| iCraig |
 iCraig World Chat Champion
| NSR Mick |
 NSR Mick World Chat Champion
| The View Askew |
 The View Askew World Chat Champion
 Posted: 21:25 - 19 Jan 2009 Post subject: |
Service history high milers are relatively ok, with diesel its a must engine oil was changed when required, motorway miles are better but you can't tell, check to see if parts that normally expire before this point have been replaced recently eg shocks/discs/belts/pads/wishbones/bushes/clutch ect.
Check the tyre tread, move steering from lock to lock, see if there is noise or play, make sure you drive it, test abs if it has it, as we have been through in great detail with siggi, it is bad news.
Check for electrical faults such as ecu errors or ecu light.
General interior condition is also a good tell tale, as is number of owners, see if mileage throughout history adds up.
It's always a gamble with a car THAT high though, I'd look for maybe 100k on a diesel, a 180k car will lose its big end bearings before long/cv joints/driveshafts all worn. ____________________ "Do what you always did, get what you always got" |
| The View Askew |
 Posted: 21:32 - 19 Jan 2009 Post subject: |
Sorry just seen the word french, I am now assuming these are mechanically injected D Turbo Peuguot/Citroen models, not the HDI equivalent.
They are Isuzu engines and are reliable, and can be played with by shortening the wastegate arm on the turbo (gotta stick a gauge on it) and upping the fuel a the pump, and depending on whether having a lucas or bosch fuel pump can run on veggie oil and a bit of diesel.
I had mine on 114k-130 and it didnt let me down, but the chassis and everything attached to it was groaning, and the BIGGEST factor with these cars is, a citroen zxara IS a 306, and vice versa, a 405 estate is an exception to this problem - The cables from chassis into the doors, are silly taught when closed, and will crack up, fray, and snap, leaving you with no leccy windows.
If it's a D Turbo, the engines are good, the rest, is very very rickety in my experience.
Edit: my 306 also had a FREAKISHLY abysmal turning circle.
Edit: there is also the issue of there being NO space in the engine bay, and if you need so much as an alternator belt, the engine needs to come off the mounts, and labour on changing belts ect will be higher. ____________________ "Do what you always did, get what you always got"
| iCraig |
| Nb |
 Nb World Chat Champion
 Posted: 21:42 - 19 Jan 2009 Post subject: |
Steer well clear, and dont EVER buy a renault laguna 2. Especially the laguna 2 with a dci engine.  ____________________ Cbr1100xx blackbird gone, mk4 golf gt tdi chav now
Columbus travel insurance are crap!! Do not use! |
| MarJay |
 MarJay But it's British!
| The View Askew |
 Posted: 21:52 - 19 Jan 2009 Post subject: |
Mk3 Golf TDI would be a superb choice. ____________________ "Do what you always did, get what you always got" |
| thegubner |
 thegubner World Chat Champion
 Posted: 21:58 - 19 Jan 2009 Post subject: |
I actually used to work with a lad who when asked about a cars high mileage would reply "well yeah that means its a good runner, its had loads of practice"
He also said I would earn loads of money as a car salesman the lying twat. |
| Robby |
 Robby Dirty Old Man
| The View Askew |
| NiteMare |
 NiteMare Spanner Monkey
 Posted: 22:33 - 19 Jan 2009 Post subject: |
i've ran citroen bx diesel estates for the last 14-15 years, two naturally aspirated 1.9 and this present one is the 1.7/1.8 turbo (xud engines) ...
my first had 185k miles on the clock when it finally got scrapped, engine was rattly when cold but fine once warm, it had lost the synchro on second both cv's were clattering and generally the car was on it's last legs but the engine was still pulling strong...
the second had 220k miles on the clock when i finally sold it with 10 months mot and tax (was sold on the basis it still had those and was just a runaround for the duration), it had a sweet engine apart from rattling until warm, bodywork was pretty beat up, tatty interior and intermittent hydraulics failure...
