvfr
PostPosted: 11:42 - 20 Jan 2009    Post subject: Reply with quote
Fully agree, most french cars I wouldn't really consider at all but 406 Diesels seem to last very very well. Most of them are much more solid and have better electrics although some have been known to be totally riddled with nasty little electrical gremlins that never get fixed. Find a good one and you won't do much better for your cash IMO.
The alfa's are good cars if looked after. I would definitely avoid the petrol variants though, unless you're looking for a nice V6 they can just end up being an utter pain with niggly faults.
The Diesels are great motors though, very very solid engine which is easily tuned too. But again be wary of any small electrical faults, it could be the tip of the iceberg. keep it serviced and you'll be safe for 150k plus. Aim for the 2.4 but factor in a few front tyre swaps as they are very torquey and have a lot of weight over the front.
At all costs avoid any of the selespeeds though, they'll probably feel fine while you test drive it but they are so prone to problems it'll probably stop working as soon as you get it home, people often find it hard to sell them on.
A quater of a NC30 and a whole tatty ZX6R J2, that's plenty...
VFR bits for sale, PM me for details!
PSN ID: money85
PostPosted: 11:55 - 20 Jan 2009    Post subject: Reply with quote
Don't really know anything about the diseasels. I basically don't like diesels (although had a go in a diesel Alfa Mito last night), and cannot really imagine bothering to buy one for a car which I wanted to be in any way interesting to drive.
Petrol wise the weak point are the front suspension wishbones(both upper and lower) where the bushes and ball joints wear out. However to replace all 4 would cost about £200 in parts (not done the lowers myself yet but the uppers are fairly easy to do). Rear suspension bushes go, but a replacement arm with bushes is about £30.
With the petrols the biggest issue is the cam belt. Alfa changed the service interval on them from 72k to 36k. When they snap they will bend the valves. Changed at 36k they should be fine.
The timing variators wear out and go rattly (first sign is that they sound like a diseasel when first started), but most people replace these (and the water pump) along with the belts / tensioners.
Main engine wise the only real problem is that the sump is pretty small, and when the mileage builds up they use a bit of oil. People don't bother to top them up and they run low, destroying the crank. Suspect that is what happened to Phoenixs colleague (or the previous owner ran it low and then sold it in a hurry).
Spark plugs are long life items, which means they are likely to be total gits to get out when the time comes.
Original radiators are rot prone. But a pattern one should be cheaper and longer lasting.
I would disagree that the selespeeds are prone to lots of problems. They are pretty reliable, just that the one problem they are prone to (the actuating unit for the selespeed gearbox) will likely cost more to fix than the car is worth by the time it goes wrong. Charlottes mother has a selespeed 156 which is now quite a way past 100k.
The last post was made 17 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 138.64 Kb