my present one has 185k miles on the clock, engine smokes like buggery when first started but clears pretty quickly, again scruffy bodywork and the engine is starting to show signs of being tired (leaks/burns a little oil) but i've thrashed it for the last 60k miles with minimal maintenance and still load it up to the gunnells and/or drag my 6x4 trailer with it, stuck 99% of a GL1100 inside it then hooked up my bike trailer with another GL1100 on it then dragged the lot up to Doncaster from Birmingham at a steady 60-70mph and still got 45-50mpg , bought the car 5 years ago for 325quid and probably spent no more than 150 on it in essential repairs (i fix things) the nearside windows don't open any more, the central locking is playing up and the car is generally used as a dustbin (unwashed, unloved)...
i'll be keeping it a while longer yet unless i spot a Xantia diesel estate i fancy or a 405/406 estate, i really like the peugeot XUD engine and wish they still made them rather than the fly by wire Hdi stuff, simple and almost bulletproof ____________________ it ain't broke...
i ain't fixed it enough |
| MarJay |
| trevoriv |
 trevoriv World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Robby |
 Robby Dirty Old Man
| D O G |
 D O G World Chat Champion
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 23:57 - 19 Jan 2009 Post subject: |
| Phoenix |
 Phoenix Twisted Firestarter
 Posted: 00:33 - 20 Jan 2009 Post subject: |
Wouldn't touch a French car with that kind of mileage on, no way the engine will last and would be suprised if it's still running the original engine or at least one that hasn't been rebuilt in some way, the chassis won't last either.
I bought my current BMW on 168,000 miles without hesitating, on 178 now with no problems and am confident it'll get to 250 without anything major, you need to test drive a high mileage car to make sure the engine still feels tight and to make sure the cars not falling to bits though. German, Swedish or Japenese will all go for 250K easily if serviced properly, an unserviced car won't obviously, but will still probably last longer than a fully serviced French/Ford/GM. I'd trust a Hyundai to last longer than a french car.
As for Alfa 156s, a guy at work bought one not long ago and the engine broke permanently a week later, oil pump failed, he said it's a known problem apparently, his was only about 70,000 I think, his was the petrol not a Diesel. |
| thegubner |
| mooserx |
 mooserx Nearly there...
| Bendy |
 Bendy Mrs Sensible
| Cigaro |
 Cigaro World Chat Champion
| jayvfr |
 jayvfr Scooby Slapper
 Posted: 10:42 - 20 Jan 2009 Post subject: |
| the_guvnor_1_uk wrote: | I know people keep saying don't go French but I bought a Peugeot 406 diesel with a quarter of a million miles on the clocks.
Fully agree, most french cars I wouldn't really consider at all but 406 Diesels seem to last very very well. Most of them are much more solid and have better electrics although some have been known to be totally riddled with nasty little electrical gremlins that never get fixed. Find a good one and you won't do much better for your cash IMO.
| Damofo D.O.G. wrote: | Just wondering what you think on the 156 1.9/2.4 JTD's, from around the year 2000?
Any common problems with them, or things to look out for? What about the petrol variants? |
The alfa's are good cars if looked after. I would definitely avoid the petrol variants though, unless you're looking for a nice V6 they can just end up being an utter pain with niggly faults.
The Diesels are great motors though, very very solid engine which is easily tuned too. But again be wary of any small electrical faults, it could be the tip of the iceberg. keep it serviced and you'll be safe for 150k plus. Aim for the 2.4 but factor in a few front tyre swaps as they are very torquey and have a lot of weight over the front.
At all costs avoid any of the selespeeds though, they'll probably feel fine while you test drive it but they are so prone to problems it'll probably stop working as soon as you get it home, people often find it hard to sell them on. ____________________ A quater of a NC30 and a whole tatty ZX6R J2, that's plenty...
VFR bits for sale, PM me for details!
PSN ID: money85 |
| Kickstart |
The last post was made 17 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
